Old 5th June 2023, 02:29   #1  |  Link
orion44
None
orion44's Avatar
What is the difference between LimitedSharpenFaster and SeeSaw?
Does LimitedSharpenFaster and SeeSaw produce the same sharpening, or is there a difference between these two sharpeners?
orion44 is offline   Reply With Quote
Old 5th June 2023, 10:24   #2  |  Link
lollo2
lollo2's Avatar
No. Here a comparison:
https://imgsli.com/MTg0MDQy
https://imgsli.com/MTg0MDQz
SeeSaw()
LimitedSharpenFaster(smode=3, strength=s250, overshoot=50, ss_x=1.5, ss_y=1.5)
In any case, you should try with your own material.
A channel on S-VHS / VHS capture and AviSynth restoration https://www.youtube.com/channel/UCMs...h1MmNAs7I8nu4g
lollo2 is offline   Reply With Quote
Old 5th June 2023, 16:16   #3  |  Link
Or you could try comparison like this [untested]
Colorbars
#Avisource(".\SomeClip.avi")
A = Last # Filter 1
B = ShowFrameNumber #Filter 2
Interleave(a.SubTitle("A"),b.SubTitle("B"))
Old 5th June 2023, 18:19   #4  |  Link
orion44
None
orion44's Avatar
I'm testing both LSF and SeeSaw.
I managed to achieve great results with LimitedSharpenFaster and HQDN3D denoiser.
I'm not sure how to use SeeSaw. I want to give SeeSaw a denoised video, then resize it, and then apply SeeSaw sharpening.
Something like this:
hqdn3d(ls=0, cs=0, lt=2, ct=3, restart=3)
BicubicResize(640,480,b=0,c=0.5)
SeeSaw()
I know this is not correct, but how do I give SeeSaw a denoised clip, then resize it, and after resizing it apply the sharpening part of SeeSaw?
Old 5th June 2023, 21:00   #5  |  Link
ChaosKing
SeeSaw: More of a detail enhancer than a regular sharpener. Also lets you really turn up the denoising without the typical ringing and haloing. https://forum.doom9.org/showthread.php?t=104701
SeeSaw needs 2 input clips, original and denoised.
Avisynth wiki has more information: http://avisynth.nl/index.php/SeeSaw
Old 19th October 2023, 07:33   #6  |  Link
Wathre
LimitedSharpenFaster is a sharpening algorithm commonly used in video encoding and post-processing. It focuses on enhancing edge sharpness while minimizing the introduction of artifacts and noise. Compared to LimitedSharpenFaster, SeeSaw offers a more aggressive approach to sharpening, resulting in a more pronounced and noticeable sharpening effect. geometry dash lite
Wathre is offline   Reply With Quote
