Old 13th February 2024, 14:40   #1  |  Link
Kuler087
Kuler087's Avatar
[DoVi_Scripts] Multi-Function Scripts for Dolby Vision processing and a lot more...
Drag-and-drop batch scripts designed for effortless management of HDR/Dolby Vision files,
ensuring a user-friendly and easy-to-use experience.
https://github.com/R3S3t9999/DoVi_Scripts
Installation tutorial for newbies: https://www.youtube.com/watch?v=6SLtsVDse2w
MUXING BEHAVIOR AND SCRIPT FOLDER:
The script's behavior for muxing (MKV, MP4, or TS) is determined by the filename of the .bat file. If you decide to remove these tags, the default muxing mode will be MKV but muxing can be completely disabled at line 55
I advise against using the script on your OS drive as it may result in certain functions being disabled or not functioning correctly. Furthermore, remuxing large files will slowdown the Windows operating system.
The script default settings can be edited if you open the bat file in Notepad++
To ensure optimal performance, make sure that your path and script folder (containing both tools and the .bat file) adhere to the following format: It's preferable not to include special characters or spaces in the path.
DO NOT LAUNCH THE BAT FILE WITH ADMIN RIGHTS, DRAG AND DROP WILL NOT WORK!
SCRIPTS MODES
MODE.I (1) =
INJECTOR/INJECTOR/EDITOR/EXTRACTOR
MODE.F (2) =
REMOVER/TRANSFER
  • Can verify the dynamic metadata (DV/HDR10plus) synchronization with the base layer.
  • see tutorial: https://www.youtube.com/watch?v=lIO_ZfT-LnY
  • Can overwrite/remove Level 2 trims
  • can transfer any metadata level to another rpu
  • can transfer scene cuts from one rpu to another
  • Can remove hdr10plus or DV
MODE.H (3) =
GENERATOR
  • Can convert any HDR10plus/HDR10/HLG source to shot-by-shot or frame-by-frame DoVi. CMV4.0 metadata, no fake static crap
  • Official Dolby cm_analyze.exe (best) or hdr10plus to dv or madvr to dv
  • see batch generate DV tutorial: https://www.youtube.com/watch?v=jBqbG5XM54g
  • can input external shot list
  • L1 analysis can be tuned (line 95)
  • Support DV-P5 / HDR10 / HLG input
  • can batch generate DV with external files for L5/ MD, and original shot list
  • Shot list source is selected in this order:
1- any external file with the same filename as the input (rpu, json, text)
2- internal RPU (in case of original rpu that has no shot, add ''IGNORERPU'' in the input filename.)
3- internal hdr10plus
4- if no dynamic metadata is found, it uses madvr to generate a shot list
MODE.7 (4) =
PROFILE 7
  • Can process any Profile 7 source(BD or Rip) to Single-layer Profile 8 or Profile 7 single-track dual-layers.
see tutorial: https://www.youtube.com/watch?v=sBUL2gjhqEE
MODE.B (5) =
BATCH MUXER
  • Can batch mux any DV source to TS or MP4
  • MKV/MP4 to TS
  • MKV/TS to MP4
MODE.P (6) =
PLOTTER
  • Can batch plot DoVi Level 1,2,3,4,5,6,8 and hdr10, hdr10plus, HLG, P5BL, video bitrate
EXAMPLES
see tutorial: https://www.youtube.com/watch?v=KHXvjtHNdB8
MODE.S (7) =
SCREENSHOTS
  • can export 16bits RGB real HDR screenshots (FEL P5 HDR10 HLG SDR) fully automated frame accurate or manual modes
    see tutorial: https://www.youtube.com/watch?v=ElJ1KvQMgzE
  • can play FEL + BL or Profile 5 DV in HDR10 or SDR with madVR+MPC (if your pc can handle it)
  • can export HDR heatmap and gamut visualization (FEL P5 HDR10 HLG SDR)
  • can tonemap to SDR or PQ (line 129, default = PQ)
EXAMPLES
frame-accurate screenshot maker tutorial: https://www.youtube.com/watch?v=SA-i1tZssIo
MANUAL SCREENSHOT EXAMPLE
MODE.E (8) =
VIDEO/AUDIO ENCODERS
MODE.M (9) =
MIXED
  • Can fix video framerate bitstream, color range
  • Can automatically find frame difference between two sources
  • can find bd playlist
  • can make 5 min samples. timestamp configurable at line: 109
  • can quickly find a video framecount (useful when creating a shotlist in 3-1)
  • Can tonemap pgs subtitles to different brightness
DIRECT MODE
  • drag and drop a file on the bat file and it will use workflow 1
  • the bat file can be associated with any video/rpu file.
L5 active area and cropping:
  • if the base layer is 16:9 (no black bars, fullscreen): set L5 to 0
  • if the base layer is 16:9 but has black bars: measure the BL letterbox and adjust L5 accordingly.
