19th September 2019, 08:43 | #802 | Link | |
OCR is performed OUTSIDE of this software, and if one half of the users require a -dash before the first line of dialogue and the other half require exactly the opposite, and this goes on and on for the aforementioned period of time, well, ...
Born in the USB (not USA) |
20th September 2019, 21:08 | #803 | Link |
@Matt: Atm, if the duration is longer than "max duration" in settings, then SE just set the duration to 3,5 secs - just changed the code to use "max duration" instead of 3,5 seconds - but perhaps it would be better to just let the user fix that afterwards?
You can set the "max duration" to something large like 20 seconds to allow long duration. @Ghitulescu: Most changes to SE are from people asking for product enhancements, but I do really try to be careful about what features I add - and I don't want to add everything to SE (like advanced ASS features as we already have Aegisub for that or features that will have very few users). SE focuses on creating/adjusting/fixing/reviewing text subtitles and ocr'ing/converting + translating - the last one is ever changing . New subtitle formats are also very important (like new stuff from Amazon, Netflix or w3c). In the last five years many improvements has been made in reading bitmap formats from mp4/ts/m2ts/bdsup and converting between/to bitmap based formats - read more here: https://raw.githubusercontent.com/Su.../Changelog.txt What was your original request by the way? |
23rd September 2019, 10:51 | #805 | Link |
I kindly asked for a possibility to change the colours (maps) of the SUP, sort of what DVDSubEdit did for DVD. Essentially, I need to get rif of the stupid black box surrounding the text, to make it transparent.
2nd October 2019, 21:35 | #807 | Link |
I don't know how to cut full streams comprising subtitles (and to keep them in), therefore I needed 3 days to delete 2000 images one-by-one in order to fit the 200kB limit of doom9:
8th October 2019, 06:53 | #810 | Link |
@Ghitulescu: Perhaps you can use some file host for the sample file or email it to me?
In Bluray sup files each subtitle have it's own palette (up to 255 colors), and vobsub normally has a global 4 color palette. |
8th October 2019, 14:58 | #811 | Link | |
nevertheless it's easy to find out the background color index entry.
11th October 2019, 06:04 | #814 | Link |
@Ghitulescu: Sorry, the attached subtitle is pretty impossible to do anything about... sometimes the text is completely transparent and sometimes the text is just as transparent as the box.
@Verminaard: Could you give some examples? Speaker dashes should be added sometimes... |
11th October 2019, 09:22 | #815 | Link |
I opened the non hearing impaired subtitles from the new Breaking Bad movie, and it didn't find any common errors.
This is the first time I see an original subtitle in which Subtitle Edit doesn't find any common errors. I was appalled. Did they, by any chance, used Subtitle Edit for the subtitles? Last edited by nekrovski; 11th October 2019 at 09:25. |
11th October 2019, 09:38 | #816 | Link |
@nekrovski: that may be possible: https://partnerhelp.netflixstudios.c...-Subtitle-Edit
11th October 2019, 22:23 | #818 | Link |
@nikse55
I will send you a link for an example file later. But logically, a function called "Remove" should not be adding something now should it Fix subtitles on the other hand has an option to add dashes. But in my case they're unchecked. Thanks for responding. Last edited by Verminaard; 11th October 2019 at 22:26. |
14th October 2019, 22:36 | #819 | Link |
I have the same problem as Verminaard.
But, after some testing, I think I found something. The tool may have an issue when text for hearing impaired are BOTH italic AND in double lines. I created a little .srt file (attachment) that should explain. |
17th October 2019, 20:57 | #820 | Link | |
"Export -> BDN xml/png" --> Export all instead of presenting Desktop as default export directory, to use the current location of the idx/sub or sup file ? That would be a big time saver. Thanks for your great job! |
