#1042 | Link |
Perhaps it has been already discussed, but I cannot solve the following problem. I have a hybrid MKV video (DV + HDR10) 3840X1608. My old LG C8 shows the file in HDR10 with black bars - all OK. So to play DV, I converted the file into m2ts - now my LG shows it in DV, all OK, BUT the top & bottom bars are no longer black, they are grayish.
So I extracted the RPU & adjusted the top/bottom borders manually to 276 & injected them back into the video. Nothing changed - the bars are still not black, but grey. Is there a solution? Please help. Forgot to mention: I play the video with OPPO clone BTW Great tool! Many thanks!! |
#1043 | Link | |
Can you send me the name of the app please? I too struggle with my older LG TV |
#1045 | Link | |
Converting MKV to M2TS works fine for me for files 3840x2160. If the video stream is "thinner" (like 3840X1600) then I get grey (not black) bars - this is very annoying if watching in a dark room. I understand that it is happening because DV metadata is not limited just to the video size, it is applied to the whole screen. I want to find a way to change this |
#1046 | Link | |
Hey, I have a question about your post. I sent you a private message about this. I would appreciate an answer! Thx. |
#1047 | Link | ||
QfG Group Germany
#1049 | Link |
Hi all,
I get below errors when using HYBRID script. Last version without this errors is 0.64.2. There are no errors with exact same video files in DEMUXER or INJECTOR -> It demux and inject without any issues and final video file is OK. It occurs with every video file, when i try to use HYBRID script. Source video file for demuxing has both RPU and HDR10+ .json as well. Where should be the problem or what should i try to set up/change on my side? OS: Win 11 Pro, 24H2 Thank you very much. Excellent tool
#1050 | Link |
QfG Group Germany
@pejok Problem fixed, please download this file and overwrite the hybrid script with this file:
https://github.com/DonaldFaQ/DDVT/bl...DVT_HYBRID.cmd
#1051 | Link |
@-QfG- thank you, no errors so far
but maybe last bug as i noticed is, while testing and trying to do hybrid with HDR10 only file + DV&HDR10+ file:- tool correctly fetch all info about the files - i have set also to inject HDR10+ - start the script -> DV extracted -> HDR10+ -> Scenecuts fixed -> DV injected -> muxing final video file - injecting of HDR10+ completely ignored - final video file contains DV + HDR10 only (not HDR10+) |
#1052 | Link |
QfG Group Germany
You're right, sorry forgot to process this switch. Fixed now, simply update the script.
#1054 | Link | |
#1055 | Link | |
Is it recommended to download the latest scripts from your github site and unzip them into the folder containing the full DDVT package, overwriting the original scripts from the Mega download? I see that 65.2 is the latest on Mega but the github scripts are showing as 65.3. Are there any gotchas like needing updates to other apps in the Tools folder? For all: I am experiencing a related issue - drag 'n drop is no longer working on the main Win 11 PC I use to run these scripts. A Win 11 VM running the same Win version does still work. I've been trying various recommended solutions (13 of them so far) but all I've managed is being able to drag 'n drop ONLY to the Desktop. Not to open apps/windows/websites with a drag 'n drop function. Plus I can only drag to the sides or bottom, not up past the explorer window title bar - that just drops the item being dragged just like pressing the ESC key while dragging. If anyone else has experienced this and fixed it, I'd be grateful if you shared your solution. Right now it's looking like a full Win re-install, which I'm reluctant to do. I can still use cut & paste to 'drop' the source files into the scripts, but drag 'n drop is preferred. Last edited by AgentXXL; 2nd February 2025 at 23:46. Reason: Removed mention of github descriptions - they're OK - my bad! |
#1056 | Link |
Big Bit Savings Now !
Maybe this helps, Ramesh Srinivasans fix helped on my Win10 too:
https://www.winhelponline.com/blog/d...file-explorer/
#1057 | Link | |
I'm going to try removing the shell extensions for DDVT and clearing the registry of any DDVT specific keys. And then I'll try a fresh folder with the latest package and retry adding the shell extensions. If that fails, I'm going to reluctantly do the full fresh Win install. Last edited by AgentXXL; 3rd February 2025 at 22:14. |
#1058 | Link | |
@-QfG-, sorry I am quite new here, but can we have updating version (currently it is 0.65.3 if I am correct).
I have tried to ddvt_demuxer to demux RPU.bin and HDR10+.json and then use ddvt_injector to inject these two into a compressed 4k film, but I kept constantly receiving error message on Editing Video HDR Metadata and Muxing test into MKV Container. I honestly did not meet these issues on 0.64.x; however, I could not find previous versions on GITHUB database. So whether you can provide previous version or possibly update version will be fine, hope it is not too much request for you, thanks!! Here are the latest result of message as follows, Quote:
#1059 | Link | |
I've done this and so far it's working great. And once you use the Profile 8 Hybrid script with drag 'n drop support, you're unlikely to need the other scripts very often. |
#1060 | Link |
New as I am to Dolby Vision, I would appreciate an answer to what is presumably the most elementary question of all:
In Dolby Vision encodes in which the EL is excluded and only the RPU injected, does that RPU do any work at all without the FEL/MEL? I'm sure an answer is hidden somewhere in this forum, but I haven't been able to find it and it would be great if you could please post a link or point me to the page. Thank you. The second question is a little more elaborate so I shall post that in a separate message below. Last edited by lemaireus; 24th February 2025 at 13:59. |
| Thread Tools | |
| Display Modes | |
