Old 24th March 2023, 09:24   #20041  |  Link
darkio
Yes, .Net Framework 3.5 is necessary.
darkio is offline   Reply With Quote
Old 29th March 2023, 13:02   #20042  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
It's time for another new build...
A month to the day, here's version 4.0.
Many updates & new scripts & filters, some have been removed
Scripts will not be compatible with previous builds.
And to keep the build sizes to a minimum, the LUT's folder is a separate download, and can be copied to wherever you like.
I'm trying something new today, no more hyperlinks, simply click on the "PD Builds, etc" in my "sig", and hopefully, all will be revealed.
Not poorly done, just doin' it my way !!!
Live every day like it is your last,
because one day, it will be !! (M$B) PD Builds, etc
Pauly Dunne is offline   Reply With Quote
Old 31st March 2023, 11:10   #20043  |  Link
FTLOY
Friend of a friend..
FTLOY's Avatar
Is there any way to increase the FPS of the video ?
I tried the AssumeFPS, but it actually just sped up the video, but the audio was still "normal", so it's instantly very out of sync
It would also be very handy to be able to do some basic Avisynth editing of the video & audio tracks, for those pesky intro's of TV episodes.
FTLOY is offline   Reply With Quote
Old 31st March 2023, 13:50   #20044  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Audio must be re-encoded. Probably you used "COPY STREAM" in audio section. That would explain why audio stream was out of sync with video.
Old 31st March 2023, 14:43   #20045  |  Link
FTLOY
FTLOY's Avatar
But AssumeFPS changes the speed of the clip, I want to just increase the FPS, not the speed.
And Trim video & audio tracks.
Old 31st March 2023, 16:23   #20046  |  Link
Atak_Snajpera
You mean by adding fake frames?
Old 1st April 2023, 09:24   #20047  |  Link
FTLOY
FTLOY's Avatar
Well, if that's what you want to call it!
But it would be a lot more useful than using AssumeFPS...I mean, who'd want to speed up their video & audio, expect for a novelty, like a "Chipmunk's" movie...
It would just be nice to have a few more video & audio editing & encoding options.
Old 2nd April 2023, 04:43   #20048  |  Link
TDS
Formally known as .......
TDS's Avatar
Subtitle font size..
Would it be possible to add an option to change the size of the subtitle font, especially when Rendering them ("burning them in") ?
I found this old post on VideoHelp...
https://forum.videohelp.com/threads/...synth-vsfilter)
video=TextSub(video,"C:\Temp\RipBot264temp\job1\ca ptions-3.srt",-1)
Does that -1 have anything to do with the size ??
This can be SO "TeDiouS"..
Long term RipBot264 user.
#1 Ryzen 7950X
#2 Intel i9-13900KF
#3 Ryzen 5950X
#4 Ryzen 5900X
#5 Ryzen 3950X
TDS is offline   Reply With Quote
Old 2nd April 2023, 07:20   #20049  |  Link
Atak_Snajpera
No.
http://avisynth.nl/index.php/Xy-VSFilter
Old 2nd April 2023, 07:23   #20050  |  Link
TDS
TDS's Avatar
Yes, I've been there a couple of times today, couldn't find anything about font size.
#1 Ryzen 7950X
#2 Intel i9-13900KF
#3 Ryzen 5950X
#4 Ryzen 5900X
#5 Ryzen 3950X
Old 2nd April 2023, 07:29   #20051  |  Link
Atak_Snajpera
If I recall correctly font style and size was controlled by external file .style.
example
[V4 Styles]
         Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, TertiaryColour, BackColour, Bold, Italic, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, AlphaLevel, Encoding
         Style: Default,Tahoma,18,&Hffffff,&H00ffff,&H000000,&H000000,1,0,1,2,1,2,20,20,20,0,1
It should be probably in the same directory as subtitle file with name like this
YourSubtitle.srt.style or YourSubtitle.style
I do not remember now...
Old 3rd April 2023, 20:36   #20052  |  Link
rp1989
Hi, does anyone know if there is any way to run the Ripbot264 Encoding Server in a docker container? This would be very useful for distributed encoding rather than setting up a windows VM.
rp1989 is offline   Reply With Quote
Old 4th April 2023, 04:18   #20053  |  Link
TDS
TDS's Avatar
Hardcoded subtitle option:-
Atak,
I have been looking around at how to add hard coded subtitles (.srt, .ssa), and it was suggested to me to try "assrender" (an unfortunate name).
