Old 11th February 2022, 22:31   #1  |  Link
Katherine1
Help converting old avisynth function
Hey,
I'm currently working on converting a few scripts to vapoursynth for a few reasons, (more familiar with python, easier to set up environment thanks to AUR, some vapoursynth plugins like VSGAN, etc.), and I've basically got everything ported over except this one function.
This function does a quick and dirty removal of most of the green color gamut. It does this because it's being used on some old video from those first-generation camcorders that would get those bright blobs of color in bright spots of the image. The video in question has bright green blobs. Funny thing is that the color gamut of VHS at that time is so limited that actual greens in the image remain fine while the unnatural greens from that artifact just get desaturated.
Anyway, the issue I've run into with this function is that basically none of the functions it uses exist in vapoursynth. Is there a good way to do this in vapoursynth? Is there a plugin or group of plugins that could accomplish this?
Here is the function:
function removeAllGreen(clip a) {
    gmask = Overlay(a.UtoY().invert(), a.VtoY().Invert(), mode="multiply").BilinearResize(a.width, a.height).ColorYUV(off_y=-65).ColorYUV(gain_y=3000)
    return Overlay(a, Tweak(a, sat=0.0), mask=gmask) # overlay original with greyscale, only where green
Katherine1 is offline   Reply With Quote
Old 12th February 2022, 12:27   #2  |  Link
Selur
Selur's Avatar
no direct solution, but some hints, that might help:
Cu Selur
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 12th February 2022, 20:02   #3  |  Link
poisondeathray
It's too bad vapoursynth is less mature than avisynth and missing some common functions
A different approach would be to mask a certain range of the green channel in RGB, using a luma mask such as mwlmask
The results are slightly different , and you won't get the same results from a G channel derived mask - but you can adjust the range, feather the edges (blur the mask) if you need to . (Another useful tool missing is Masktools2)
eg. test source
https://upload.wikimedia.org/wikiped...RGB%29.svg.png
removeAllGreen
https://i.postimg.cc/fy7s88Gm/removeallgreen.png
mwlmask l1 = 180
https://i.postimg.cc/g22pKqNL/mwlmask-180.png
mwlmask l1 = 220
https://i.postimg.cc/vm1dJ8RQ/mwlmask-220.png
AVS
ImageSource("1024px-Color_circle_(RGB).svg.png")
ConvertToPlanarRGB()
ConvertBits(16)
ConvertToYUV444(matrix="rec709")
removeAllGreen
VPY
clip = core.imwri.Read(r'1024px-Color_circle_(RGB).svg.png')
y = core.resize.Bicubic(clip, format=vs.YUV444P10, matrix_s="709")
nosat = adjust.Tweak(y, sat=0, coring=False)
g = core.std.ShufflePlanes(clip, planes=1, colorfamily=vs.GRAY)
gm = mwlmask(g, l1=220, h1=255)
gm = core.fmtc.bitdepth (gm, bits=10, fulls=True, fulld=True)
ov = haf.Overlay(y, nosat, mask=gm)
#ov = core.resize.Bicubic(ov, format=vs.RGB24, matrix_in_s="709")
ov.set_output()
avisynth, scripting, scripts, vapoursynth
