29th April 2019, 20:37 | #21 | Link |
Just a small Update, now with a Local Version column.
@stax76 Are other apps also this big? WPF should be dpi aware. What is your scaling value in windows, 200%? I have "3K" -> 1440p @ 100%. With scaling @ 150% it is very big, but looks ok and stays within the screen.
29th April 2019, 20:43 | #22 | Link |
like I said 288 DPI (96 DPI equals 100% zoom so my zoom is 300%)
29th April 2019, 22:06 | #23 | Link |
ok and is alpha2 also out of screen bounds?
29th April 2019, 22:17 | #24 | Link |
Well, I downloaded the link from first post saying it's a2 but title bar says a1 so probably chrome browser cache issue, use dl filenames including version like VSRepoGUIvA2.zip
29th April 2019, 22:21 | #25 | Link |
Downloaded with another browser, still out of screen bounds.
29th April 2019, 22:24 | #26 | Link |
I forgot to change the version string
But you can resize it smaller?
29th April 2019, 22:39 | #27 | Link | |
29th April 2019, 22:58 | #29 | Link |
you are young and use less than 288DPI/300% zoom
edit: dau: Dümmster Anzunehmender User
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 29th April 2019 at 23:02. |
29th April 2019, 23:15 | #31 | Link |
I'm sorry then, born 76 and never had the best eyesight.
2nd May 2019, 09:19 | #33 | Link |
Alpha3
- Removed some duplicate calls, should start faster now - Use PythonPath if available in vs registry - Win64 toggle is fully working now - Added a "portable mode" - auto update definitions on start EDIT: And fixed search EDIT2: And source code is up For portable mode you need to create a "vsrepogui.json" text file in the same folder as the exe with the following contents: Code:
{ "Bin":"D:\\PortableApps\\VapourSynth\\vsrepo\\abc d\\vsrepo.py", "win32": { "Binaries":"D:\\PortableApps\\VapourSynth\\vsrepo\\abc d\\p32", "Scripts":"D:\\PortableApps\\VapourSynth\\vsrepo\\abc d\\scripts", }, "win64": { "Binaries":"D:\\PortableApps\\VapourSynth\\vsrepo\\abc d\\p64", "Scripts":"D:\\PortableApps\\VapourSynth\\vsrepo\\abc d\\scripts", } }
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 2nd May 2019 at 18:09. |
14th May 2019, 14:35 | #34 | Link |
Alpha4
- Added Tabs - It is now possible to use relative paths in vsrepogui.json - Fixed high dpi issue (@stax76 please test)
30th May 2019, 16:58 | #35 | Link |
Alpha6 inspired by avsmeter:
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 30th May 2019 at 17:53. |
30th May 2019, 20:44 | #36 | Link |
🔥 Namespace already populated, therefore it failed to load: ------------------------------------------------------------ vs_sangnommod.dll 😑 Notice - Not a VapourSynth Plugin: ------------------------------------------------------------ libfftw3-3.dll libfftw3f-3.dll |
30th May 2019, 20:55 | #37 | Link |
Yes they are not VS plugins, You can't load them via LoadPlugin() but it doesn't mean they can't be dependencies of other plugins and that's why it is under "Notice" and not Error. Should I add some additional infos? Suggestions?
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 30th May 2019 at 20:57. |
31st May 2019, 01:27 | #39 | Link |
How about like this?
🤨 Notice - Probably a Plugin dependency (not a VS Plugin): ------------------------------------------------------------ libfftw3-3.dll libfftw3f-3.dll
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 31st May 2019 at 01:29. |
