Old 28th August 2024, 17:32   #641  |  Link
Gatorman3385
Gatorman3385's Avatar
That makes sense. Thank you.
Gatorman3385 is offline   Reply With Quote
Old 8th September 2024, 23:27   #642  |  Link
Kuler087
Kuler087's Avatar
3.0.2 released (minor changes)
https://github.com/R3S3t9999/DoVi_Scripts/releases
- (8-2) tools pack: x265.exe must be updated and old versions will no longer work.
- Plotter: added Level 9 info in L1 plot(6-3 / 6-4) and quick info (1)
- Screenshots: added an option to disable screenshot OSD in 7-1 / 7-2 / 7-3 (line 145)
- Editor: added an option to edit source_PQ (for testing only: never change it in real movies/shows)
- Default settings change: DDP EC3 encoding default is now: NO. (Line 75: set encode_DDP=NO)
DoVi_Scripts
Kuler087 is offline   Reply With Quote
Old 9th September 2024, 21:48   #643  |  Link
Hellboy.
Thanks Kuler087
Hellboy. is offline   Reply With Quote
Old 13th September 2024, 15:23   #644  |  Link
Atari1971
Script Error
Good morning. I've had problems with Dolby Vision encoding for several months. I thought the update would fix it, but I still get this error with the official Dolby script or the MadVr script...
 Generating DoVi from a MadVR measurement file...
Reading generate config file...
Parsing madVR measurement file...
Error: Le fichier spécifié est introuvable. (os error 2)
Stack backtrace:
   0: <unknown>
   1: <unknown>
   2: <unknown>
   3: <unknown>
   4: <unknown>
   5: <unknown>
   6: <unknown>
   7: <unknown>
   8: <unknown>
   9: <unknown>
  10: BaseThreadInitThunk
  11: RtlUserThreadStart
Done.
 Editing L5 (active area) to left=0, right= 0, top= 278, bottom= 278
Stack backtrace:
   0: <unknown>
   1: <unknown>
   2: <unknown>
   3: <unknown>
   4: <unknown>
   5: <unknown>
   6: <unknown>
   7: <unknown>
   8: <unknown>
   9: <unknown>
  10: <unknown>
  11: BaseThreadInitThunk
  12: RtlUserThreadStart
Appuyez sur une touche pour continuer...
Atari1971 is offline   Reply With Quote
Old 13th September 2024, 15:43   #645  |  Link
Kuler087
Kuler087's Avatar
This looks like workflow 3-2?
Did you install madVR and lavfilter? it looks like madvr failed to measure the video
DoVi_Scripts
Old 13th September 2024, 17:08   #646  |  Link
Atari1971
how to install madvr?
Old 13th September 2024, 17:28   #647  |  Link
Kuler087
Kuler087's Avatar
go in tools/madvr folder and click (with admin rights) on the install bat.
DoVi_Scripts
Old 13th September 2024, 17:33   #648  |  Link
Atari1971
Installation succeeded.
Please do not delete the madVR folder.
The installer has not copied the files anywhere
Old 13th September 2024, 21:34   #649  |  Link
Atari1971
Apparently everything is installed well. What can cause this error?
Old 13th September 2024, 22:31   #650  |  Link
Kuler087
Kuler087's Avatar
if everything were installed correctly, it would work
post the complete log of the workflow, not just part of it otherwise there's not much I can do to help you.
DoVi_Scripts
Old 14th September 2024, 08:30   #651  |  Link
Atari1971
Hello, here is the full capture of the final message...
Donate: https://www.paypal.com/donate/?hosted_button_id=6ML5KUZG9XGB6                  Date: 13/09/2024 10:33
  Contact: R3S3T_9999@proton.me                                                          Version: 3.0.2_MKV
  Tutorials: https://www.youtube.com/playlist?list=PLFGpkrmX_eOL2Dre1ZyIJP2uMtcQYH8ql
    _____    __      ___       _____           _       _
   |  __ \   \ \    / (_)     / ____|         (_)     | |
   | |  | | __\ \  / / _     | (___   ___ _ __ _ _ __ | |_ ___
   | |  | |/ _ \ \/ / | |     \___ \ / __| '__| | '_ \| __/ __|
   | |__| | (_) \  /  | |     ____) | (__| |  | | |_) | |_\__ \
   |_____/ \___/ \/   |_|    |_____/ \___|_|  |_| .__/ \__|___/
   -Author: RESET_9999--------------------------|__|-----------
1) MODE.I=  INJECT / EDIT / EXTRACT / INFO / VALIDATE
2) MODE.F=  VERIFY SYNC / REMOVER / TRANSFER LEVELS
3) MODE.H=  DoVi MAKER from HDR10 (Dolby Algo or MadVR or HDR10+)
4) MODE.7=  DoVi Profile 7 Input (MKV/BDMV)
5) MODE.B=  DoVi MKV Batch Muxer
6) MODE.P=  Plotter (DoVi/HDR10/HLG/SDR)
7) MODE.S=  Screenshots & Player
8) MODE.E=  Encoders (video and audio)
9) MODE.M=  MORE
Choice? [1,2,3,4,5,6,7,8,9]?3
       -   SELECT A WORKFLOW   -
1) Workflow.1= CM_analyzer HDR10 to DoVi maker (can batch) (Professional CM v4.0 Dolby Algo)
2) Workflow.2= Convert HDR10plus videos to DoVi (can batch) (Not Recommended)
3) Workflow.3= Back to main menu
Choice? [1,2,3]?2
-- NOT RECOMMENDED: you'll get better DV if you use 3-1.
