#19981 | Link | |
Formally known as .......
OMG, first post on page 1000 (congrats Atak)
As I said, I was going to test for you:- This is importing that 1920 x 960 clip of "1883" TV series:- Below is what is displayed in the Avisynth "Show Video Script" window Direct adding this as a job:- Code:
#Upscale LoadPlugin("C:\RipBot264_PD (01-02-23)\Tools\AviSynth plugins\ColorMatrix\ColorMatrix64.dll") LoadPlugin("C:\RipBot264_PD (01-02-23)\Tools\AviSynth plugins\Plugins_JPSDR\Plugins_JPSDR.dll") video=Spline36ResizeMT(video,1920,960) Code:
#Downscale LoadPlugin("C:\RipBot264_PD (01-02-23)\Tools\AviSynth plugins\ColorMatrix\ColorMatrix64.dll") LoadPlugin("C:\RipBot264_PD (01-02-23)\Tools\AviSynth plugins\Plugins_JPSDR\Plugins_JPSDR.dll") video=Spline36ResizeMT(video,1280,640) Code:
#Downscale LoadPlugin("F:\RipBot264v1.26.3\Tools\AviSynth plugins\ColorMatrix\ColorMatrix64.dll") LoadPlugin("F:\RipBot264v1.26.3\Tools\AviSynth plugins\Plugins_JPSDR\Plugins_JPSDR.dll") video=Spline36ResizeMT(video,1280,640) ![]() The only thing I would change is Spline36ResizeMT to Spline64ResizeMT.. ![]() This should also allow you to add any size clip, (in Batch) and it will "keep" the correct ratio, from now on. NICE.
This can be SO "TeDiouS".. Long term RipBot264 user. #1 Ryzen 7950X #2 Intel i9-13900KF #3 Ryzen 5950X #4 Ryzen 5900X #5 Ryzen 3950X |
#19982 | Link |
Thanks for the results, I need to do do some more testing this evening. In regard to changing Spline32ResizeMT to Spline64ResizeMT, is this something that can be done globally, or were you suggesting it as an option?
#19983 | Link | |
No, this is not a global option, it would have to be done on a per job basis, unless again, you created your own scripts. It would be nice if it was an option, OR changed by default, as I've read that 64 IS better than 36.
#19984 | Link |
Because We all know that higher number is better... Right?
#19985 | Link | |
http://avisynth.nl/index.php/Resize#...based_resizers Spline64Resize may be the most accurate of the Resize filters. Spline16Resize is sharper and rings just a bit (which may be desirable with soft sources), and looks pleasing to the eye when enlarging or reducing in moderate amounts. Spline36Resize is somewhere in between the other two.
#19986 | Link |
Do some real tests first. Spline64Resize for example is ~20% slower than Spline36Resize without any noticeable by humans difference.
Like you mentioned Spline36Resize is a good compromise between speed and overall quality of scaling. Do not expect miracles using spline64. You won't get extra details like with some AI powered stuff.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 13th February 2023 at 14:38. |
#19988 | Link |
All I know is I have done a bunch of downsizing of 4k to 1080 for a friend of mine with "I guess" Spline36Resize, never paid attention to that, and I have always had great results. Everything looks fine to me . I don't use ripbot to upscale anything, If I need to upscale 480p stuff I run that through Topaz Video Enhance AI before I convert back to x265.
#19989 | Link |
Grumpy Old Man.
Update package for standard RipBot264..
I thought it was time to make an updated build of this, for those who use Atak's RipBot, and would like the latest available for the main components.
Moved, and updated.
Not poorly done, just doin' it my way !!! Live every day like it is your last, because one day, it will be !! (M$B) PD Builds, etc Last edited by Pauly Dunne; 21st February 2023 at 02:53. |
#19990 | Link | |
#19991 | Link |
Request for the return of a long "lost" decoder...
Atak, as you well know, several years ago you made the decision to change the default video decoder from FFMS2 to the then fairly new Lsmash, mainly for frame accuracy, I believe.
