4th August 2022, 14:24 | #1381 | Link |
"I can get white NaN pixels (from the -0.1 values)."
If you think there is some bug around zero or in going negative - the float allow to add some 'big' positive offset like 10.0 to 'nominal' 0.0..1.0 range before operation and subtract after. I think it should completely avoid using any negative values and zero crossing at resampling engine. This also works without visible distortions Code:
Blankclip(width=256, height=256, pixel_type="YUV420PS") Expr("sx 128 > range_max 0 ?","") ColorYUV(off_y=50000) bicubicresize(2048,2048,0,0.75) ColorYUV(off_y=-50000) ColorYUV(gain_y=-100, off_y=50) ConvertBits(8) |
4th August 2022, 16:40 | #1382 | Link | |
Thanks DTL, yes I was trying to avoid adding an additional calls like preshaping or clamping. It's for the scaling spaces in ConvertFormat (gamma, linear, sigmoid, log)
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 4th August 2022 at 16:46. |
5th August 2022, 02:42 | #1385 | Link | |
@kedautinh12, can you check frame properties after AnimeIVTC? I don't have the script and its dependencies installed so I can't check but for me your clip works by deinterlacing with ex_bob(nnedi3=true).
Try adding propSet("_FieldBased",0) before deep_resize() Quote:
EDIT: hello_hello, you can download now updated TransformsPack here. Default OETF and EOTF have been changed for consumer delivery spaces. I might need to add more in the future. I also created a new function OOTF() in TransformsPack - Transfers. It will take a single remap gamma value in OOTF, but you can also specify OETF and EOTF gamma values as floats, or their transfer names as strings. For those transfers with piece-wise functions (a linear part towards zero) a minimization algo was implemented to find the power law match, so for example for sRGB it would minimize to 2.223. This is faster than linearizing then gamma encoding back. On another note I'm finally updating the SMDegrain documentation, half done already.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 5th August 2022 at 12:46. |
5th August 2022, 18:43 | #1387 | Link |
Well... I've tried, but I just don't understand the world anymore.....
720p Rec.709 YV12 source. No Avisynth+ frame properties. Transforms Pack 1.0 RC55 ConvertBits(16) ConvertToDoubleWidth() Matrix(From=709, To=601, Bitdepth=16) ConvertFromDoubleWidth() Spline36Resize(640,360) https://i.ibb.co/zx4gq2g/1.jpg ConvertToYUV444() ConvertBits(16) ConvertYUVtoLinearRGB(Color=2) ConvertLinearRGBtoYUV(Color=4) ConvertBits(8) ConvertToYV12() Spline36Resize(640,360) https://i.ibb.co/dt886c9/2.jpg fmtc_bitdepth(bits=16) fmtc_resample(css="444") fmtc_matrix(mat="709", bits=16) fmtc_transfer(transs="709", transd="linear") fmtc_primaries(prims="709", primd="601-625") fmtc_transfer(transs="linear", transd="601") fmtc_matrix(mat="601", bits=16) fmtc_resample(640,360,css="420") fmtc_bitdepth(bits=8) https://i.ibb.co/191WJpG/3.jpg ConvertFormat(640,360) https://i.ibb.co/VHKC1Dc/4.jpg ConvertFormat(640,360, OETF="170m", EOTF="170m") https://i.ibb.co/3dGfynG/5.jpg ConvertFormat(640,360, EOTF="170m") https://i.ibb.co/CBN1ZLY/6.jpg Bugs be here? Display_Referred("1886") https://i.ibb.co/PTPxJzd/7.jpg Display_Referred() ConvertFormat(640,360) https://i.ibb.co/FgXV3j1/8.jpg |
5th August 2022, 19:39 | #1388 | Link |
There's a regression when I repurposed Matrix_coef() to retrieve primaries for XYZ_to_RGB() a few weeks ago so it's reading 470M instead of 170M, hold on a bit. I've been thinking for some time on a manner to restructure the matrices vertically since I'm going to add many more but still haven't come with a solution...
Display_referred() should be working. You don't specify the transfer but the color space, if your source is "170M" and your display is calibrated to Rec.709 with 1886 transfer set: Code:
Display_Referred ("170M","709") # 709 or sRGB whatever your display is calibrated against EDIT: @hello_hello, updated TransformsPack to RC56 with the above fix. I can't follow your first two examples but for fmtconv you might want to use "601-525" which corresponds to "170M". And as I commented a few posts back you want to use 1886 transfer for going to and from linear since all/most media is delivered in this ODT (display referred).
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 5th August 2022 at 20:36. |
5th August 2022, 20:22 | #1389 | Link | ||
Sorry for the late response.
x64 Looks like that fixed it. |
5th August 2022, 20:51 | #1390 | Link |
@ENunn, that's very strange specially after the last fix for ex_retinex(), simply try directly:
ex_retinex(lo=80, tv_in=true, tv_out=false)
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
6th August 2022, 18:39 | #1391 | Link | |
I updated vsTCanny and it's still there. |
6th August 2022, 22:49 | #1392 | Link | |
Dogway, is there a RC56 version of Transforms Pack - Models? It's just that I'm only producing "no function named Matrix_coef" errors with ConvertFormat since updating the other two scripts.
