7th February 2022, 20:06 | #1 | Link |
LWLibavVideoSource + sRestore + strange source
I'm using:
# Imports import os import sys import vapoursynth as vs # getting Vapoursynth core core = vs.core # Import scripts folder scriptPath = 'I:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/SourceFilter/LSmashSource/vslsmashsource.dll") # Import scripts import havsfunc # source: 'C:\Users\Selur\Desktop\Sample_8bit.avi' # current color space: RGB24, bit depth: 8, resolution: 320x224, fps: 59.94, color matrix: 470bg, yuv luminance scale: limited, scanorder: progressive # Loading C:\Users\Selur\Desktop\Sample_8bit.avi using LWLibavSource clip = core.lsmas.LWLibavSource(source="C:/Users/Selur/Desktop/Sample_8bit.avi", format="RGB24", cache=0, fpsnum=60000, fpsden=1001, prefer_hw=0) # making sure frame rate is set to 59.940 clip = core.std.AssumeFPS(clip=clip, fpsnum=60000, fpsden=1001) # Setting color range to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) # adjusting color space from RGB24 to YUV444P8 for vssRestore clip = core.resize.Bicubic(clip=clip, format=vs.YUV444P8, matrix_s="470bg", range_s="limited") # adjusting frame count and rate with sRestore clip = havsfunc.srestore(source=clip, frate=7.9920, omode=6) # adjusting output color from: to YUV422P10 for ProResModel clip = core.resize.Bicubic(clip=clip, format=vs.YUV422P10, range_s="limited") # set output frame rate to 7.992fps clip = core.std.AssumeFPS(clip=clip, fpsnum=8000, fpsden=1001) # Output clip.set_output() I get the same when using Avisynth: Code:
ClearAutoloadDirs() SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE) LoadPlugin("I:\Hybrid\64bit\Avisynth\AVISYN~1\LSMASHSource.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\AVISYN~1\RgTools.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\AVISYN~1\mvtools2.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\AVISYN~1\masktools2.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\AVISYN~1\TIVTC.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\AVISYN~1\Average.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\AVISYN~1\grunt-x64.dll") LoadPlugin("I:\Hybrid\64bit\Avisynth\AVISYN~1\MedianBlur2.dll") Import("I:\Hybrid\64bit\Avisynth\avisynthPlugins\Zs_RF_Shared.avsi") Import("I:\Hybrid\64bit\Avisynth\avisynthPlugins\Srestore.avsi") # loading source: C:\Users\Selur\Desktop\Sample_8bit.avi # color sampling RGB24@8, matrix: bt601, scantyp: progressive, luminance scale: limited LWLibavVideoSource("C:\Users\Selur\Desktop\SAMPLE~1.AVI",cache=false,format="RGB24", fpsnum=60000, fpsden=1001, prefer_hw=0) # current resolution: 320x224 # removing ghosting ConvertToYV24(interlaced=false, matrix="Rec601") srestore(frate=7.992,omode=6) # filtering # adjust color to YUY2 (color matrix: Rec601) ConvertToYUV422() # adjusting bit depth current 8 to target 10 # convert to 10bit for encoder ConvertBits(10) # setting output fps to 7.992fps AssumeFPS(8000,1001) # output: color sampling YV24@10, matrix: bt601, scantyp: progressive, luminance scale: limited return last source -> https://drive.google.com/file/d/1wD1...ew?usp=sharing Funny thing is when I load the source thorugh LWLibavVideoSource without specifying "fpsnum=60000, fpsden=1001" I get 362 frames the directly from the source filter, but sRestore has no effect in both cases. Remuxing the source to mkv and then loading the mkv doesn't change a thing. So then I thought this is an issue of LWLibavVideoSource, but since using AviSource instead of LWLibavVideoSource has the same effect, that sRestore doesn't work, I assume it's an issue with sRestore or the source in general or my system. -> A. Can someone else reproduce these effects? a. LWLibavVideoSource with "fpsnum=60000, fpsden=1001, " => 2748 frames, LWLibavVideoSource without "fpsnum=60000, fpsden=1001, " => 362 frames b. sRestore not having an effect on this source no matter whether "fpsnum=60000, fpsden=1001, " is used or not? B. Does someone know what is causing this (and ideally how to fix it)? Cu Selur |
avisynth, lagarith, srestore, vapoursynth |