But there is no option (other than to do it manually in the .ini file), to change this back to FFMS2. I'm sure it wouldn't be too difficult for you to re-instate this as a user option, so at least they had an easy choice. There have been several FFMS2 updates recently, so maybe update it in RB at the same time ![]() https://forum.doom9.org/showthread.p...02#post1983002 There have also been some new updates for avsresize as well... https://forum.doom9.org/showthread.p...91#post1982991 But, as always, this is entirely up to you, so please consider. ![]()
#19992 | Link | |
A 5 minute 1080p clip @ Spline32 took 3:28..size was 126,016Kb Same 5 min clip @ Spline64 took 4:48. and was 125,935Kb Couldn't tell any difference on 27" 4K monitor, but maybe on 4K TV ![]() Have started using Topaz Video Enhance AI ![]()
#19993 | Link | |
![]() ![]() Do you really want that kind of problems after encoding in distributed encoding mode?
#19994 | Link |
I'm trying to use Ripbot264 on a Dell Poweredge R510 and it seems to be stuck opening after I have installed the OpenCL runtimes for the Xeon CPUs. The OpenCLinfo.cmd step seems to keep dumping info in to OpenCLinfo.txt and doesn't seem to finish (been waiting 30mins). The OpenCLinfo.txt file is currently 72MB in size and still increasing.
Platform 0. Name : Intel(R) CPU Runtime for OpenCL(TM) Applications Vendor : Intel(R) Corporation Version : OpenCL 2.1 WINDOWS Profile : FULL_PROFILE Extensions : cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_dx9_media_sharing cl_intel_dx9_media_sharing cl_khr_d3d11_sharing cl_khr_gl_sharing cl_khr_fp64 cl_khr_image2d_from_buffer cl_intel_vec_len_hint 0.0 Device name : Hardware version : Software version : OpenCL C version : Compute units : 0 ...................................... Then lots of empty entries. ...................................... 0.555005 Device name : Hardware version : Software version : OpenCL C version : Compute units : 0 0.555006 Device name : Hardware version : Software version : OpenCL C version : Compute units : Code:
"D:\Storage\RipBot264v1.26.3\tools\OpenCLinfo\OpenCLinfo.exe" /cpu >> "D:\Storage\RipBot264v1.26.3\tools\OpenCLinfo.txt"
A Man Eating Duck Last edited by AMED; 17th February 2023 at 02:09. |
#19995 | Link | |
I have been using FFMS2 & DE for a couple of weeks, and I haven't noticed any processing or playback problems. But if you think it's mainly a problem for DE, I'm sure there are MANY users who can't or don't use DE. NOTE:- and for you users that aren't aware, Distributed Encoding CAN be used on a single pc !!!, and there are benefits of doing so !!
#19996 | Link | |
![]() So, it might be an idea to add a basic AMD or nVidia GPU to use OpenCL better. But if you've found a workaround, that might be all it needs. I have several Dell & SMC server's and haven't had too much success with Intel OpenCL stuff, so I have just added a GPU. Good Luck.
This can be SO "TeDiouS".. Long term RipBot264 user. #1 Ryzen 7950X #2 Intel i9-13900KF #3 Ryzen 5950X #4 Ryzen 5900X #5 Ryzen 3950X Last edited by TDS; 17th February 2023 at 03:01. |
#19998 | Link | |
Just check 1.avs file in Chunks folder.
#19999 | Link | |
![]() It also shows in the video script. I will check that tomorrow. DONE !! EDIT:- I have checked 1.avs in the Chunks folder, and this is what it shows :- Code:
#VideoSource LoadPlugin("\\RYZEN-9-7950X\RipBot264temp\Tools\AviSynth plugins\ffms\ffms_latest\x64\ffms2.dll") video=FFVideoSource("\\RYZEN-9-7950X\RipBot264temp\job1\video.mkv",threads=0,cachefile="\\RYZEN-9-7950X\RipBot264temp\job1\video.mkv.ffindex")
This can be SO "TeDiouS".. Long term RipBot264 user. #1 Ryzen 7950X #2 Intel i9-13900KF #3 Ryzen 5950X #4 Ryzen 5900X #5 Ryzen 3950X Last edited by TDS; 18th February 2023 at 01:54. |
