Old 8th August 2023, 02:13   #1  |  Link
Paul-Kun
Just Learning To Use This
Merge 2 half videos but error on loading on encoder
Hi!
Sorry not exactly a noob, but I Just need to confirm if I'm might be doing something wrong because I have 2 videos that I need to merge, but when I run the avisynth script on my media player, is running completely fine, but when I try to encode it, to something none of the programs that I use for encoding seem to work, but I'm not sure if maybe is the Size of the project or some sort of other limitation, the scripts that I'm currently running are for opening the file using FFMS and changing the channels from 6 to 2, first script is
FFMS2("E:\DISC1\BDMV\STREAM\00109.m2ts", vtrack = -1, atrack = -1)
DownMix()
Normalize()
ConvertAudioTo16bit()
return Last
function DownMix(clip a, float "centergain", float "surroundgain")
a.ConvertAudioToFloat()
## 5.1 WAV channel layout:
fl = GetChannel(1)
fr = GetChannel(2)
fc = GetChannel(3)
lf = GetChannel(4) ## (LFE not used)
sl = GetChannel(5)
sr = GetChannel(6)
## add center
gc = Default(centergain, 1.0) * 0.7071
fl = MixAudio(fl, fc, 1.0, gc)
fr = MixAudio(fr, fc, 1.0, gc)
## add surround
gs = Default(surroundgain, 1.0) * 0.7071
fl = MixAudio(fl, sl, 1.0, gs)
fr = MixAudio(fr, sr, 1.0, gs)
return AudioDub(a, MergeChannels(fl, fr))
And the second script is
FFMS2("E:\DISC2\BDMV\STREAM\00109.m2ts", vtrack = -1, atrack = -1)
DownMix()
Normalize()
return Last
fl = GetChannel(1)
fr = GetChannel(2)
fc = GetChannel(3)
sl = GetChannel(5)
sr = GetChannel(6)
## add center
## add surround
Note Drive E is not a disc drive but a hard drive.
And to merge it, since I wouldn't allow me to merge it directly from a single avisynth script I was using a 3rd one that is
v1 = AviSource("C:\Users\Paul-Kun\Desktop\justice 1.avs")
v2 = AviSource("C:\Users\Paul-Kun\Desktop\justice 2.avs")
v1+v2
Since this a Blu-ray the size of the files are pretty big at 30GB each and merging them in such a way is really resource intensive I don't know if there is any other way as I was trying to find other ways but nothing that I could use.
Paul-Kun is offline   Reply With Quote
Old 8th August 2023, 02:31   #2  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
DownMix()
Normalize()
v1 = Last
DownMix()
Normalize()
v2 = Last
v1++v2
VoodooFX is offline   Reply With Quote
Old 9th August 2023, 01:08   #3  |  Link
TDS
Formally known as .......
TDS's Avatar
Originally Posted by Paul-Kun View Post
Hi!
You could try MKVToolNix or tsmuxer to merge the clips...
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
