Old 22nd October 2021, 01:36   #21  |  Link
quietvoid
Well this is unfortunate. The decoder in the FireTV Stick 4K Max is not applying film grain on playback.
Has anyone checked if others supporting the Main profile do apply it?
LG C2 OLED | GitHub Projects
quietvoid is offline   Reply With Quote
Old 22nd October 2021, 04:21   #22  |  Link
benwaggoner
It's not applying the FGS filter, even though the AV1 bitstream is flagged with it?
If you can get me a repro file, I can get someone to take a look.
Ben Waggoner
My Compression Book
Old 22nd October 2021, 11:11   #23  |  Link
hajj_3
Amlogic A311D2 supports 8K AV1 @24p/4K 60p: https://www.cnx-software.com/2021/10...ssor-16gb-ram/
Old 22nd October 2021, 13:17   #24  |  Link
quietvoid
Yes that's right. I tested it with a libaom encoded file that has film grain params in the stream, but there is only one set that is repeated for all the frames.
You can find the file here: https://mega.nz/file/wR0AmY7K#eG3IIc...gBOAcLEeVfJwh0
I've played it with both Kodi and https://github.com/moneytoo/Player, both of which use the hardware decoder (JustPlayer uses ExoPlayer) and result in no grain application.
While mpv for Android is in software and applies the grain.
I'll have to test with a complete grain table to see if it makes a difference.
Old 27th October 2021, 01:54   #25  |  Link
benwaggoner
Thank you. It is being investigated. There was a Broadcom SDK issue (I believe fixed in the latest updates) that I know impacted some AV1 FGS decode, so it might be related to that.
Ben Waggoner
My Compression Book
Old 27th October 2021, 03:12   #26  |  Link
soresu
If you read the article fully it mentions that 8K video output is not supported despite being able to decode video at that resolution.
Apparently 8K output is expected on the long awaited S908X which may be a bit beefier with A76/A55 cores instead vs A311D2's A73/A53 core configuration.
soresu is offline   Reply With Quote
Old 28th October 2021, 08:27   #27  |  Link
olduser217
Fire TV Stick 4K Max uses Broadcom SoC?
According to Wikipedia, its CPU is Mediatek MT8696.
olduser217 is offline   Reply With Quote
Old 28th October 2021, 14:27   #28  |  Link
quietvoid
I'm pretty sure it's Mediatek, all the MediaCodec decoders advertised are MTK.
Old 29th October 2021, 18:21   #29  |  Link
benwaggoner
FWIW, it's not like 8K video is happening any year soon (no evidence yet that humans can see any difference between 4K and 8K in moving picture content). And 8K TVs typically have very advanced upsamplers in them, so it's probably better to feed native 4K to them and let the TV take it up to 8K.
Ben Waggoner
My Compression Book
Old 4th January 2022, 18:13   #30  |  Link
Spyros
AMD Unveils 6nm Ryzen 6000 ‘Rembrandt’ Chips With Zen 3+, RDNA2 and DDR5
AMD's new mobile CPUs (with Zen 3+ and RDNA 2 architectures) support AV1 hardware decode.
Spyros is offline   Reply With Quote
Old 6th January 2022, 07:22   #31  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Yet their newly announced lower end 6500 series discrete GPUs lack hardware decode!
Old 7th January 2022, 23:43   #32  |  Link
benwaggoner
No discreet decode hardware for anything?
That would break a lot of things, including anything with a hardware DRM requirement.
Ben Waggoner
My Compression Book
Old 8th January 2022, 02:31   #33  |  Link
Blue_MiSfit
They lack AV1 decode specifically
Curiously they also gimped hardware AVC and HEVC encoding on these products, which didn't make any sense to me.
Old 11th January 2022, 22:43   #34  |  Link
benwaggoner
How gimped?
Ben Waggoner
My Compression Book
Old 11th January 2022, 23:17   #35  |  Link
rwill
How gimped?
I think "gimped" as in "removed".
Old 12th January 2022, 07:22   #36  |  Link
Blue_MiSfit
It's not clear if the hardware encoders are still present, or restricted to 1080p..
Old 12th January 2022, 16:43   #37  |  Link
hajj_3
How gimped?
i think i read that they removed h265 hardware encoding.
Old 12th January 2022, 18:27   #38  |  Link
benwaggoner
Ugh.
I can kind of get why they might; HW encoders are mainly used for videoconferencing stuff in practice, where 1080p is a stretch goal. I've maybe used the HW encoders is my a6000 GPU three times ever.
Ben Waggoner
My Compression Book
Old 27th April 2022, 15:56   #39  |  Link
quietvoid
7 months have passed and the FireTV Stick 4K Max still doesn't do film grain synthesis correctly on playback.
At this point I've yet to watch anything in AV1 because of this.
I also don't think it supports AV1 through Netflix yet, but I haven't been subscribed for a couple months now.
Old 27th April 2022, 16:30   #40  |  Link
ChaosKing
@quietvoid I would like to test it on my firetv max. Are there publicly available samples with film grain synthesis to download anywhere? AV1 works with Kodi 20 (dev version) btw.
EDIT
Found your link https://forum.doom9.org/showthread.p...16#post1955516
Hmm yeah I don't see any generated noise in Kodi.
EDIT2
Looks correct in VLC, but not sure if HW accelerated...
av1, av1 hardware decode, hardware decoders
