Old 7th September 2023, 00:41   #1  |  Link
orion44
None
orion44's Avatar
Correct placement of ColorMatrix in AviSynth script?
When converting Blu-Ray to SD resolution, where should I put the ColorMatrix filter?
Before cropping and resizing, or after resizing?
This is my current script:
DGSource("D:\Project\m2ts.dgi")
ColorMatrix(mode="Rec.709->Rec.601")
Crop(4,0,1916,1080)
BicubicResize(720,404,b=0,c=0.5)
Trim(0,154009)
#SelectRangeEvery(1918,96)
orion44 is offline   Reply With Quote
Old 7th September 2023, 16:52   #2  |  Link
Sharc
It doesn't matter for the end result. However, I would insert it after resizing because players may default to 709 when you watch the video at the original HD resolution (e.g. for debugging the script) but default to 601 when you watch it at the downscaled SD resolution.
