Old 18th February 2019, 22:54   #6081  |  Link
Grimsdyke
Regarding: Infinite Pin Tee Filter
Shouldn't the 64-bit version of mpc-be load/use qcap.dll from SysWow64 instead from System32 ??
Grimsdyke is offline   Reply With Quote
Old 18th February 2019, 23:06   #6082  |  Link
Aleksoid1978
Aleksoid1978's Avatar
It's automatically load from system.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 18th February 2019, 23:31   #6083  |  Link
nevcairiel
Contrary to the names of the folders...
- system32 is the "primary" directory for all OS components. On a 64-bit OS, this folder contains 64-bit DLLs.
- SysWow64 is the "compatibility" directory, containing 32-bit components to run on a 64-bit OS. WoW64 stands for "Windows 32-bit on Windows 64-bit"
So a 64-bit application should pull from "system32", a 32-bit application on a 64-bit OS should use "SysWow64".
nevcairiel is online now   Reply With Quote
Old 19th February 2019, 00:19   #6084  |  Link
beter
Update for translation of Traditional Chinese and Dutch
https://www.sendspace.com/file/f1v0mo
beter is offline   Reply With Quote
Old 20th February 2019, 17:55   #6085  |  Link
v0lt
@beter
Thanks. Updated in r4436.
v0lt is offline   Reply With Quote
Old 22nd February 2019, 16:07   #6087  |  Link
v0lt
@wushantao
Thanks. Updated in r4442.
Old 25th February 2019, 17:14   #6088  |  Link
Klaus1189
Updated german translation based on r4445
Old 26th February 2019, 06:26   #6089  |  Link
wushantao
Simplified Chinese update:)
https://send.firefox.com/download/78...Gqgnx_mvVhZgZQ
http://www.solidfiles.com/d/Byrd4gZdAk7x6
https://bayfiles.com/8bL9i7v6b6/mplayerc.sc.rc_7z
https://anonfile.com/92L8i8v3b7/mplayerc.sc.rc_7z
wushantao is offline   Reply With Quote
Old 28th February 2019, 03:30   #6090  |  Link
v0lt
@Klaus1189, @wushantao
Thanks. Updated in r4448.
Old 4th March 2019, 06:57   #6091  |  Link
wushantao
crash when saving thumbnails, but not every time, and I don't know why……
mpc be 4450 + lav 0.73.1-28 + madvr 0.92.17
and save image is good x10 times
Old 4th March 2019, 09:27   #6092  |  Link
Aleksoid1978
Trying without madVR. If no crash - write to madVR.
Old 6th March 2019, 17:57   #6093  |  Link
v0lt
MPC-BE 1.5.3 (build 4455) beta (SF.net)
Old 6th March 2019, 23:26   #6094  |  Link
lvqcl
MPC-BE switched from libaom to dav1d, so I decided to test its performance on my (rather old) CPU.
Test CPU: Intel Core2 Q9300 (quad core, up to SSE4.1, no AVX)
Test video: Gangnam Style 720p from Youtube
All tested decoders are 64-bit.
Results:
1) LAVFilters 0.73.1-28:       46.0 FPS (CPU usage is about 50%)
2) MPC-BE filters 1.5.3.4450:  45.7 FPS (CPU usage is about 50%)
3) MPC-BE filters 1.5.3.4455:  87.8 FPS (CPU usage is slightly above 80%)
(LAVFilters and MPC-BE 4450 use libaom, MPC-BE 4455 uses dav1d).
Nice speed increase, even on non-AVX2 processor.
lvqcl is offline   Reply With Quote
Old 7th March 2019, 00:50   #6095  |  Link
crazyy
The option "prefer external audio files over embedded audio track" doesn't work with the /dub command line switch.
crazyy is offline   Reply With Quote
Old 7th March 2019, 03:18   #6096  |  Link
Aleksoid1978
I can not confirm(reproduce).
Using option "prefer external audio files over embedded audio track" - always external audio selected.
Old 7th March 2019, 07:36   #6097  |  Link
crazyy
OK.I just tested it again.(from command line with /dub switch) The option works with local external audio files (in PC's disc, both video and audio) but don't with online external audio files (in https server, both video and audio) So the program loads video and audio nicely but does not select external audio track, i need to select it manually.
Old 7th March 2019, 08:12   #6098  |  Link
Aleksoid1978
Yes, it's limitation. When use external from http server it's don't work.
Old 7th March 2019, 08:41   #6099  |  Link
crazyy
OK. but the program should prefer the external one if it was loaded through the /dub switch without needing an option, I think.
Old 10th March 2019, 22:19   #6100  |  Link
Perenista
I am having problems with this program.
Sound crackling on EVERY FILE tested.
What should I do?
Perenista is offline   Reply With Quote