  • if the base layer is cropped set L5 to 0
Example 1:
input= 3840x2160p with active area of 2.40 (16:9 with black bars)
L5 offsets= Left:0 Right:0 Top:280 Bottom:280
Example 2:
input= 3840x2160p with active area of 1.78 (16:9 no black bars)
L5 offsets= Left:0 Right:0 Top:0 Bottom:0
Example 3:
input= 3840x1600p (cropped)
Downscaling and upscaling:
divide or double the L5 values.
Example:
input 3840x2160 with L5 0,0,280,280
output 1920x1080 with L5 0,0,140,140
Input filename keywords that override the script's main settings:
  • DONTUPSCALE : Keep original resolution in 7-2
  • KEEPAUDIO : Keep all the audio
  • DONTMUX : Disable muxing
  • IGNORERPU : Ignore internal rpu for shot list in 3-1
  • REMOVECMV4 : Force CMV4.0 removal in 1-1
  • KEEPPRORES : Keep prores file
  • FORCESDR : Force SDR tonemapping in 7-1 7-2
  • KEEPTRIMS : keep trims in XML injection for 1-1 and 3-1
  • KEEP1000 : keep 1000nits trims in XML injection for 1-1 and 3-1
  • KEEP600 : keep 600nits trims in XML injection for 1-1 and 3-1
  • JUSTINJECT : Inject without changing the DV profile in 1-1
  • FORCEHDR10PLUS: force hdr10plus scene cut extract when input has dv for workflow 2-3
DoVi_Scripts
Kuler087 is offline   Reply With Quote
Old 13th February 2024, 17:21   #2  |  Link
TDS
Formally known as .......
TDS's Avatar
Are you affiliated with RESET ??
'Cause this is straight off his Github page ??
Great set of tools, this !!!!
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 13th February 2024, 17:53   #3  |  Link
Kuler087
Kuler087's Avatar
Yes, I'm RESET_9999
DoVi_Scripts
Old 13th February 2024, 21:10   #4  |  Link
speedy
@RESET, do you have access to a S922X-J chipset device (Ugoos AM6B+) and/or have any intention of testing one?
speedy is offline   Reply With Quote
Old 13th February 2024, 21:25   #5  |  Link
Kuler087
Kuler087's Avatar
No, I use the Sony x800m2 for FEL playback.
The new CoreElec build for the Ugoos looks interesting though. I will let other people test FEL playback a bit more but if it's really 100% stable, I might get one.
DoVi_Scripts
Old 14th February 2024, 03:53   #6  |  Link
TDS
TDS's Avatar
OK, Reset,
Here's that error I mentioned in the email.
I'm using 8-2-1, and it gets thru most of the process then this:-
libavutil      58. 36.100 / 58. 36.100
  libavcodec     60. 36.100 / 60. 36.100
  libavformat    60. 20.100 / 60. 20.100
  libavdevice    60.  4.100 / 60.  4.100
  libavfilter     9. 16.100 /  9. 16.100
  libswscale      7.  6.100 /  7.  6.100
  libswresample   4. 13.100 /  4. 13.100
  libpostproc    57.  4.100 / 57.  4.100
Unrecognized option 'vbsf'.
Error splitting the argument list: Option not found
Error: No frames parsed!
Error: No RPU found
D:\Dovi_Encodes_MP4>"D:\DoVi_Scripts\tools\NVEncC\NVEncC64.exe" --vbr 50000 --codec h265 --multipass 2pass-full --preset P7 --output-depth 10 --profile main10 --max-bitrate 160000 --vbv-bufsize 160000 --colormatrix bt2020nc
 --colorprim bt2020 --transfer smpte2084 --colorrange limited --chromaloc 2 --aud --repeat-headers --master-display "G(8500,39850)B(6550,2300)R(35400,14600)WP(15635,16450)L(10000000,1)" --max-cll "0,0" --dolby-vision-profile 8.1
 --dolby-vision-rpu "D:\Dovi_Temp_MP4\temp.folder49\P8.RPU.bin" -i "D:\Dovi_Temp_MP4\temp.folder49\script.avs" -o "D:\Dovi_Encodes_MP4\removed file name.S01.E01.2010.2160p.HDR.UHD.BluRay.DD5.1.x265-10bit-HDS-001_DV_encoded.hevc"
Failed to open dovi rpu "D:\Dovi_Temp_MP4\temp.folder49\P8.RPU.bin".
Failed to open input file.
D:\Dovi_Encodes_MP4>echo off   & goto :end
The script has been completed. Do you want to quit or go back to main menu (q or m default=q)?
This is a 10 minute chunk that I just converted to DV, and I thought I'd try 8-2-1.
Is it simply something I have missed installing, etc, or ??
I'm running an RTX 3050 GPU, BTW.
Old 14th February 2024, 04:26   #7  |  Link
Kuler087
Kuler087's Avatar
it looks like ffmpeg didnt like the ''vbsf'' parameter. Are you using the version included in the pack or your own version?
