#18961 | Link | |
Grumpy Old Man.
As RB uses FFMPEG, it would probably be the same, ONLY Atak can answer, for sure. If you don't want to down mix 7.1, just use X Copy for the audio, OR mux it in later with MkvToolNix.
Not poorly done, just doin' it my way !!! Live every day like it is your last, because one day, it will be !! (M$B) PD Builds, etc |
#18962 | Link |
why wave?
RB's default is to convert dts-ma and trueHD to wave. When the end result is to be AC3 or AAC, is there any advantage to the default wave conversion or am I better off demuxing the dts-ma and trueHD?
#18963 | Link | |
Grumpy Old Man.
However, how are you processing your movie files ?? Are they ripped disc's, downloaded .iso's, .mkv's or .mp4's ?? I think it depends on your process to whether RB converts to .wav. I recall that it might convert to .wav if it's a ripped disc, but if it's already an .mkv / .mp4 you can choose X Copy for the audio, and it will retain original spec's. If RB doesn't do what you want, you need to have a plan b, and that just might be demuxing / converting the audio to the type you want, then muxing it back in after RB's done what you want to the video. With my 4K encodes, I ONLY process the video thru RB, and mux back the audio & subtitles with MKVToolNix. Sorry to be the only one answering your questions....nobody else is !!!
#18964 | Link |
Converting Subtitles Exhausts Memory
Not sure if there was an update to bdsup2sub++ that causes it to consume almost all memory which causes all applications to be killed or it almost consumes all memory and it does eventually complete, but the subfile is has a zero size. I'm burning in subtitles for my mobile versions.
Is it still necessary to convert sup to sub to burn in the subtitles. I've had issues with color conversion between the two when burning 10bit color. ![]() Last edited by Ryushin; 4th March 2021 at 14:15. |
#18965 | Link |
BDSup2Sub.jar
Used BDSup2Sub.jar to convert sup to sub and it worked fine. Here is a link to the problem subtitle:
https://cloud.chrisdos.com/index.php/s/dsB4zrik8HFKd2N So I've encountered about a dozen of these bad forced subtitles created from MakeMKV in the Game of Thrones. I think something might have been wrong with MakeMKV in creating these forced subtitle files. Using the BDSup2Sub.jar file and using the original full subtitle file and then just extracting the forced subs out of it into an sub file seems to work most of the time, but I had a stuck sub (never went away) and a missing sub. I tried doing the same thing with bdsup2sub++ and it created the appropriate forced subtitles. I think this is an outlier issue Atak and I wouldn't spend any time on it. I'm just going to manually use bdsup2sub++ to created a forced subtitle file from the full subtitles file. Last edited by Ryushin; 4th March 2021 at 17:43. Reason: Further details |
#18966 | Link | |
Grumpy Old Man.
Have you had a look here :- https://www.videohelp.com/software/BDSup2Sub You might have to find another process.
#18967 | Link | |
I'd like to see RB remove the need to convert sup to sub for the burning in of subtitles. |
#18968 | Link | |
Grumpy Old Man.
![]() So you must enable the conversion in "Setting's" to do this...what happens if you don't ?? Yes, I think there's a LOT of stuff that could be changed in RB, it's still got a fair bit of "legacy" type stuff from the "early day's", that's basically redundant or inaccessible. I have to use convert ALL my subtitles to .srt. So I have a whole extra process to go thru. (please don't suggest using some streaming app). I watch all my movies off a USB stick, direct into the TV.
#18969 | Link | |
The conversion from sup to sub is done regardless of the "Convert Blu-ray to DVD Format". I don't have that checked. I do convert my foreign movies subtitles to .ass format and I push the subs into the black bars. Though with HDR you don't burn them into the bottom bar as it changes the lighting for the scene. Otherwise, my subs are what come on the disc. You can watch all your movies on a Nvidia Shield using Kodi or Plex. I have them all on my NAS and I watch them over my network. Not sure if it makes any difference watching from a filesystem on a USB stick or a network file system with the files residing on a NAS. NFS or SMB. |
#18970 | Link | ||||
Grumpy Old Man.
I thought if anyone could relate to that, it would be you. ![]() Quote:
![]() Each to their own, I guess. ![]() Cheers
#18971 | Link | |
Yes, muxing the subtitles in is not burning them into the video itself. I mux them in myself for my home theater files, but I burn them in for my streaming and mobile size versions. As for electricity, there are little nas servers that spin the drives down when not in use and they only use 10-15 watts of power when idle. |
#18972 | Link | |
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
#18973 | Link | |
Grumpy Old Man.
However, I just couldn't do that !!! I haven't got, nor planning to get a small NAS box. You see, I download stuff on my laptop, and then simply copy to a USB stick, then watch on the TV. If I had another system, then it would be more complicated, I'd still download on the laptop, copy to USB stick, then paste into NAS, then "stream" that to the TV, and to be honest, I haven't really got a WiFi network, other than the WiFi modem/router I use for my internet connection. And then there's the possibility of buffering...just don't need that. I do have a fairly good LAN network, but I don't want cables all over the place, as the laptop is in completely different part of the house..I guess I could setup a "Powerline" line network.... Anyway, I'm happy with my process, that's the main thing.
#18975 | Link | |
#18976 | Link |
I assume he wants nvencc added as AVC and HEVC Encoders
![]() @misagh72 Not likely that this will be happening ![]() mainconcept wrapped ffmpeg and rate control around the nvencc encoders (hybrid encoder for rtx by mainconcept, which seems to be what adobe has licenced), this implemeneatation could be interesting.. but its not free.. Since the hardware encoders are fast already, there is not much point in distributing the workload over several machines (although the slim and nice interface of ripbot certainly would be nice)... If you want to go for HW-Encoding, get a Turing (Ampere is the same in that regard) card, use hybrid, as encoder, staxrip or whatever you like that uses nvencc on one machine, I easily get fps of several hundred with some machines. If you even use the decoders and hw-filters, a very small CPU will do, too... |
#18977 | Link |
@misagh72:
Nvidia GPU chipset compatibility provided, NVEnc may be able to encode H.264 video, but it is not the x264 encoder (which does not use Nvidia GPU features at all). Nvidia GPU chipset compatibility provided, NVEnc may be able to encode H.265 video, but it is not the x265 encoder (which does not use Nvidia GPU features at all). |
#18978 | Link |
Distributed Encoding - Unable to open input file.
My client pc's can access RB's temp folder that's on my host pc via windows explorer, yet their EncodingServer windows all show "unable to open input file".
RB and all supporting software is installed on all pc's. I start ES manually on clients and then run RB only on host. No encoding process occurs. Results are same when firewall and virus protection are turned off. Do I need to configure my router? Do I need static IP's? Is there a step by step guide? If not, why? Are there any negative aspects of DE? Last edited by FuzzyNutz; 10th March 2021 at 03:43. |
#18979 | Link | |
Grumpy Old Man.
https://forum.doom9.org/showthread.p...49#post1935949 and maybe a couple of posts prior to that one.
