Old 6th September 2012, 15:44   #1  |  Link
DevilMind
Driving me Crazy! AviSource: Could not decompress frame 0 (c:\source.avs,line 1)
this error is driving me crazy on StaxRip, i'm gonna jump out of window because of frustration this is causing me
before StaxRip worked perfectely and now not even one video is encoding,
i get this error on each & every video Format i try.
i am Encoding
HDV (Vegas Pro 11)
to
Lagarith Lossless AVI then
StaxRip to MP4 (x264 2000kbpx CBR 2pass + Nero aac 128kbps CBR LC)
my log file:
                        Environment
StaxRip version: 1.1.7.2
OS Name        : Windows 7 Ultimate
OS Version     : 6.1.7600.0
OS Type        : 64-bit
OS Culture     : English (United States)
                            .NET
v2.0.50727 : 2.0.50727.4927
v3.0       : 3.0.30729.4926
v3.5       : 3.5.30729.4926
v4\Client  : 4.0.30319
v4\Full    : 4.0.30319
                   Source file MediaInfo
D:\00 UK AFA upload clips\pal66.avi
General
Complete name                            : D:\00 UK AFA upload clips\pal66.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
Format profile                           : OpenDML
File size                                : 2.15 GiB
Duration                                 : 49s 840ms
Overall bit rate                         : 370 Mbps
TCOD                                     : 149200000
TCDO                                     : 647600000
Video
Format                                   : YUV
Codec ID                                 : UYVY
Codec ID/Info                            : Uncompressed 16bpp. YUV 4:2:2 (Y sample at every pixel, U and V sampled at every second pixel horizontally on each line). A macropixel contains 2 pixels in 1 u_int32.
Bit rate                                 : 369 Mbps
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 25.000 fps
Chroma subsampling                       : 4:2:2
Compression mode                         : Lossless
Bits/(Pixel*Frame)                       : 16.000
Stream size                              : 2.14 GiB (100%)
Audio
Format                                   : PCM
Format settings, Endianness              : Little
Format settings, Sign                    : Signed
Codec ID                                 : 1
Bit rate mode                            : Constant
Bit rate                                 : 1 536 Kbps
Channel(s)                               : 2 channels
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Stream size                              : 9.13 MiB (0%)
Interleave, duration                     : 249 ms (6.23 video frames)
Interleave, preload duration             : 250 ms
               Demux AVI using VirtualDubMod
Demuxer: Demux AVI
"H:\0 DOWNLOAD MANAGER\00 Audio n Video Converters n codecs\Video Converters -2012 Aug\StaxRip_1.1.7.2\Applications\VirtualDubMod\VirtualDubMod.exe" /s"D:\00 UK AFA upload clips\pal66 temp files\pal66_Demux.vcf" /x
        DirectShow filters used to render the source
DirectSound Audio Renderer
Video Mixing Renderer
Color Space Converter
AVI Decompressor
AVI Splitter
File Source (Async.)
                    Error opening source
DirectShowSource : Timeout waiting for graph to start.
(D:\00 UK AFA upload clips\pal66 temp files\pal66_Source.avs, line 1)
DirectShowSource("%source_file%", audio=false, convertfps=true, fps=%source_framerate_mediainfo%)
Crop(0,0, -Width % 8,-Height % 8)
ConvertToYV12()
                    Index with ffmsindex
"H:\0 DOWNLOAD MANAGER\00 Audio n Video Converters n codecs\Video Converters -2012 Aug\StaxRip_1.1.7.2\Applications\AviSynth plugins\ffms2\ffmsindex.exe" "D:\00 UK AFA upload clips\pal66.avi" "D:\00 UK AFA upload clips\pal66 temp files\pal66.ffindex"
Writing index... done.
Start:    6:46:14 PM
End:      6:56:33 PM
Duration: 00:10:19
                       Source Macros
Source Directory:   D:\00 UK AFA upload clips\
Source Directory Name: 00 UK AFA upload clips
Source Directory Parent: D:\
Source File Path:   D:\00 UK AFA upload clips\pal66.avi
Source Files Blank: "D:\00 UK AFA upload clips\pal66.avi"
Source Files Comma: "D:\00 UK AFA upload clips\pal66.avi"
Source Framerate:   25.00
Source Framerate MediaInfo: 25.000
Source Frames:      1246
Source Image Height: 720
Source File Name:   pal66
Source Seconds:     50
Source Image Width: 1280
waiting for your response
DevilMind is offline   Reply With Quote
Old 6th September 2012, 16:28   #2  |  Link
poisondeathray
Looks like you forgot to choose lagarith
to
Codec ID : UYVY
Another option is debugmode frameserver (but you have to be careful with the way vegas handles levels)
Old 6th September 2012, 23:20   #3  |  Link
IanB
Avisynth Developer
For an .avi file with fourcc "UYVY", AviSource will first ask windows for a codec to decode UYVY to YV12. And if none are available next a codec to decode UYVY to YUY2, then RGB32 and RGB24. If they all fail you get the cannot find a codec message. You did not get that message so some codec put it's hand up and said "Yes I can do that." but after it was loaded and initialised and Avisynth asked for frame 0 to be decoded it reneged on the deal and said oops I cannot do that after all.
Quite a few codecs have this evil behaviour, the Panasonic DV codec is one example of being notorious for doing this for DV sources, it can actually only do RGB24 decoding. The solution there is to add Pixel_Type="RGB24". A better solution is to use a correctly working codec like Cedocide.
For your problem you can try adding AviSource(.... , Pixel_Type="YUY2") to your script, your installed bad UYVY decoder may actually be able to do that. If that fails you need to uninstall the broken codec and install a working UYVY codec. Or you could fix your work flow as above.
IanB is offline   Reply With Quote
Old 7th September 2012, 09:32   #4  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Many thank for this explanation !
This now saves me lots of headaches, because my UYVY intermediates
(which I only made to get off the faulty WinXP's DirectShow quartz.dll decodes from plain DV-AVI
were obviously decoded improperly again using AviSource which indeed seemed to have called WinXP's DirectShow quartz.dll again.
Booho.
avi, avisynth script, error, mp4, x264
