Old 6th February 2021, 20:38   #1  |  Link
YaBoyShredderson
X265 high vs main tier??
In x264/H.264(AVC) high offers better quality than main, as far as i know anyway. Is the same true for x265? I ask as in staxrip i have to select an encoder level to use the high tier of that level. Selecting level 4 still uses main though? Im thinking at this point that its only a tag, like level, and doesnt actually affect quality as long i stay in range of the level/tier? Like it will only increase quality if i exceed the maximum bitrate of, say, level 4 main, and cross into level 4 high? I dont know if i explained that right but anyway. Is high tier better than main in x265?
YaBoyShredderson is offline   Reply With Quote
Old 7th February 2021, 10:25   #2  |  Link
rwill
H.264 has a High Profile which allows the use of additional coding tools like 8x8 transform. This increases Quality/Rate most of the time.
H.265 has a High Tier for Levels which potentially requires additional decoder resources and speed but has no effect on the selected Profile which specifies the available coding tools.
So if you do not hit Level Limits with H.265 there is no impact to Quality. Or you can constrain your streams to a specific Level to target a specific Decoder Class which is recommended for playback compatibility.
Old 7th February 2021, 13:08   #3  |  Link
YaBoyShredderson
So i can leave the level on automatic and dont have to worry about quality? I believe everything i encode will be within level 4 anyway, so selecting level 4 high wont make any difference?
Old 7th February 2021, 13:26   #4  |  Link
rwill
Well maybe you should not let the encoder automatically decide the level but set a hard cap yourself.
You can always download the h.265 spec from here:
https://www.itu.int/rec/T-REC-H.265-201911-I
and check the level limits for a certain level. Then configure all relevant parameters of your encoder to match a specific level and set that level at the encoder so no magic things that are not wanted happen.
Old 7th February 2021, 23:39   #5  |  Link
benwaggoner
That said, the default levels in HEVC are pretty sane for any given height * width * fps, and using the lowest content-compatible level maximizes decoder compatibility. x265 does a good job at automatically picking the optimal level for your content, and I only override it in rare and peculiar circumstances.
For reasonably slow presets and a broad range of content, the max bitrate/ref frames/ecetera of the default profile is almost always sufficient for excellent quality.
Ben Waggoner
My Compression Book
Old 8th February 2021, 09:38   #6  |  Link
excellentswordfight
Lost my old account :(
Correct me if I'm wrong, but afaik x265 does only enforce vbv restrictions when level is set manually.
And for OP, level 4 @ main has max bitrate of 12Mbps, that could effect quality for 1080p. But as I said above, I'm pretty sure that its left unrestricted at auto, so in that case it wont effect your output.
excellentswordfight is offline   Reply With Quote
Old 8th February 2021, 23:11   #7  |  Link
benwaggoner
My understanding is that it will automatically enforce the appropriate vbv-bufsize and vbv-maxrate for the given level irrespective of whether it was manually or automatically set. I've not tested that recently, though. It'd be obvious in the console output at the start of encoding.
Ben Waggoner
My Compression Book
Old 8th February 2021, 23:25   #8  |  Link
apophis906
My experience is that it doesn't enforce either of them. I have mine set to auto and have seen it set main level 4 and the output file average 19.7 Mb/s and know it spikes at some points into the 40's. I even tested a 4K clip with auto levels and a low crf to see if it would go past the default level 5 vbv settings and it got up to over 200 Mb/s and averaged around 150's.
apophis906 is offline   Reply With Quote
Old 10th February 2021, 02:24   #9  |  Link
benwaggoner
Peak bitrate can only be measured based on a particular VBV buffer size. I've seen MediaInfo calculate peak bitrates much higher than the stream actually had based on --vbv-maxrate and --vbv-bufsize.
Ben Waggoner
My Compression Book
Old 10th February 2021, 02:46   #10  |  Link
apophis906
All I can say is that when left to auto the bitrate will go up to what it needs to for the set crf. Even if that bitrate is past what the auto set level is and what its vbv maxrate would be.
A 5 min clip I muxed and ran through bdinfo. This was set to auto and came out as level 5 main.
VIDEO:
Codec                   Bitrate             Description
MPEG-H HEVC Video       37701 kbps          2160p / 23.976 fps / 16:9 / Main 10 @ Level 5 @ Main / 10 bits / HDR10 / BT.2020
FILES:
Name            Time In         Length          Size            Total Bitrate
00000.M2TS      0:00:00.000     0:04:59.757     1,620,111,360   39,405
CHAPTERS:
Number          Time In         Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:04:59.757     41,368 kbps     77,747 kbps     00:01:56.741    72,488 kbps     00:01:56.741    69,931 kbps     00:01:56.825    0 bytes         1,024,557 bytes 00:03:20.950
Old 10th February 2021, 08:42   #11  |  Link
excellentswordfight
VIDEO:
FILES:
CHAPTERS:
Yes this is my experience as well, and its also stated in the docs that vbv is disabled by default so when using crf mode its uncapped when level is set automatically. This is also why I always set level manually so that I dont get any weird spikes that can cause buffer issues for LAN streaming, SoC mediaplayers etc. 4.1 High for HD and 3.1 for SD usually is high enough either way to cause much impact on quality, were using the lowest possible for that MaxDpbSize can.
Old 23rd February 2021, 10:33   #12  |  Link
Tenkei
But what about device compatibility? If specification for a device says it supports "Main 10 Profile Level 4.1", does that mean main tier and high tier or just main? AFAIK Main 10 profile does not mean main tier, so I'm a little confused. If it's just main, can I assume that device supporting 4.1 main tier would also run 4.0 high?
Tenkei is offline   Reply With Quote
Old 23rd February 2021, 19:23   #13  |  Link
benwaggoner
Assume it's Main Tier unless otherwise specified.
The primary exception I can think if is that UHD Blu-ray's peak bitrate is a lot higher than 40 Mbps, so that probably should be done at High Tier and then --vbv-bufsize and --vbv-maxrate specified per the BD spec.
Ben Waggoner
My Compression Book
Old 23rd February 2021, 20:21   #14  |  Link
excellentswordfight
Yes, the uhd blu-ray standard specify high tier, the lower max bitrate is set as other disk based media cause of the limitation of the read bandwidth from the disk. The decoder itself in those units can probably handle the full data rate of high teir.
I wouldn't assume that, 4.0 high specify a higher data rate then 4.1 main.
Old 24th February 2021, 16:05   #15  |  Link
Tenkei
I'll have to manually set the profile then, because If I set the VBV constraints to eg. 19000, x265 will choose 4.0 high instead of 4.1 main.
Old 25th February 2021, 00:43   #16  |  Link
benwaggoner
Profile or Tier?
I always specify Profile and Level, and it always defaults to Main Tier as long as my --vbv-maxrate and --vbv-bufsize are within Main Tier limits.
Ben Waggoner
My Compression Book
Old 25th February 2021, 10:01   #17  |  Link
Tenkei
Profile or Tier?
I meant Level 4.0, Tier High, the wording on those settings confuse me too much.
Old 25th February 2021, 17:31   #18  |  Link
benwaggoner
I get that!
"High Tier Main Profile Level 4.0"
Some old x264 reflexes get weird here, since some content can use a different level in HEVC than H.264, H.264 High is equivalent to HEVC Main, etcetera.
Ben Waggoner
My Compression Book
bitrate, level, quality, staxrip, x265