2. 709 -> 601-625 conversion with HDRTools. What's the logic behind always converting to NTSC primaries? I was pondering over whether "170M" should still be used to describe a transfer function earlier, which led me to discover... unless the list is incomplete or I'm blind.... it no longer does for h265. http://www.vapoursynth.com/doc/funct...eo/resize.html And as rec.601 is the matrix for both digital "PAL" & "NTSC", the only reason I can think of for using 170M or 480bg is to differentiate between them. 601_525, 601_625 & 601 cover all the bases, although for CropResize I went with 601N, 601P and 601 even though the NTSC and PAL implication isn't accurate. For a while I was fairly anal about converting the primaries to 601, and I generally chose 601_625 because they're closer to 709, but if HD displays and players don't concern themselves with the primaries and simply assume 709, which I suspect they mostly do, a matrix-only conversion might be better. I'll take your word for that, but I still can't get my head around it as everything I've read indicates it's only a display transfer function, and because 1886 is designed to factor in the black (and white?) levels of a calibrated display, and because the display used for mastering is an unknown, and because the definition of "deliver" might be one that doesn't imply it's not converted to 709 (scene) before it reaches my TV, and because to me it defeats the purpose of 1886, but what do I know..... Last edited by hello_hello; 6th August 2022 at 23:13. |
7th August 2022, 10:40 | #1393 | Link | ||||
TransformsPack - Models was updated here. I simply forgot version update.
Now why did I keep 470BG transfer (2.8 gamma)? because in TransformsPack I allow you to do whatever you want to. Limited TV range for float? Also OK. AP0 primaries? Also OK (not listed in ITU) Another aspect is the matrix coefficient table, so RGB "is" a matrix ? ICtCp is a matrix? YCoCg? Another mess. They are color models, and the said "matrix" coefficients only refers to the YCbCr model matrix coefficients, not the ICtCp, not the YcCbcCrc or any other. No wonder you are confused, not even the standards make it right. I do my best to add comments on my scripts to give some background but I don't adhere strictly to ITU or any other standard. Quote:
The display used for mastering DVD/BD consumer media is calibrated to 1886, they make different (grade) trims depending on delivery media and it's always display referred (for the last 20 years at least). The workflow typically involves an IDT (OETF) -> Log/Linear (trim pass under EOTF proof) -> ODT (EOTF). So they work in log or linear space under an EOTF (1886) viewing transform. To be more specific, the input device might be calibrated so the IDT could be transformed from a custom (unknown) profile, and similarly the EOTF viewing transform is also a mastering monitor profile characterized against 1886. When encoding the EOTF into the image instead you don't use your display profile (with custom 1886 settings) but a generic one that assumes a perfect imaginary display with 0 black, so in essence a power law gamma of 2.4 and a generic color space with known primaries, like 709. This makes it possible to "undo" the transfer and primaries and convert to your display profile in case it's calibrated, or play very close to intended in case it's not calibrated -------------------------------------- @ENunn, what do you mean with "the issue is still there, plus it makes the image much brighter as well." Either the issue is present or it's making the image brighter which means it's working fine (that's retinex) if it shows your image black or as your above example, then there's an issue. But I'm not experiencing it with FFMS2 loader.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 7th August 2022 at 12:37. |
8th August 2022, 00:16 | #1394 | Link | ||||||
It's working now so I'll have a play with it again soon. Quote:
That's why I think replacing 170m with 601 (in respect to naming) as the transfer curve and matrix for digital is a good idea because if you read the wikipedia page it was intended for both PAL and NTSC and was later updated to include both the PAL and NTSC primaries. Some plugins (colormatrix) use 601 as the SD matrix, while some (avsresize) use it for the transfer curve but not for the matrix. Of course because the primaries are different for PAL and NTSC you do need a way to differentiate between them. Quote:
709:srgb:170m=>601:srgb:170m but I don't think any plugins will do that sort of thing for RGB without a format conversion in between. Maybe there's a reason for that I'm unaware of. Quote:
