Thread Tools Display Modes
Old 31st December 2024, 08:05   #1001  |  Link
GodzilaAvenger
GodzilaAvenger's Avatar
Originally Posted by Fuso View Post
I know that. But my output has HDR10 as a base layer.
Are you sure that the DV is played and interpreted correcrly? Because as QfG said a P5 RPU is not compatible with a BT.2020 (HDR10) base layer. You can inject the RPU into the base layer but the result would be all mangled up as far as brightness and color accuracy are concerned.
What happens if you convert the P5 RPU to a P8 RPU using dovi_tool and inject that into the base layer? Can you spot any differences?
GodzilaAvenger is offline   Reply With Quote
Old 31st December 2024, 11:21   #1002  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Here, I will upload it.
Microsoft 'Windows Security' has detected a virus...
Old 2nd January 2025, 17:25   #1003  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
HDR format                  : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                    : hev1
HDR10 layers and P5 RPUs incompatible. Why not simply transform Profile 5 from RPU to Profile 8 and mux this correct RPU into HDR10 stream?
Also the mp4muxer.exe from @Fuso is clean, false positives from Windows Security:
https://www.virustotal.com/gui/file/...49b4d1da47d1b3
That says Dolby Laboratories, not QfG
https://professionalsupport.dolby.co...language=en_US
page 13
For profile 5:
• VUI information is optional for a profile 5 bitstream. If VUI are present, as of this specification, there
are two options that may be used: 1,2,2,2,0 and 1,9,16,15,0. The values of 2 are compliant with the
VUI definition in ITU-T H.265, where the 2s represent unspecified.
• Within the Dolby Vision context, a profile 5 bitstream must use perceptual quantization with reshaping
for the transfer characteristic, even if setting the transfer characteristic value to 16, uses Dolby Vision
previously proprietary IPT color space (now known as IPT-PQ-C2) for color primaries, uses full range
for range, and, by default, uses center-left siting for chroma sample location.
As defined in SMPTE ST 2128:2023, IPT-PQ-C2, previously a Dolby Vision proprietary color space, is
similar to BT.2100 ICtCp, where I is similar to I, P similar to Cp, and T similar to Ct
. As of the date of this
specification, the MPEG Joint Video Experts Team (JVET) working group has standardized the code
point for this previously proprietary color space, also known as IPT-PQ-C2, using code point 15
btw. little bugfix in DDVT:
-v0.64.3a
*FIXED Problems with files that contains "()" in filename.
-QfG- is offline   Reply With Quote
Old 2nd January 2025, 21:23   #1004  |  Link
matey
can anyone who had downloaded the mp4muxer from @fuso please let me know which version it is, i will be needed the linux arm64 version so I want to look for & download that version. thanks
matey is offline   Reply With Quote
Old 4th January 2025, 20:33   #1005  |  Link
Fuso
MP4muxer version: v1.3.3 (build: Aug 6 2023)
The RPU is P8, I think the files that I "produce" are the so called "fake profile 5".
The source MKV has this info:
Video
Format                      : HEVC
Format/Info                 : High Efficiency Video Coding
Format profile              : Main 10@L5@Main
HDR format                  : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID                    : V_MPEGH/ISO/HEVC
1. I demux the video and the audio with tsmuxer.
2. The extracted .hevc and .ec3 files I mux with the following line:
mp4muxer --dv-profile 5 --input-file 1.hevc --input-video-frame-rate 24000/1001 --input-file 1.ec3 --media-lang eng --output-file MOVIE.mp4
pause
The ouptut MOVIE.mp4 looks like that:
Video
Format                      : HEVC
HDR format                  : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID                    : dvhe
Codec ID/Info               : High Efficiency Video Coding with Dolby Vision
3. And since files with Codec ID: dvhe can't be playes on a Samsung TVs (I haven't tested other brands), I rename the MOVIE.mp4 to MOVIE.mkv and then use the QfG's script DDVT_MKVTOMP4
 powered by quietvoids tools        Copyright (c) 2021-2024 QfG
                                             Dolby Vision Tool MKVtoMP4
 == VIDEO INPUT =========================================================================================================
Filename   = [MOVIE.mkv]
Video Info = [Resolution = 3840x1600] [Codec = HEVC-10Bit-YUV-4:2:0] [Frames = 199736] [FPS = 23.976]
HDR Info   = [HDR, HDR10+, Dolby Vision Profile 5]
HDR10+ Metadata found.
