Old 31st December 2009, 21:07   #1  |  Link
audiohominis
High Quality Up-Conversion filter
Hi guys. In your experience, what would you consider to be AVISynth filter equivalents closest to commercially available up-scaling plug-ins like InstantHD, BlowUp, Genuine Fractals, etc. The rez of some 640x360p vids need doublin' but I'm looking for something sharper than what the conventional bi-linear, bi-cubic, etc algorithms have to offer.
I looked for some pages comparing images produced with various AVISynth filters aimed at that but couldn't find anything satisfying.
Thank you in advance.
CPU: Intel® Core™i7 930 @ 2.80GFz 2.79 GHz (8 cores)
GPU: NVIDIA® GeForce® GTS 250
SYS: Windows 7 Ultimate x64
RAM: 6.00 GB
audiohominis is offline   Reply With Quote
Old 31st December 2009, 21:17   #2  |  Link
DarkT
I think NNEDI 2 or something like that is famous for its "blow up" capabilities?
*shrugs*
DarkT is offline   Reply With Quote
Old 31st December 2009, 23:04   #3  |  Link
audiohominis
Thank you for your reply. It looks pretty good.
RAM: 6.00 GB
Old 1st January 2010, 00:27   #4  |  Link
DarkT
glad I could help... I'm usually the one who gets helped here .
Happy new year people, btw .
Old 1st January 2010, 01:44   #5  |  Link
10L23r
ya nnedi2 is the best upscaler for avisynth... probably better than commercial plugins too.
for linear interpolation... the best would be lanczos and spline
10L23r is offline   Reply With Quote
Old 1st January 2010, 01:54   #6  |  Link
thetoof
Sleepy overworked fellow
Don't forget the new (and still in testing) eedi3 - http://forum.doom9.org/showthread.ph...68#post1343668
AnimeIVTC() - v2.00
-http://boinc.berkeley.edu/-
Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p)
thetoof is offline   Reply With Quote
Old 1st January 2010, 02:43   #7  |  Link
audiohominis
_m
Some pretty impressive de-interlacing results there.
RAM: 6.00 GB
Old 1st January 2010, 03:33   #8  |  Link
DarkT
I tried eedi3 with mixed results... at some places it caught some stuff, at others it performe worse than yadif+nnedi2 / tdeint+nnedi2, but it's certainyl worth a shot .
Old 1st January 2010, 07:07   #9  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Using nnedi / nnedi2 in double height mode will probably be your best option
If you're doing upscaling, you might want to look into some form of noise reduction, and possibly sharpening - though you should probably go easy on them both! Over filtering is always a bad idea.
Take a look at LSFMod for sharpening, and FFT3DFilter / MDegrain are both excellent denoisers. Tune them carefully.
~MiSfit
Old 1st January 2010, 18:18   #10  |  Link
Didée
If you think about what NNEDI actually is doing, you'll come to the conclusion that the result of NNEDI-upscaling *should* be sharpened in some way. Remember that NNEDI is not a scaler, but an interpolator for missing-by-decimation data. In a smooth progressive frame, there is not any data missing in this special way. E.g. a 1-pixel line with 1-pixel antialiasing on either side will be much broader in the upscaled frame than it should be ideally.
orig: 10 10 14 20 14 10 10
NNEDI: 10 xx 10 xx 14 xx 20 xx 14 xx 10 xx 10
Not quite sure how to put this in a few words ... what about "Nyquist interpolation / restoring" ? Those parts of detail that are somehow close to Nyquist frequency in the source frame, those need to be thinned in the NNEDI-upscaled frame.
Old 1st January 2010, 18:28   #11  |  Link
DarkT
Sorry man, I lost you at "nyquist" *grins*
But the basic idea is that because NNEDI is trying to restore lost (or missing?) data, and a progressive frame has no lost data, what happens is that some stuff which NNEDI *thinks* is lost data, gets strengthened, I think, no?
Old 1st January 2010, 22:34   #12  |  Link
shoopdabloop
a different "sharpening" mode could be used when dh=true.
shoopdabloop is offline   Reply With Quote
Old 3rd January 2010, 03:14   #13  |  Link
Undead Sega
If NNEDI is an interpolator and not a scaler (even though it does provide good results) what would be the best upscaling filter in Avisynth (just to help answer the OP's question)?
Can TGMC be used as an upscaler???
Undead Sega is offline   Reply With Quote
Old 3rd January 2010, 04:10   #14  |  Link
DarkT
Dude, you used the B word! *awaits for neuron2* *chuckles*
It is an interesting one though... To be honest though, I didn't find much difference between lanczs and nnedi... Maybe I wasn't lookign good enought? *shrugs*
Old 3rd January 2010, 04:37   #15  |  Link
Undead Sega
ohhh crap, i totally forgot about that, im not going to edit that post as i will take up for that little typo, what i really meant to say was "what would be the better upscaling filter in Avisynth instead of using conventional resizing methods like Bicubic, Lancz and Spline?"
Are you refering to when i mentioned TGMC as an upscaler? i mentioned that because of its motion-compensated analysis of frame(s) which it naturally yields excellent and 'rich' results. Cant it be using that algorithm for upscaling?
Old 3rd January 2010, 06:41   #16  |  Link
markanini
How about HybridFuPP?
markanini is offline   Reply With Quote
upscaling