10 bit ITU-R BT.709 / D65 / ITU-R BT.1886 (Gamma 2.4) So then I checked out the packaging requirements: All deliveries to Netflix must be compliant to either SMPTE ST 2067-21:2016 or SMPTE ST 2067-21:2020 Interoperable Master Format (IMF) Application #2E. Okay, so what does SMPTE ST 2067-21:2020 say? COLOR.1 Mapped as specified for 625-line systems in Section 2.6 of Recommendation ITU-R BT.601-7. COLOR.2 Mapped as specified for 525-line systems in Section 2.6 of Recommendation ITU-R BT.601-7. COLOR.3 Mapped as specified in Section 1 of Recommendation ITU-R BT.709-6. Note: In Recommendation ITU-R BT.601 and Recommendation ITU-R BT.709, the signals... ...correspond to gamma pre-corrected signals. The above seems to serve as support for only using 601 too, but off to ITU-R BT.709-6. https://www.itu.int/dms_pubrec/itu-r...6-I!!PDF-E.pdf Overall opto-electronic transfer characteristics at source It doesn't seem to copy and past properly but it's the standard 709 OETF with the following footnote: (1) In typical production practice the encoding function of image sources is adjusted so that the final picture has the desired look, as viewed on a reference monitor having the reference decoding function of Recommendation ITU-R BT.1886, in the reference viewing environment defined in Recommendation ITU-R BT.2035. Just kill me now. Could "the encoding function of image sources" mean "the encoding function of the source video when it's decoded"? It won't install on this PC, but sometime soon I'm going to check out Davinci Resolve to see what it actually does. I've looked at a few instructional videos and what they show is what you've said, with the exception of rendering when choosing rec.709 as the output colorspace. There, the transfer curve used wasn't really clear. Last edited by hello_hello; 8th August 2022 at 01:28. |
8th August 2022, 16:43 | #1395 | Link | ||||
I'm adding or planning to add all sorts of analog models and spaces, for example YIQ, YPbPr and so on. NTSC 1953 was also analog only and it's included everywhere (for some reason). My design choice is similar to avisynth's "give people enough rope to hang themselves", replacing "hang" with the chance of being more capable or experimental, all while keeping a good user experience and defaults. Quote:
8th August 2022, 18:06 | #1396 | Link | |
I loaded it with ffms2, and the issue is still there. EDIT: It has something to do with the tweak line. I removed the convertbits parts and the issue persists. I also tried another tweak plugin, SmoothTweak, and the issue happens there as well. Tweak before SMDegrain causes the issue, tweak after SMDegrain does not have any issues. Last edited by ENunn; 9th August 2022 at 05:31. |
9th August 2022, 07:41 | #1397 | Link | ||
Lots of options is good, but for presets that'd be my preferred naming scheme. Quote:
My example probably should have looked like this 709:srgb:709=>601:srgb:170m but it was in reference to my fantasy for being able to correct the incorrect matrix used when converting YUV to RGB without changing color space. So it'd be RGB in and RGB out. For the above example you'd have RGB that was converted from YUV using the 709 matrix when it should've been 601, so in my fantasy it would correct that while staying in RGB. Maybe it's something that can't actually be done, although I was under the impression that's what the following would do for HDRTools, but looking at it again now I'm not really sure what it does. I think it's just changing the primaries. ConvertToRGB(matrix="rec709") ConvertRGBtoXYZ(Color=2) ConvertXYZtoRGB(Color=4) Well it does say "the encoding function of image sources is adjusted", and if it's referring to the source video it shouldn't apply if the source video was 1886. Anyway, it's obviously just guessing because I don't actually know. Last edited by hello_hello; 9th August 2022 at 07:46. |
9th August 2022, 10:11 | #1398 | Link | ||
601 is too ambiguous, for SD I follow the SMPTE nomenclature because they were the reference standard at the time and CCIR (now ITU) was behind. They simply knew what they were doing. All SD related content from ITU is badly copy/pasted from SMPTE standards or directly don't have a paper for the recommendation and simply refer to the SMPTE.
The good news in ConvertFormat is that it supports aliases, so if you like "601" or "601_525" (to remove ambiguity) simply input that and it will retrieve the best match. And the property IDs are unified so they will be the same for fmtconv, TransformsPack, avsresize, etc I expanded them though. Quote:
Read here. It shouldn't be a thing really. My question is, how do you know it's using the wrong matrix but the correct primaries? Quote:
11th August 2022, 11:30 | #1399 | Link |
Posts: n/a
Hello,
Could you advice how to setup denoiser like SMDegrain to clear this out? EDIT: on the screen there is less noise than on the video. i tired these without any spectacular effects: SMDegrain(tr=2, thSAD=500,thSADC=100, thSCD2=80, contrasharp=false, refinemotion=true, truemotion=false, search=4, subpixel=3, Chroma=true, plane=4, LFR=false, DCTFlicker=false) ### Dogway this is a good compromise between quality and speed Code: smdegrain(tr=2,mode="temporalsoften",blksize=32,thSAD=700,LFR=2,contrasharp=false,refinemotion=true) smdegrain(tr=2,mode="MDegrain",blksize=32,thSAD=400,LFR=false,contrasharp=true,refinemotion=true) EDIT: i've just adjusted in the latest version of SMDegrain below line acordingly: (prefilter== 5) ? pref.ex_KNLMeansCL(a=3,s=3,d=3,h=9.0,wmode=2,chroma=chroma,gpuid=gpuid,LFR=0*(nw/1920.)).ex_boxblur(0.5, mode="weighted", UV=Chr) and got some promissing results, but encode speed drop off beacuse CPU usage is only for about 70%. Last edited by madey83; 11th August 2022 at 12:14. |
11th August 2022, 12:16 | #1400 | Link |
I don't think you need to run the double call, I don't see the source that grainy (300 style).
Simply use a good prefilter, maybe BM3D, and raise 'tr' a bit. I don't know the reason to tweak thSCD2, also everything else is already the default so you can omit. KNLMeansCL runs in GPU with OpenCL, you can also try DGDenoise which runs over CUDA.
avisynth, dogway, filters, hbd, packs |