Dolby Vision Profile 5 found.
Be sure that there no picture based subtitles in your MKV file (PGS or VobSub)
Only textbased subtitles supported.
Please check your Audio Codec and the MP4 specifications. You can switch the
Audio Codec if the source is not compatible with MP4 container.
 == MENU ================================================================================================================
1. Audio Codec                    : [Untouched]
S. START
Change Settings and press [S] to start Converting
Select a Letter 1,[S]tart
and the final ouput MOVIE.mp4:
Video
Format                      : HEVC
Codec ID                    : hev1
I did try to mux directly to Codec ID: hev1 at step 2, but it didn't work with one of the following (or both) - --dv-bl-compatible-id, --hvc1flag.
I've asked many times before not only on this forum but no one could give me a solution for playing HDR10/HDR10+/DoVi hybrid files on both Samsung and LG (old and new). The whole shenanigans is needed because the old LGs can't play DoVi Profile 8 with Codec ID: hev1, it plays in regular HDR. But when the file is DoVi Profile 5 with Codec ID: hev1 it plays in Dolby Vision, and the same file plays on Samsung TV in HDR10/HDR10+, and if video is real Profile 5 will play in green and purple colors.
So I figured out for myself and so far I haven't noticed anything wrong when playing on all of the TVs.
Fuso is offline   Reply With Quote
Old 4th January 2025, 23:18   #1006  |  Link
GodzilaAvenger
That's really interesting, thanks for sharing!
Old 5th January 2025, 04:09   #1007  |  Link
skydalimit
I've got a Hybrid MP4 movie that contains HDR + DV Profile 7. I need to convert the DV to Profile 8 (keeping HDR). Do I use the Hybrid Script and add the same file twice, or do I need to use the Demuxer script and do extra steps?
skydalimit is offline   Reply With Quote
Old 5th January 2025, 11:35   #1008  |  Link
cool advertise
cool advertise's Avatar
@-QfG-
Bug (v0.64.3b).
If you try to demux with DDVT_DEMUXER, the single Enhancement Layer of a dolby vision profile 7, and want to convert it to profile 8 (cropping it) you will not get the rpu, but an error.
In previous versions it worked, but now it doesn't.
cool advertise is offline   Reply With Quote
Old 5th January 2025, 23:50   #1009  |  Link
mikeq
Hidef Junkie
Question about the various MaxCLLs
So if I look at Jaws remux
MaxCLL in MediaInfo is 1000,259
and from the RPU summary:
RPU content Light Level (L1) is 9977,251
L6 Metadata is 4001,597
Why are these numbers all different?
mikeq is offline   Reply With Quote
Old 6th January 2025, 18:15   #1010  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
-v0.64.3c
*FIXED Errors in demuxing combinations in DEMUXER script.
*FIXED Some errors in MediaInfo with DL files.
*FIXED L6 Error (L6 SWITCH) in Injector script.
*FIXED If changing FPS with Injector and EL is input, FPS from EL changed, too.
*ADDED Option in Injector script for writing RPU L6 Data as HDR bitstream data.
*Minor Bugfixes.
Bug (v0.64.3b).
Thanks, fixed in 0.64.3c
Old 6th January 2025, 18:44   #1011  |  Link
cool advertise
Bug (v0.64.3b).
I just tried version 0.64.3c but the bug I described is still there.
I get an error instead of rpu.
Old 6th January 2025, 19:54   #1012  |  Link
matey
Video
Format                      : HEVC
pause
Video
Format                      : HEVC
Codec ID                    : dvhe
S. START
Video
Format                      : HEVC
Codec ID                    : hev1
thanks for the detailed reply @fuso
just 1 clarification - for playing on old & new LG (2018 & 2023 models) the mp4 got after step 2 is enough to play in DV, right? the additional 2 steps you are doing is only for samsung tv's to play in HDR, correct?
