Old 26th July 2007, 21:34   #81  |  Link
timestoby
well since askn on this forum and others ive never gotten a solid answer to wot type of hardware a gpu's is best for playn back 720p and 1080p movies witout stutter and being able to do emails or some other stuff at the same time.
like wots the least type of gpu can i use for a laptop,same for desktop.
core duo or core 2 duo,which is better
a list of gpu's for both laptop and desktop would be great.
like right now my desktop has 1gb ram p4 3.oghz and an old nvidia fx5200 128mb card,and its old.i can run 720p fine,but cant run mkv.x.264 1080p files,but can run 1080p wmv-hd fine.
surely newbs would want to know this type of info.maybe they still stuck in the sd era.
timestoby is offline   Reply With Quote
Old 9th September 2007, 16:43   #82  |  Link
jult
A Joy Forever
jult's Avatar
Converting videos from
YouTube Googlevideo LiveLeak Dailymotion FLV flash video
to be editable usable in VirtualDub, and all this as lossless as possible.
There are literally hundreds of so-called guides on this, but none of them is considering the aspect of not wanting to lose audio- and video-quality. Also, most of the guides involve HUGE software-packages for just one task, or scripts. I have yet to see a decent guide for this. Would be great to see one here.
jult is offline   Reply With Quote
Old 9th September 2007, 17:11   #83  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Avidemux can directly edit them. Instant bonus!
You can use ffmpeg to mux to avi and edit in virtualdub, totally lossless, but you must have a recent ffdshow installed and flv decoding enabled for it. There's also no GUI for it, command-line or batch files only. Fortunately it's dirt simple:
ffmpeg -i {input}.flv {output}.avi
In newer builds it'll detect the frame rate and everything for you. (Which surprised me just now, it used to always do 1000 fps.)
Or you can use pretty much any ffmpeg or mencoder frontend to convert it to pretty much any other format in existence, see the GUI forum for plenty of those.
Old 7th November 2007, 16:35   #84  |  Link
lellum
duh....
I am using the very latest StaxRip (1.0.0.1) and it has downloaded it's needed versions of everything but nero aac encoder (it wanted feb 2007 - august '07 was dl'ed instead).
I am new to x264/aac encoding into the mkv and mp4 containers and am playing the files using VLC 0.8.6c. Ripper is DVDdecrypter 3.5.4.0 on XP Pro.
Audio sync is a nightmare and is off by a constant interval. Should I search for the older version the AAC encoder, or is there something wrong with using the programs I am using?
edit to add:
I have located a source for the required back level nero encoder; it can be downloaded from
http://www.brothersoft.com/mp3_audio...oad_59677.html
The required version is 1.0.7.0 and the releases date is Feb 12, 2007. I am doing an encode from scratch on a movie that has displayed the sync prob and will update this post when I have checked it out.
edit to update:
Many problems seem so obvious after you find them. The problem was that I did not change the default DVDDecrypter processing mode from 'File' to 'IFO' and was at the mercy of circumstance. I was trying to get my process up and running on four machines and thought that individual environments were involved.
Thank you.
lellum is offline   Reply With Quote
Old 12th November 2007, 08:14   #85  |  Link
_yo_wasup_
Seriously, cover the result of this other topic of EVO files to WMV HD conversion after it is figured out. What I don't like about this forum in particular that should change is that people should post updates in the first post in an easy to understand manner dated with credits. Especially these 15 page topics you know no one is going to read every 15 pages because their attention span is 10 seconds before they post the same question asked 128 times already.
_yo_wasup_ is offline   Reply With Quote
Old 1st February 2008, 23:18   #86  |  Link
nightryder21
How to create a single .vob file from a DVD containing just the movie.
nightryder21 is offline   Reply With Quote
Old 10th February 2008, 17:18   #87  |  Link
DMF
DMF's Avatar
Kind of DVD-RB specific, but may apply somewhat to a FAQ here: There is *no* discussion in DVD-RB FAQ (unless I've managed to miss it) of the various modes. I know it's a complex subject, but surely each merits a couple of sentences and a pointer to some on-line resource (or, here, thread). E.g.:
"XYZ Mode - Mode that {uses the XYZ program or whatever}. It's particularly good at blah blah, but downside is blah blah.. See [linkie] for more information."
DMF is offline   Reply With Quote
Old 3rd September 2008, 22:46   #88  |  Link
ettin
I would like an detailed explanation of what happens when a variable (or combination of variables) within a filter is set to either extreme. Every single tutorial or FAQ out there just explains in vague terms what it does, like "function Q of MY filter makes THIS do THAT, you can set it from 0 to 99". And im always left asking, well, what the hell happens if i set it to 99? No wait, let me spend the next hour finding out. Oh, whats that, you have 5 more settings to change, and the combination of any of them could produce a drastically different result than any of them by themselves? Well, let see, 6 settings , so thats 5 + 4 + 3 + 2 + 1 = 15 hours for combinations of two! I wonder what 3 or more of these settings do, i think retirement is coming up soon, maybe i can finally find out!
