Old 11th June 2022, 19:21   #21  |  Link
Update for ConvTxtToOggChap.avsi, supports COMMA (,) fractional time separator as well as PERIOD (.) separator.
# ConvTxtToOggChap.avsi         # (c) StainlessS @ https://forum.doom9.org/showthread.php?p=1966757#post1966757
# Converts very loosely user specified times and chapter name in file, to Ogg/Ogm Chapter style in file.
# Requires AVS+, and RT_Stats v2.0 Beta13+
Function ChrIsNul(String S)      {return RT_Ord(S)== 0}                             # End of String
Function ChrIsHash(String S)     {return RT_Ord(S)==35}                             # #
Function ChrIsWhite(String S)    {C=RT_Ord(S) return C==32||C>=8&&C<=13}            # SPC, BackSPC, TAB, LF, VT, FF, CR
Function ChrIsDigit(String S)    {C=RT_Ord(S) return C>=48&&C<=57}
Function ChrEatWhite(String S)   {i=1 C=RT_Ord(S,i) While(C==32||C>=8&&C<=13)       {i=i+1 C=RT_Ord(S,i)} return i>1?MidStr(S,i):S}
# Return extent of string S [ie length from the beginning] that matches any character in Chars set of characters [Default case insignificant]. # StrMatchChrLen("1234.567abcd","0123456789.") = 8
Function StrMatchChrLen(String s,String Chars,Bool "Sig") {
    Function __StrMatchChrLen_LOW(String s,String Chars,int n) { c=s.MidStr(n+1,1) Return(c==""||Chars.FindStr(c)==0) ? n : s.__StrMatchChrLen_LOW(Chars,n+1) }
    Sig=Default(Sig,False)  # Default Case Insignificant
    s=(Sig)?s:s.UCASE   Chars=(Sig)?Chars:Chars.UCASE
    __StrMatchChrLen_LOW(s,Chars,0)
Function ConvTxtToOggChap(String txtfile,String "chapfile",Int "ChapIxLen",String "CommentChars") {
    myName    = "ConvTxtToOggChap: "
    Chap      = Default(chapfile,"")
    ChapIxLen = Default(ChapIxLen,3)                  # At Least ChapIxLen digits appended to CHAPTER Times and NAME. [NO CHECK if exceeded]
    CommentChars=Default(CommentChars,"#*")           # String of chars, any one of which will be interpreted as comment introducer.
    Assert(txtfile!="",RT_String("%stxtfile path required",myName))
    txtfile = txtfile.RT_GetFullPathName
    Assert(Txtfile.Exist,RT_String("%stxtfile Does not Exist",myName))
    Chapfile = ((chapfile=="") ? ".\OggChap.txt" : chapfile).RT_GetFullPathName  # Chapfile defaults "OggChap.txt" in current directory.
    Chapfile.RT_FileDelete
    SIN=RT_ReadTxtFromFile(txtfile)
    LINES = SIN.RT_TxtQueryLines
    DIGITS    = "0123456789"
    TIMEALP_A = DIGITS + ":"
    TIMEALP   = TIMEALP_A + ".,"
    ChapIX = 0
    for(i=0,LINES-1){
        S = SIN.RT_TxtGetLine(Line=i).ChrEatWhite.RevStr.ChrEatWhite.RevStr   # Get Line of text, remove EOL and Eat leading & trailing White Space.
        IsComment = CommentChars.RT_FindStr(S.LeftStr(1),sig=True)!=0
        if(!S.ChrIsNul && !IsComment) {   # Ignore blank lines and those beginning with Any character in CommentChars string.
