12th October 2022, 14:42 | #19641 | Link | |
#Custom video=AssumeFPS(video,24/1.001)
12th October 2022, 18:49 | #19642 | Link | |
video=AssumeFPS(video, 24000, 1001) What does line 6 represent and does this matter? EDIT: Having checked the MediaInfo data for the output produced via script or manually, they appear to be identical (other than time stamps and IDs) so I assume that field 6 is not relevant. Thanks, Archiel Last edited by archiel; 12th October 2022 at 19:34. Reason: Updated info |
13th October 2022, 23:00 | #19643 | Link |
im trying to start encoding 4k uhd movies as close as i can to what the disc has in the way of picture. some discs have Dolby Vision which my TV supports. ive noticed some MKVs are now including the DV meta data. im using a PC with a nvidia 1650 hdmi 2.0 connection to the TV and mpc-hc and madvr to play MKVs. what id like to know is if ripbot can create an MKV from an original rip of the whole movie with the Dolby Vision working?
14th October 2022, 10:50 | #19644 | Link |
hi all.
Can ripbot264 use smooth frame interpolation > 50/59.94 fps like 100/119.88 fps ? There is a good avisynth filtrr: http://avisynth.nl/index.php/SVPflow Last edited by darkio; 14th October 2022 at 14:44. |
15th October 2022, 01:03 | #19645 | Link | |
Formally known as .......
So what exactly are you wanting to do ?? Slow down or speed up things ? Would this also be something similar ?? https://github.com/Dogway/Avisynth-S...verterMIX.avsi This the code / script from Staxrip, if it means much to anyone... Code:
AddAutoloadDir("C:\StaxRip-v2.13.0-x64\Apps\FrameServer\AviSynth\plugins") LoadPlugin("C:\StaxRip-v2.13.0-x64\Apps\Plugins\AVS\SVPFlow\svpflow1.dll") LoadPlugin("C:\StaxRip-v2.13.0-x64\Apps\Plugins\AVS\SVPFlow\svpflow2.dll") Threads = 8 super_params = "{pel:2,gpu:1}" analyse_params = """{block:{w:16,h:16}, main:{search:{coarse:{distance:-10}}}, refine:[{thsad:200}]}""" smoothfps_params = "{rate:{num:4,den:2},algo:23,cubic:1}" super = SVSuper(super_params) vectors = SVAnalyse(super, analyse_params) SVSmoothFps(super, vectors, smoothfps_params, mt=threads) #Prefetch(threads) must be added at the end of the script and Threads=9 after the source Prefetch(threads) Last edited by TDS; 15th October 2022 at 05:46. |
16th October 2022, 01:16 | #19647 | Link | |
Have a look at this :- https://forum.doom9.org/showthread.php?t=183479 |
17th October 2022, 02:13 | #19649 | Link | |
It's been a while since your last post, here. So there are 2 ways to get 1.26.2 !!! Enable autoupdate, OR go here :- https://forum.doom9.org/showthread.p...92#post1974392 OR here :- https://forum.doom9.org/showthread.p...91#post1974691 |
24th October 2022, 22:15 | #19650 | Link |
Encodingserver hangs / stalls
Hello,
has any one else encountered this issue when doing distributed encoding (and solved it)? Sometimes a encodingserver stalls/get stuck on 99.x % for a chunk and doesn't finish? i can manually stop the encoding for the specific server and let it continue on another chunk. thanks. |
25th October 2022, 00:26 | #19651 | Link | |
Unfortunately, this can & does happen from time to time, and what you do is about the best way to "fix" it. However, maybe you could try this (in the RipBot264.ini) Code:
Server1CommandLine=/port 1000 /minimize /priority normal /restart-if-no-progress Good luck. |
26th October 2022, 14:54 | #19653 | Link | |
26th October 2022, 20:50 | #19654 | Link | |
https://forum.doom9.org/showthread.php?t=183479 l extract the Dolby Vision out from files created by MakeMKV, I select crop (if necessary) and save the RPU.bin. I create my encoded file using RipBot and I crop (if necessary). I then use DDVT to mux the RPU.bin file with my RipBot encode to create a new file with Dolby Vision in it. I'm not resizing the video (other than cropping) though as that will add another few steps to change the Dolby Vision for the smaller file. |
27th October 2022, 00:12 | #19655 | Link | |
You've been quiet for a while.... I was half expecting you to comment on this post, as I knew you'd done the same thing a while back...I actually pointed the op to that link, as well. Good thing is, you've provided some instructions |
27th October 2022, 13:43 | #19658 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th October 2022 at 14:35. |
28th October 2022, 12:23 | #19659 | Link | |
Aslo just something i noticed, perhaps just a coincidence (or a clue), but i changed from demux (TRUEHD / AC3) to core when selecting the audio it seems to be running fine... perhaps /restart-if-no-progress at work but i had this option set earlier also. i did multiple encodes (10+) to x265 with core audio and didn't need to restart any of them . |
29th October 2022, 14:38 | #19660 | Link |
not sure if it's the same issue or a Win server 2019 specific "security" issue but my issue when encoding server didn't start was that the process was waiting for another process to finish, i had to kill that process for encoding server to start, look in task mananger if you can see encoding server there and then go to details -> analyze wait chain.
