Old 18th September 2023, 17:58   #1  |  Link
MMA
Correcting solid pixels
I have a file with solid dead pixels across the entire video and i would like to have them corrected: https://i.imgur.com/WbNoV1C.png
They only show up in same line at the bottom border but their position changes with every frame. They also look like they are the same color every time.
I was thinking about a Vapoursynth script that searches for the specific color and replaces each pixel with the average of the pixels immediately adjacent up or to the sides, provided the ones on the side are not of that same color. So i would need to create a mask to search for said color, apply a function to replace them and merge it only at the bottom border. I'm having a hard time executing it so i would appreciate if someone could help or point me in the right direction.
Here is a full frame: https://imgbox.com/4Y0KCmFh
MMA is offline   Reply With Quote
Old 18th September 2023, 18:31   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
What if you call these dead pixels a logo and use InpaintDeLogo ? ;-)
Old 18th September 2023, 22:17   #3  |  Link
MMA
I've never thought about using a delogo. I'll try the VS ones since i'm not familiar with AS.
Old 19th September 2023, 09:21   #4  |  Link
ChaosKing
I would also try delogo.
A simple average (or blur) with Overlay+Crop could be also effective
There's also https://github.com/AkarinVS/vapoursynth-plugin#expr which can access individual pixels. But expr is to cryptic for me...