Its not really a FAQ in and of itself, its more of a way of creating FAQ's that actually create a greater sense of understanding instead of just blindly leading people towards a specific goal.
ettin is offline   Reply With Quote
Old 10th September 2008, 15:23   #89  |  Link
juGGaKNot
juGGaKNot's Avatar
a "how to" faq
hot to get DXVA working on ATI HD cards
juGGaKNot is offline   Reply With Quote
Old 13th September 2008, 18:16   #90  |  Link
Ramir Gonzales
A method on how we could play two encodes 'on top of eachother' or "side-by-side" would be great !
Ramir Gonzales is offline   Reply With Quote
Old 13th September 2008, 19:50   #91  |  Link
juGGaKNot
juGGaKNot's Avatar
well
make a new project in vegas ( you didn't say the resolution ) 1920x1080
take the first material at 960x540 and add a border up 960 pixels
take the second 960x540 material and add a border down 960 pixels
put the footage on top of each other and you will have a 1920x1080 split screen material
weird i know
if your footage is 1920x1080 than project 3840x2160 and add border 1920 each
Originally Posted by juGGaKNot View Post
a "how to" faq
got the DXVA working, no need for the faq
Old 14th September 2008, 00:26   #92  |  Link
Ramir Gonzales
Yes JuGGAknot, but I was actually look for some Avisynth script.
Old 14th September 2008, 12:20   #93  |  Link
J_Darnley
J_Darnley's Avatar
Read the docs. StackHorizontal and StackVertical are what you should look at and Interleave might also be of interest.
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 10th October 2008, 02:22   #94  |  Link
omibrain
OK, so I just found this forum which seems to be a plethora of audio/video info. But, it all is "greek" to me. Has anyone written a dictionary of terms?
omibrain is offline   Reply With Quote
Old 10th October 2008, 02:28   #95  |  Link
A dictionary wouldn't help you much. You need to do some serious research and learning. I'm sorry to say there is no shortcut. But the journey can be quite enjoyable.
Anyway, Google is a giant dictionary and you should be able to find out what you need with it. If not, post a question in the Newbies forum.
Old 10th October 2008, 04:41   #96  |  Link
linyx
Un-Registered User
linyx's Avatar
Actually there is a glossary of terms here, but this is FAR from everything.
Happy learning.
linyx is offline   Reply With Quote
Old 11th October 2008, 01:52   #97  |  Link
omibrain
glossary=good
well, thanks all. I do think the glossary will help. so, I begin my journey with the first step.
Old 27th March 2009, 23:54   #98  |  Link
Karkas
Karkas's Avatar
Software glossary
I started delving into this stuff a few months ago and still feel overwhelmed by the number of apps out there. I would love to see a list something like this...
Ripping programs:
Standard DVDs only:
Program A - Discription, price, rating etc.
Program B - Discription, price, rating etc.
HD DVD, BR, and standard DVDs:
Program C - Discription, price, rating etc.
BR only:
Program D - Discription, price, rating etc.
Encoding programs
Program E - Discription(codecs & containers), price, rating etc.
Program F - Discription(codecs & containers), price, rating etc.
Playback programs:
Standard DVD only
Program G - Discription, price, rating etc
HD DVD/BR playback
Program H - Discription, price, rating etc
File playback
Program I - supported codecs/container, price, rating etc
Yadda Yadda Yadda
If there was something like this that allows us noobs to make sence of the tower or babel of codecs & programs most of us could be brought up to speed very quickly.
Karkas is offline   Reply With Quote
Old 5th April 2009, 16:26   #99  |  Link
kalia
i've had quite a bit of success converting with the open source software mediacoder. pretty intuitive to work out and operate. simply set source, output file and destination, tweak output settings depending on file format, and go.
kalia.
kalia is offline   Reply With Quote
Old 2nd June 2009, 05:12   #100  |  Link
frank lampard
Originally Posted by aleksander View Post
Hi there!
I would like to make this thread a place where everybody can post his/hers ideas or suggestion of what should be included in the upcoming Newbies FAQ (that, by the way, is missing and should be done long time ago - I admit - my fault).
There is already a number of people working on it, but we are all only humans. There are things that might be just straightforward for some of us, but for others will need some explanation. There are things that we may just overlook. There is a lot of reasons...
And you guys are the ones I would like to ask for help.
If you think that something is missing in other FAQs, that something has to be explained in more understandable way - now you've got a place to post your thoughts, remarks, etc.
If you have some questions, that you think that should be included in the FAQ and already know good answers - post it here!
We will look for answers and we will combine it all into one FAQ.
Any help from your side is much anticipated and welcome.
So....
LET'S BEGIN!!!!
aleksander
Hi guys,I am newbie here.My name is frank.
Glad to meet you all,guys..
frank lampard is offline   Reply With Quote
