23rd September 2024, 21:11 | #681 | Link |
I dont encode movies and I'm no expert with the x265.exe settings. The best approach is always to use different settings based on the source type as you said.
I think the script default settings(line 199) are decent and in the comparisons I did, it looks transparent to the source but you might have to use higher CRF values for grainy content because the encode could end up larger than the source.
DoVi_Scripts |
27th September 2024, 17:20 | #683 | Link |
Hey Kuler, is it possible for you to confirm this HDR10+ plot is accurate?
https://i.imgur.com/mg4OTMK.png https://i.imgur.com/KSwWnY6.png I can send the json as well. Last edited by CineManiac; 27th September 2024 at 17:27. Reason: Resized images |
27th September 2024, 17:31 | #684 | Link |
Interesting, first time I've seen a static HDR10plus plot. It looks correct because it only has 1 shot/scene.
It doesn't matter since the whole movie is under 100nits.
DoVi_Scripts |
27th September 2024, 17:41 | #686 | Link |
Thank you
Did i already give you have access to my RPU collection (over 1000rpus) ? I give a link to any donors.
DoVi_Scripts |
28th September 2024, 08:39 | #687 | Link |
Hi Kuler, thank you so very much for these wonderful scripts. Thanks to you, I have been able to do my first EAC3 7.1 encode from a TrueHD Atmos 7.1 track. I have three questions or, in fact, one question asked in three different ways:
1. Is there any way in which I can get DoVi_scripts to encode to 7.1 EAC3-JOC format? 2. Is there any way in which DoVi_scripts can extract Atmos metadata from a TrueHD Atmos track and inject that back into an EAC3 7.1 encode? 3. Is it possible that DoVi_scripts's EAC3 7.1 encode already includes JOC but cannot use the name of that format because of licensing issues? Basically, I am searching for a way to encode to EAC3 7.1 with Atmos intact. Any help would be much appreciated. Thank you. |
28th September 2024, 13:53 | #688 | Link |
No, DS cannot encode EAC3 + the atmos metadata. But there's a way because I've seen other people doing it. The quality was much worse than DS 7.1 EAC3 .
DoVi_Scripts |
28th September 2024, 16:28 | #689 | Link |
Thank you for letting me know that, Kuler. There's little point in using an encoder that will produce substandard results, so I shall let go of the EAC3-JOC project for now.
Wish you all the very best with the work that you are doing on a GUI for DoVi_Scripts. |
29th September 2024, 04:51 | #690 | Link |
Failure Message
I have run into two issues:
1. Each time I encode audio with EAE in DoVi_Scripts, a second CMD window which initially flashes a sign about Dolby being a proprietary format, begins flashing this when the track is being encoded: However, the encoded audio track I get comes out just fine. Any ideas on what I might be doing wrong? 2. Another alert that I haven't been able to figure out is this, highlighted in the blue rectangle: |
29th September 2024, 13:07 | #691 | Link |
it's normal, you can ignore it.
DoVi_Scripts |
1st October 2024, 13:49 | #695 | Link |
no, you can't and even if you could, your SDR video would still be 100nits.
DoVi_Scripts |
1st October 2024, 19:28 | #696 | Link | |
https://forum.doom9.org/showthread.p...33#post2007433 |
2nd October 2024, 02:45 | #697 | Link | ||
2nd October 2024, 03:47 | #698 | Link |
DoVi_Scripts |
2nd October 2024, 12:01 | #700 | Link |
no, it cant
DoVi_Scripts |
batch scripts, dolby vision processing, dovi_scripts |
