Old 11th August 2008, 19:09   #61  |  Link
Seraphic-
Forum Member
What function is related to "spline64resize"?
I'm getting a no function named error for "spline64resize".
Not sure why as the script was working the other day.
Seraphic- is offline   Reply With Quote
Old 11th August 2008, 20:02   #62  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Did you recently uninstall and reinstall avisynth?
It is an internal function, but I don't think it comes in avisynth 2.57. I believe it was implemented in 2.58.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 11th August 2008, 20:07   #63  |  Link
Seraphic-
Forum Member
Ah, yes I did. Must have installed the wrong version there. Thanks
Also, is there anyway to something like "threads=4" to take advantage of four CPU cores?
Old 11th August 2008, 21:27   #64  |  Link
Adub
Adub's Avatar
For what? There are filters that can do this, yes, but many don't.
Normally, the way to run filters multithreaded is to use MT. Just run a search and you will find it.
Site:Adubvideo
Old 28th August 2008, 01:45   #65  |  Link
thetoof
Sleepy overworked fellow
As requested by PM, here my modded version with a new "MT" parameter. It will be used as aa=4 in the next version of animeivtc and will be included in animeivtc.avsi
I may add other parameters (such as overlap, pel, search...) later.
True = use josey_wells' multithreaded MVTools with the new syntax (default)
False = Old syntax, "official" development is up-to-date, but no MT
Also added tradius parameter if you want to use more frames to degrain. Default is 2 since SharpAAMC() uses MVDegrain2.
function SharpAAMC(clip orig, int "aastr", float "ds", int "ShPre", int "ShPost", int "SmPost", bool "MC", bool "MT", int "tradius")
aastr=default(aastr,255) #antialiasing strength
ds=default(ds,0.2) #strokes darkening strength
ShPre=default(ShPre,80) #Presharpening
ShPost=default(ShPost,300) #Postsharpening
SmPost=default(SmPost,100) #Postsmoothing
MC=default(MC, true) #Motion Compensation
MT=default(MT,true) # Use josey_wells' branch of MVTools
Tradius=default(Tradius,2) # 2 = MVDegrain2 / 3 = MVDegrain3 /// 28 = MVDegrain 28
a=orig
w=width(a)
h=height(a)
m=logic( a.DEdgeMask(0,255,0,255,"5 10 5 0 0 0 -5 -10 -5", divisor=4,Y=3,U=3,V=3)
 \       ,a.DEdgeMask(0,255,0,255,"5 0 -5 10 0 -10 5 0 -5", divisor=4,Y=3,U=3,V=3)
 \       ,"max").greyscale().levels(0,0.8,128,0,255,false)
b=a.Toon(ds).Warpsharp(depth=ShPre)
b=b.spline64resize(w*2,h*2).TurnLeft().SangNom(aa=aastr).TurnRight().SangNom(aa=aastr)
b=b.spline64resize(w,h).LimitedSharpenFaster(edgemode=1,strength=ShPost,overshoot=1,soft=SmPost)
MaskedMerge(a,b,m,Y=3,U=3,V=3)
sD=mt_makediff(a,last)
fv2 = a.MVAnalyse(isb=false,delta=2,idx=13)
fv1 = a.MVAnalyse(isb=false,delta=1,idx=13)
bv1 = a.MVAnalyse(isb=true, delta=1,idx=13)
bv2 = a.MVAnalyse(isb=true, delta=2,idx=13)
allv = a.MVAnalyseMulti(refframes=tradius,idx=13)
sDD = (MT) ? sD.MVDegrainMulti(allv,idx=14) : sD.MVDegrain2(bv1,fv1,bv2,fv2,idx=14)
reduc = 0.4
sDD = mt_lutxy(sD,sDD,"x 128 - abs y 128 - abs < x y ?").mergeluma(sDD,1.0-reduc)
return MC ? a.mt_makediff(sDD,U=2,V=2) : b
AnimeIVTC() - v2.00
-http://boinc.berkeley.edu/-
Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p)
thetoof is offline   Reply With Quote
Old 28th August 2008, 07:57   #66  |  Link
egrimisu
egrimisu's Avatar
what aa is aa4 ?