            MilliSecs=0   Secs=0 Mins=0 Hrs=0
            Timelen=S.StrMatchChrLen(TIMEALP,sig=True)                                                  # Entire Time length
            Assert(TimeLen>0,RT_String("%sLine %d Time NOT FOUND @'%s'",myName,i+1,S))
            TITLE = S.MidStr(Timelen+1).ChrEatWhite                                                     # Chapter title
            ST = S.Leftstr(TimeLen)        # Time Only, no title
            Timelen_A=ST.StrMatchChrLen(TIMEALP_A,sig=True)                                             # Whole Part Only
            SA = ST.LeftStr(Timelen_A)        # Whole part string
            SB = ST.MidStr(TimeLen_A+1)        # Fraction Part String
            Chr = SB.MidStr(1,1)
            if(Chr=="." || Chr==",") { SB = SB.MidStr(2) }                                              # Strip leading '.' or ',' ::: Remaining SB MUST be digits only or "", else error
            Assert(SB.StrMatchChrLen(DIGITS,sig=True)==SB.StrLen,RT_String("%sLine %d Bad Fractional time @'%s'",myName,i+1,S))
            MilliSecs = LeftStr(SB+"000",3).Eval                                                        # Optional Millsecs, As integer, 0 -> 999 [Left Aligned, ie '.5' is 0.500 seconds]
            RTS = SA.RevStr
            ix = RTS.RT_FindStr(":")
            Secs = ((ix>0) ? RTS.LeftStr(ix-1) : RTS).RevStr.RT_NumberValue
            Assert(Secs < 60,RT_String("%sLine %d Invalid Seconds @'%s'",myName,i+1,S))
            RTS  = (ix>0) ? RTS.MidStr(ix+1) : ""
            Mins = ((ix>0) ? RTS.LeftStr(ix-1) : RTS).RevStr.RT_NumberValue
            Assert(Mins < 60,RT_String("%sLine %d Invalid Minutes @'%s'",myName,i+1,S))
            Hrs  = RTS.RevStr.RT_NumberValue
            Assert(Hrs < 24,RT_String("%sLine %d Invalid Hours @'%s'",myName,i+1,S))
            ChapIX = ChapIx + 1        # New Chapter
            TimeS            = RT_string("%02d:%02d:%02d.%03d",Hrs,Mins,Secs,MilliSecs)                 # Time as eg "23:59:59.987"
            CHAPTER_LINE     = RT_String("CHAPTER%0*d=%s",ChapIxLen,ChapIx,TimeS)
            TITLE = (TITLE=="") ? RT_String("Title %0*d",ChapIxLen,ChapIx) : TITLE                      # Improvise TITLE if is ""
            CHAPTERNAME_LINE = RT_String("CHAPTER%0*dNAME=%s",ChapIxLen,ChapIx,TITLE)
RT_DebugF("%d:%d] %s  : '%s' : '%s'",i+1,ChapIx,S.RT_StrPad(48),CHAPTER_LINE,CHAPTERNAME_LINE,name=myName)     # UnComment, output to DebugView
            RT_WriteFile(chapfile,"%s\n%s",CHAPTER_LINE,CHAPTERNAME_LINE,Append=True)
    return ChapIX # Number of Chapters written
Same Client,
ConvTxtToOggChap_Client.avs
# Import(".\ConvTxtToOggChap.avsi")
textFile  = ".\SimpleTimes.txt"     chapfile  = ".\chapfile.txt"
textFile2 = ".\SimpleTimes_2.txt"   chapfile2 = ".\chapfile_2.txt"
textFile3 = ".\SimpleTimes_3.txt"   chapfile3 = ".\chapfile_3.txt"
textFile4 = ".\SimpleTimes_4.txt"   chapfile4 = ".\chapfile_4.txt"
Nchaps = ConvTxtToOggChap(textfile,chapfile)
#Nchaps = ConvTxtToOggChap(textfile2,chapfile2)
#Nchaps = ConvTxtToOggChap(textfile3,chapfile3)
#Nchaps = ConvTxtToOggChap(textfile4,chapfile4)
MessageClip("DONE")
Return last
Mod to one of the test input files, SimpleTimes.txt [Added comma separator] {the other test files unchanged}
SimpleTimes.txt
00:00 Title 1
02:40 Title 2
09:27 Title 3
15:12 Title 4
1:05:23 Title x
1:13:26 Title xx
00:00. Title 7
02:40.12 Title 8
09:27.99 Title 9
15:12.71 Title 10
# Next line has fractional seconds period separator
23:59:59.987 Title 11
# Next line HAS NO TITLE TEXT - NOTE has fractional seconds comma separator
11:10:09,876
# Next line fractional seconds comma separator, and 500 millisecs time (.500)
11:10:09,5
# Next line No Hours, and no millisecs, NO TITLE TEXT
12:31
And result ChapFile.txt
CHAPTER001=00:00:00.000
CHAPTER001NAME=Title 1
CHAPTER002=00:02:40.000
CHAPTER002NAME=Title 2
CHAPTER003=00:09:27.000
CHAPTER003NAME=Title 3
CHAPTER004=00:15:12.000
CHAPTER004NAME=Title 4
CHAPTER005=01:05:23.000
CHAPTER005NAME=Title x
CHAPTER006=01:13:26.000
CHAPTER006NAME=Title xx
CHAPTER007=00:00:00.000
CHAPTER007NAME=Title 7
CHAPTER008=00:02:40.120
CHAPTER008NAME=Title 8
CHAPTER009=00:09:27.990
CHAPTER009NAME=Title 9
CHAPTER010=00:15:12.710
CHAPTER010NAME=Title 10
CHAPTER011=23:59:59.987
CHAPTER011NAME=Title 11
CHAPTER012=11:10:09.876
CHAPTER012NAME=Title 012
CHAPTER013=11:10:09.500
CHAPTER013NAME=Title 013
CHAPTER014=00:12:31.000
CHAPTER014NAME=Title 014
chapter, chapter entries, chaptereditor, converstion, converter