Old 6th January 2025, 22:05   #1013  |  Link
Fuso
If you just want to play DoVi on both old and new models LG only, there's no need for my method. Profile 8 DoVi mp4 with Codec ID set to dvhe is enough. And it's also the official way which meets the Dolby standarts.
@QfG is it possible to implement my way into the script of the DDVT_MKVTOMP4? You can add it to be set as an option [NO/YES] - something like Fake Profile 5 with explanation and also clarify that is expiremental.
I don't know if I'm the only one that needs this but it will be much easier to just convert MKV with HDR10/DoVi P8 to MP4 with HDR10/DoVi "P5" with Codec ID: hev1.
Also can you add an option to select the Codec ID - hev1 or dvhe for P8 mp4? That is what @matey needs in his case I think...
Old 6th January 2025, 22:09   #1014  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Yes, i can add in the next update a "Fake P5 Switch". That's no problem
The target file must have - DV Profile 5 Tag (but contains P8) / hev1 instead dvhe / mp4 container, correct?
Originally Posted by cool advertise View Post
Bug (v0.64.3b).
Have you this entries in line 1166?
:RPU_EXTRACT
if "!ELSTREAM!"=="" (
	set "ELSTREAM=!INPUTSTREAM!"
	%WHITE%
	echo  == DEMUXING ============================================================================================================
	echo.
%CYAN%
echo Please wait. Demuxing DV Reference Processing Unit...
%WHITE%
"!DO_VI_TOOLpath!" %CROPSTRING% %CONVERTSTRING% extract-rpu "!ELSTREAM!" -o "!TARGET_FOLDER!\%INPUTFILENAMEO%_[RPU].bin"
if exist "!TARGET_FOLDER!\%INPUTFILENAMEO%_[RPU].bin" (
	%GREEN%
	echo Done.
	echo.
) else (
	%RED%
	echo Error.
	set "ERRORCOUNT=1"
	echo.
goto :eof
if not, please reload the tool.
Old 6th January 2025, 23:15   #1015  |  Link
Fuso
Yes. The ouput mp4 file must look like this:
Video
Codec ID                    : hev1
Old 7th January 2025, 03:52   #1016  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
-v0.64.3d
*ADDED Function in MKVtoMP4 script for creating "fake" Profile 5 files.
Function is only available if input file is Profile 8.
Old 7th January 2025, 12:10   #1017  |  Link
Fuso
Just tried it but it's not working. Output file has lost the HDR10 info:
Codec ID                    : hev1
and can't be even played.
MPC-HC error:
File Source (Async.)::Output
Media Type 0:
Unknown
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Stream {E436EB83-524F-11CE-9F53-0020AF0BA770}
subtype: Unknown GUID Name {08E22ADA-B715-45ED-9D20-7B87750301D4}
formattype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 1
cbFormat: 0
Media Type 1:
Unknown
AM_MEDIA_TYPE:
subtype: TIME_FORMAT_NONE {00000000-0000-0000-0000-000000000000}
lSampleSize: 1
cbFormat: 0
The temp.mp4 file has this info:
Codec ID                    : dvhe
and the temp.mp4 plays fine.
Old 7th January 2025, 12:43   #1018  |  Link
cool advertise
Tried the new v0.64.3d version, now everything works correctly, thank you -QfG-.
Old 7th January 2025, 12:49   #1019  |  Link
Fuso
Ok, so ffmpeg.exe is the one that breaks the process. I took the older version (from v0.63.1) and now everything is working as it should.
Old 7th January 2025, 12:56   #1020  |  Link
KarthikTdk
Hi @All ,
Can any one know where,I can get 1k to 4k resolutions or more than that of YUV video Format of 4:2:0 chroma sampling .
Thank you
Karthik.
KarthikTdk is offline   Reply With Quote
Thread Tools