It's very simple & basic, and I think you could easily integrate this into RB (but ONLY for rendered subs), there are lots of options, but the main options are font size & font style/type.
More info here :-
AssRender
And a simple script:-
LoadPlugin("%AVISYNTHPLUGINS%\assrender\assrender.dll")
video=assrender(video, "subtitle path & name.srt", scale=0.8, srt_font="Sans")
Biggest problem might be needing the full path & name of each & every subtitle, in the call
#1 Ryzen 7950X
#2 Intel i9-13900KF
#3 Ryzen 5950X
#4 Ryzen 5900X
#5 Ryzen 3950X
Old 5th April 2023, 15:53   #20054  |  Link
pinco1117
pinco1117's Avatar
Font size
I simply edited the "default.style" file with notepad located in the ripbot program folder under "Tools" and then "srttossa", I changed the Fontsize from 18 if I remember correctly to 16 and now each new file what load in which I print the subtitles above, it gives them to me immediately with this default, I hope I have been of help.
pinco1117 is offline   Reply With Quote
Old 6th April 2023, 01:03   #20055  |  Link
TDS
TDS's Avatar
Hi pinco1117,
OMG, that has been a LOT of help, thankyou.
Even Atak had forgotten about this, I think, that VideoHelp link where he mentions how to edit that "default.style" was slightly off in its location, but there you have it.
So now it's just a matter of what to change to get the desired result
These are the default settings :-
[V4 Styles]
Style: Default,Arial,20,16777215,65535,65535,-2147483640,0,0,1,2,1,2,10,10,10,0,1
I would think that the red would be the main changes.
EDIT:-
I just had a play around with these settings, and as far as I could tell, it does not change anything...there must be some other subtitling going on somewhere else
I even removed the srttossa & ssatosrt folders, and I still got subtitles in the preview, when set to render.
#1 Ryzen 7950X
#2 Intel i9-13900KF
#3 Ryzen 5950X
#4 Ryzen 5900X
#5 Ryzen 3950X
Old 6th April 2023, 02:55   #20056  |  Link
FTLOY
FTLOY's Avatar
Hi Atak,
I have run into a strange issue...
When using this call:-
video=FrameRateConverter(video,NewNum=60000,NewDen=1000)
When using DE, it doesn't create the chunks properly, and only processes 10 frames, and starts again.
However, in "single" mode, it works without issue.
Any ideas ??
Old 6th April 2023, 03:03   #20057  |  Link
TDS
TDS's Avatar
example
[V4 Styles]
In reference to what pinco1117 has mentioned, would you consider adding some tweaking options to the subtitles ?
Like once enabled, some drop down lists appeared, and you could change the font name, size & colour.
EDIT:-
This post is probably irrelevant, now
#1 Ryzen 7950X
#2 Intel i9-13900KF
#3 Ryzen 5950X
#4 Ryzen 5900X
#5 Ryzen 3950X
Old 6th April 2023, 05:15   #20058  |  Link
pinco1117
pinco1117's Avatar
Hi pinco1117,
[V4 Styles]
EDIT:-
I'm sorry it didn't work for you, I don't know if it's relevant but I use ripbot version 1.26.0, maybe there was some change to these settings with new versions.
Old 6th April 2023, 08:01   #20059  |  Link
TDS
TDS's Avatar
Interesting that you're still using an older version, is there a reason why you haven't updated ?
I would very much doubt that the subtitle function has been changed in a long time, but maybe I could try 1.26.0 for myself.
Thanks for the suggestion in the first place
#1 Ryzen 7950X
#2 Intel i9-13900KF
#3 Ryzen 5950X
#4 Ryzen 5900X
#5 Ryzen 3950X
Old 6th April 2023, 10:13   #20060  |  Link
pinco1117
pinco1117's Avatar
Let's say that for now I'm not interested in updating, I stayed with the 1080p resolution because the 4k format disappointed me especially for the choice of HDR which worsens the image for me, I did many tests, so for now the program is for me it works perfectly i have no DE problems, problems with resolutions and compression times and therefore i prefer not to mess with new problems, that's all so more for a personal choice.