I7 920 @ 3.60GHz + Thermalright Ultra 120 Extreme
Asus P6T Deluxe, 6GB Corsair XMS3 1600MHZ 8-8-8-24
2x1TB Samsung + 1x500GB Samsung,
Corsair 520W, Thermaltake Soprano DX
GeForge GTX280
egrimisu is offline   Reply With Quote
Old 28th August 2008, 09:36   #67  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
sDD = (MT) ? sD.MVDegrainMulti(allv,idx=14) : (MT==false) ? sD.MVDegrain2(bv1,fv1,bv2,fv2,idx=14) : NOP()
o_0 ??? With what condition would that NOP() work?
...desu!
Mystery Keeper is offline   Reply With Quote
Old 28th August 2008, 12:02   #68  |  Link
thetoof
haha, you're right... dunno what I was thinking when I wrote that *edited the first post*
AnimeIVTC() - v2.00
Old 28th August 2008, 16:45   #69  |  Link
Mystery Keeper
Beyond Kawaii
By the way, thetoof. There's NNEDI antialiasing in your script which you say is my suggestion, modified by you. I suggested using EEDI2. What made you change it to NNEDI? NNEDI is more ACCURATE interpolation. 'Tis not as good for antialiasing as EEDI2.
...desu!
Old 29th August 2008, 04:55   #70  |  Link
thetoof
Woah, that's some bad mistake I made back then... I simply thought "nnedi is more accurate, so it must be better", changed it without testing and took it for granted afterwards.
I just tested it on the image we had in the "Denoise of tv-anime" thread and it's uber obvious that nnedi is ineffective where eedi2 works like wonders.
It will be changed in the next version animeivtc.
AnimeIVTC() - v2.00
Old 14th December 2008, 07:38   #71  |  Link
thetoof
Originally Posted by Didée View Post
@ MysteryKeeper: you've had a 1/2-pel registration error between the original (a) and antialiased (b) clip, due to EEDI2. Corrected by the blue parts.
May I ask you what is the purpose/theory/explanation behind 2*w+.001,2*h+.001?
edit: I also compared a random original and aaed clip by using the following script to find which values were appropriate (the image did not move in any direction after ediaa)
function ediaa(clip a) {return a.EEDI2(field=1).TurnRight().EEDI2(field=1).TurnLeft().spline36resize(a.width,a.height,-0.5,-0.5,2*a.width+.001,2*a.height+.001)}
interleave(source, source.ediaa())
Note that I used -0.5,-0.5 to make it work and that you recommended
0.5,-0.5
Am I missing something?
AnimeIVTC() - v2.00
Old 14th December 2008, 14:15   #72  |  Link
Gavino
Avisynth language lover
Note that I used -0.5,-0.5 to make it work and that you recommended 0.5,-0.5. Am I missing something?
Didée's version did the eedi upsizing in a different order:
b=a.Warpsharp(depth=100).TurnLeft().EEDI2().TurnRight().EEDI2()
Since his horizontal resizing was done on a left-turned version, and yours on a right-turned one, the horizontal shift correction is reversed.
Old 14th December 2008, 20:37   #73  |  Link
thetoof
Oh, you're right. Thanks!
Now about the 2*w+.001,2*h+.001 thingy...
AnimeIVTC() - v2.00
Old 14th December 2008, 22:46   #74  |  Link
Gavino
No, I don't get that bit either.
It may have been intended to force resampling to be done (avoiding the no-op optimisation for same-size resizing), but using a non-zero crop position does that already.
Old 15th December 2008, 06:36   #75  |  Link
Didée
It's for backward compatibility with Avisynth 2.5.6. That version would have the resizer going NOP without the +.001 thingy, indeed.
anime, antialiasing, avisynth
