Old 24th December 2009, 01:20   #1  |  Link
jsada
Chapters Timecodes from AVS
I am sure there must be easy solution to this. But I have not been able to find it. After days of googling nothing seems to be visible.
I am trying to put Chapters in my AVS scripts for final MKV output.
My script contains multiple clips (amalgamation of video clips, and pictures).
" I would like to put a Chapter start at beginning of each my clip. "
ShowSMPTE will Timecodes in video, but not to an external text file like chapters.txt.
My normal route is x264 for .264 and faac/neroAacEnc for .aac or wav(vdub) to ac3 (eac3to), to using mkvmerge for MKV with chapters.
I don't mind doing another pass on my .AVS as I am doing second pass for Audio already. This pass should create a text file compatible with mkvmerge with my specified timecodes.
Any info would be helpful.
Jay
jsada is offline   Reply With Quote
Old 26th December 2009, 04:46   #2  |  Link
MadRat
MadRat's Avatar
I'm confused about what you're trying to do but this sounds more like an MKV container issue than a avisynth issue.
MadRat is offline   Reply With Quote
Old 26th December 2009, 14:03   #3  |  Link
Gavino
Avisynth language lover
As I understand it, you want your script to create a text file containing timecode data.
Perhaps something similar to the approach in this thread will do what you want.
avs, chapter, timecode