DoVi_Scripts
Old 14th February 2024, 04:31   #8  |  Link
TDS
TDS's Avatar
Originally Posted by Kuler087 View Post
It looks like the script thinks your input has DV but it doesn't?
input mediainfo or a sample please
converted file info (input):-
Format profile                           : Main 10@L6.1@High
HDR format                               : Dolby Vision, Version 1.0, Profile 8.0, dvhe.08.06, BL+RPU / SMPTE ST 2086, Version HDR10, HDR10 compatible
Codec ID                                 : dvhe
Codec ID/Info                            : High Efficiency Video Coding with Dolby Vision
original file info:-
HDR format                               : SMPTE ST 2086, HDR10 compatible
Like I said, I had just converted it to DV with 3-1.
Old 14th February 2024, 04:34   #9  |  Link
Kuler087
Kuler087's Avatar
sorry i edited my original response after realizing that the problem was a parameter in ffmpeg.
it looks like -vbsf is now deprecated and replaced by -bsf:v
either use the version in the tools pack or wait for the script's next version.
DoVi_Scripts
Old 14th February 2024, 05:07   #10  |  Link
TDS
TDS's Avatar
Interesting you mention that, 'cause that is what Google found
Cheers.
Update:- I changed it back to the version in the tools pack, and it looked like a different process, and NO errors...I think it was using NVencC, but MediaInfo doesn't show anything about it.
Update #2:-So I took a chance and changed all the -vbsf entries to -bsf:v, and using the latest FFmpeg, I didn't get any errors, so hopefully the process & encodes will be good to go.
Thanks
Old 14th February 2024, 11:52   #11  |  Link
Atlantis
Please could someone explain for us casual users the difference between this and DDVT Tool? Do they do the same thing?
Atlantis is offline   Reply With Quote
Old 14th February 2024, 12:04   #12  |  Link
TDS
TDS's Avatar
In my humble opinion, DDVT does do the same thing, sort of.
I think it is a little harder to use the scripts, needing a cmd prompt, and copying the paths of the script & the file you want to process.
DoVi_Scripts is just a multi option menu, and you just choose the functions menu number, then simply drag the file you want to process, then there may or may not be a few more option you need to choose, then basically it does the rest itself.
But it also does a LOT of other conversions, etc, etc.
Makes a lot of other apps look pretty basic and lacking, in comparison.
It's a little involved to initially set it up, but then you're set.
Old 18th February 2024, 12:55   #13  |  Link
DaMacFunkin
avs libplacebo error
Hi, Updated to your latest pack, I am trying HDR to HDR DoviBake and I get this error (see screenshot), yet the file is present, can you advise please?
DaMacFunkin is offline   Reply With Quote
Old 18th February 2024, 14:01   #14  |  Link
Kuler087
Kuler087's Avatar
Does the FEL script work when you play it avspmod? Do you have an Nvidia GPU ?
DoVi_Scripts
Old 18th February 2024, 17:17   #15  |  Link
DaMacFunkin
Hi, yes I have a Nvidia GPU that’s why I edited the config to use this.
Not sure what you mean by avspmod, please explain,
I encode HDR with Nvenc and Staxrip all the time so I’m not sure what is wrong?
Old 18th February 2024, 17:34   #16  |  Link
DaMacFunkin
Just tried to play the AB’s file with avspmod and it says invalid argument, the avs does play with media player classic, how do I fix this please?
Old 18th February 2024, 17:40   #17  |  Link
Kuler087
Kuler087's Avatar
I mean have you checked if the dovi_baker script works in avspmod?
Go into the temp folder and try to open the Avisynth script or create a new script with workflow 7-1 (manual mode)
Also, any error in the dovi_scripts window?
DoVi_Scripts
Old 18th February 2024, 17:41   #18  |  Link
Kuler087
Kuler087's Avatar
Did you install avisynthplus?? if yes maybe try to reinstall it:
https://github.com/AviSynth/AviSynth...3_20230715.exe
DoVi_Scripts
Old 19th February 2024, 00:29   #19  |  Link
DaMacFunkin
Hi, I uninstalled my old version of Avisynth and installed this one, I feel like I've spent all day on it, but now all of a sudden it is encoding, not very fast @ 9fps on --quality --vbr --2pass-full.
Has anybody been able to use --lookahead32 and --vbr-quality 19 with Dovibaker and Nvenc instead of 2 pass??
Thank you.
Old 19th February 2024, 05:00   #20  |  Link
TDS
TDS's Avatar
Thank you.
AFAIK, you should be able to edit the NVenc_HDR_settings.bat (found in the Tools folder) to your hearts content.
I made a couple of changes to my liking the other day.
This may also be handy, to some:-
https://github.com/rigaya/NVEnc/blob...c-option-list-
batch scripts, dolby vision processing, dovi_scripts
