Old 14th May 2022, 08:37   #21  |  Link
Arx1meD
Arx1meD's Avatar
I decided to compare two different methods in the Grayworld filter. If you do not look closely, the difference is almost not noticeable. Or I am doing something wrong again.
so = DSS2("C:\test\underwater.mkv", fps=30.000)
v1 = so.ConvertBits(32)
v1 = v1.z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:709:709:f=>rgb:linear:709:f")
v1 = v1.grayworld(cc=0)
v1 = v1.z_ConvertFormat(pixel_type="YUV420", colorspace_op="rgb:linear:709:f=>709:709:709:l")
v2 = so.ConvertBits(32)
v2 = v2.z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:709:709:f=>rgb:linear:709:f")
v2 = v2.grayworld(cc=1)
v2 = v2.z_ConvertFormat(pixel_type="YUV420", colorspace_op="rgb:linear:709:f=>709:709:709:l")
StackHorizontal(so.AddBorders(0, 0, 0, 20).Subtitle("Source", align=2),
\ v1.AddBorders(0, 0, 0, 20).Subtitle("grayworld(cc=0)", align=2),
\ v2.AddBorders(0, 0, 0, 20).Subtitle("grayworld(cc=1)", align=2))
Test video: underwater
Comparison: underwater_test
Arx1meD is offline   Reply With Quote
Old 16th May 2022, 02:26   #22  |  Link
Reel.Deel
@Arx1meD
I don't think you're doing anything wrong. I tried the 2 modes with the "corals" image from here: https://www.eng.tau.ac.il/~berman/Un...orRestoration/
The difference in this image is not day and night but it is visible. Maybe with certain images the difference is very small. For what it's worth, asd updated the docs and added this to the median mode: "This mode is not affected by extreme values in luminance or chrominance."
Old 4th September 2022, 11:34   #23  |  Link
cork_OS
cork_OS's Avatar
Grayworld effect is unstable on my sources. Is there a way to smooth it temporally or limit its strength?
I'm infected with poor sources.
cork_OS is offline   Reply With Quote
Old 4th September 2022, 17:17   #24  |  Link
Arx1meD
Arx1meD's Avatar
Cork_os, I think not.
Maybe create a clip with compensation for movement. Something like that:
function MC_Clip(clip clp, int "blksize", int "overlap", bool "chroma", bool "truemotion", bool "global") {
blksize    = Default(blksize, clp.Width()<=720?16:32)
overlap    = Default(overlap, blksize<=16?2:4)
chroma     = Default(chroma, true)
truemotion = Default(truemotion, true)
glob       = Default(global, true)
sup    = MSuper(clp, hpad=8, vpad=8, pel=1, sharp=2, chroma=chroma)
bvec1  = MAnalyse(sup, isb=true,  blksize=blksize, overlap=overlap, divide=0, delta=1, plevel=0, truemotion=truemotion, global=glob, chroma=chroma) # backward vectors
fvec1  = MAnalyse(sup, isb=false, blksize=blksize, overlap=overlap, divide=0, delta=1, plevel=0, truemotion=truemotion, global=glob, chroma=chroma) # forward vectors
backw1 = MFlow(clp, sup, bvec1)
forw1  = MFlow(clp, sup, fvec1)
Interleave(backw1, clp, forw1)
MC_Clip(blksize=32, overlap=16, chroma=true, truemotion=true, global=true)
# Your filters are here!
SelectEvery(3, 1)
ffmpeg, filter, grayworld