-- See: https://drive.google.com/file/d/1IXR60nWe2Ylb7CTRjZ3_tpI5RsAajU5G/view?usp=drive_link
-- This script will batch convert HDR10plus or HDR10 video to DoVi with dynamic metadata or madVR
-- Can use external L5 json if filepath/name is the same as the BL input
-- 10/100nits floor can be removed at line 169
Drag and drop folder with files or a single file and press enter...
D:\revenant_HDR-1000nits-HEVC_TEKNO3DConverter.mkv
Auto or Manual Active Area L5 edit... a or m ?  and press enter...
a
processing..."revenant_HDR-1000nits-HEVC_TEKNO3DConverter.mkv"
Measuring letterbox of "D:\revenant_HDR-1000nits-HEVC_TEKNO3DConverter.mkv"
left border: 0
right border: 0
top border: 278
bottom border: 278
Reading input tracks format/id/language...
Done.
       -    DEMUXING     -
Extracting track 0 with the CodecID 'V_MPEGH/ISO/HEVC' to the file 'F:\DoVi_Scripts\temp.folder34\hdr.hevc'. Container format: HEVC/H.265 elementary stream
Extracting track 1 with the CodecID 'A_DTS' to the file 'F:\DoVi_Scripts\temp.folder34\revenant_HDR-1000nits-HEVC_TEKNO3DConverter.track_2_fre.dts'. Container format: Digital Theater System (DTS)
Progress: 100%
LAV Splitter Source not found.
Stack backtrace:
   0: <unknown>
   1: <unknown>
   2: <unknown>
   3: <unknown>
   4: <unknown>
   5: <unknown>
   6: <unknown>
   7: <unknown>
   8: <unknown>
   9: <unknown>
Done.
Stack backtrace:
   0: <unknown>
   1: <unknown>
   2: <unknown>
   3: <unknown>
   4: <unknown>
   5: <unknown>
   6: <unknown>
   7: <unknown>
   8: <unknown>
   9: <unknown>
  10: <unknown>
Done.
Stack backtrace:
   0: <unknown>
   1: <unknown>
   2: <unknown>
   3: <unknown>
   4: <unknown>
   5: <unknown>
   6: <unknown>
   7: <unknown>
   8: <unknown>
   9: <unknown>
  10: <unknown>
 Editing L6 to MDL=1000/1,  MaxCLL/FALL=0/0
Stack backtrace:
   0: <unknown>
   1: <unknown>
   2: <unknown>
   3: <unknown>
   4: <unknown>
   5: <unknown>
   6: <unknown>
   7: <unknown>
   8: <unknown>
   9: <unknown>
  10: <unknown>
Old 14th September 2024, 10:19   #652  |  Link
Kuler087
Kuler087's Avatar
Lab filter is not installed or misconfigured
DoVi_Scripts
Old 14th September 2024, 10:30   #653  |  Link
Atari1971
Lav Splitter is installed
Old 14th September 2024, 10:37   #654  |  Link
Atari1971
What is the configuration of Lav Splitter? Lav Audio, video and splitter are installed.
Old 14th September 2024, 14:43   #655  |  Link
Kuler087
Kuler087's Avatar
all shown in the tutorial installation video but it depends on your hardware.
here's mine:
DoVi_Scripts
Old 14th September 2024, 14:58   #656  |  Link
Atari1971
I try it
Old 14th September 2024, 15:34   #657  |  Link
Atari1971
same error...
Old 14th September 2024, 15:51   #658  |  Link
Atari1971
My configuration:
Old 14th September 2024, 15:55   #659  |  Link
Kuler087
Kuler087's Avatar
Well, I dont know but the issue is on your end. Try the nightly lav filters
DoVi_Scripts
Old 14th September 2024, 16:10   #660  |  Link
Atari1971
I also have the teckno3D app. Can this play a role?
batch scripts, dolby vision processing, dovi_scripts
