Old 27th October 2021, 23:44   #1  |  Link
johnmeyer
Need help "perfecting" script to delete drops and dups
I have been trying for a decade to perfect a script which can reliably and automatically detect and remove dropped frames, and also automatically fix the duplicates which usually follow the drops. This drop/dup pattern happens at some point in almost every streaming video, and is also often seen in screen captures. It is an incredibly common problem.
I need help with three things:
1. TDecimate is not reliable in this application (this is the main problem)
2. A minor problem: mt_merge does not provide identical video to the original when merged with pure white. The script works despite this flaw, but I'd like to understand how to fix it.
3. I cannot multi-thread the script because of TDecimate
Any help would be appreciated. At this point, I have given up. The script is still useful as written, but it will fail to fix quite a few drops and dups, all because of TDecimate's failures.
However, it is tantalizingly close to being an incredibly useful script.
For those interested in helping, here is the background, followed by my current script.
I first posted my script in 2011: Automatically fix dups followed (eventually) by drops , and then again a few weeks ago: Dropped frames
When I answered the OP a few weeks ago I thought initially that the main problem was that I wasn't detecting drops very well, but after posting about this (Script for reliably detecting dropped frames) I found out the my technique is actually quite good. There is no need to revisit my detection scheme.
The REAL problem is TDecimate. If a frame drop happen on a Cycle boundary (where "Cycle" is the group of frames TDecimate works on at one time), it fails. The reason for this is that Didée's original brilliant idea requires that the drop and the dup happen within a TDecimate "Cycle."
Perhaps I need to come up with a different approach, or perhaps there is a way to tweak Didée's idea.
The script is also very slow, but does not play nice with MT (also a TDecimate problem), so I can't use that technique to make it play faster. Because it is so slow, the idea of running TDecimate three times with different parameters and then "voting" on the best result is not going to work because the script speed will be measure in seconds per frame instead of frames per second.
BTW, I used my "really good" MVTools2 technique for creating the intermediate frames, so when a replacement is made it is usually undetectable. That is why there are so many lines of code preceding the MFlowFPS call.
I also tried SVP, and it does work and it is faster, even without MT, so I might go with that if and when I figure out a replacement or a fix for TDecimate. I have left that commented out code in the script.
Things I have tried
I have tried FDecimate and it doesn't work. I have tried TDecimate using its 2-pass approach which I thought would work for sure, but it does not. I have also tried TDecimate's mode 0, mode 1, mode 2, and mode 7.
I am thinking about playing around with Requestlinear settings, and also am wondering if I can use the metrics from FrameDiff to create my own decimation.
I am running AVISynth+ 3.7.0 and am using pinterf's 2/22/2021 compile of TIVTC (which includes TDecimate).
The comments at the beginning of the script describe how it works. If anyone has any ideas about how to fix it, let me know. The script is still partially hard-wired for 59.94 fps, but I will clean that up and turn it into an AVSI if I ever get the problems solved.
Here are links to two really tiny test videos. The first is artificial video (just a title scrolling horizontally) and the other is real video with multiple short scenes chosen for their different types of motion. I used my NLE to create a drop, followed by a dup within 1 to 12 frames later. The real video link also includes a text file which gives you the frame numbers where I created a drop, and also the frame numbers for the dups I inserted.
"Trivial" manufactured video test
https://www.mediafire.com/folder/yjf...d3d4mlo/shared
Real Video Test
https://www.mediafire.com/file/yjffj..._Test.zip/file
Thanks in advance to anyone who has read this far and might have some ideas.
# Based on script created by Didée
# Modified by John Meyer on June 29, 2011
# Further modification on June 8, 2013
# Tdecimate modifications on October 26, 2021
# 1. Create interpolated frames a 2x original frame rate using MVTools2.
# 2. Detect jumps in the original 1x video.
# 3. Create white mask at each jump point; black mask for all other frames.
# 4. Repeat each frame of original video.
# 5. For each frame in double-frame video, use a mask to "choose" between that original video, or the motion estimated video
# 6. Decimate exactly 50% to get back to original frame rate.
# This decimation removes the dup frames that existed in the original video and also removes the dups created by
# repeating each frame of original video.
# However, at each point where motion-estimated frame was inserted, no decimation occurs.
# Thus, if dups=drops, all dups in the original video will be removed and the drop will be filled.
# On the other hand, if no drops or dups occur, then no motion estimation appears in the final result, and the decimation
# merely gets back to original, unchanged video.
#User-settable paramaters
#Puts dot on screen during debugging. True for troubleshooting; otherwise, false.
showdot = true
#Threshold for detecting jumps. Increase to catch more jumps. Should always be less than 1.0
JumpThresh = 0.8
#Frame rate of your video
#PAL: Vidnum=25; VidDen=1;   NTSC: Vidnum=30000; VidDen=1001;  etc.
VidNum = 60000
VidDen = 1001
#Detection window size. Try changing if you find residual dups or drops. Script gets slow if you use big numbers
DupCycle = 18
threads = 1  #TDecimate does not like multithreading
loadplugin("E:\Documents\My Videos\AVISynth\AVISynth Plugins\plugins\MVTools2 (latest)\mvtools2.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\mt_masktools-26.dll")
#These were used when trying to get AVISynth+ multi-threading to work
#SetFilterMTMode("TDecimate", MT_SERIALIZED)
#SetFilterMTMode("TDecimate", MT_MULTI_INSTANCE)
global source=AVISource("E:\fs.avi").ConvertToYV12.killaudio()
global BlackFrame = BlankClip( source, Color=$000000 )
global WhiteFrame = BlankClip( source, Color=$FFFFFF )
prefiltered = RemoveGrain(source,22)
super = MSuper(source,hpad=16, vpad=16, levels=1) # one level is enough for MRecalculate
superfilt = MSuper(prefiltered, hpad=16, vpad=16) # all levels for MAnalyse
backward = MAnalyse(superfilt, isb = true, blksize=16,overlap=4,search=3,dct=0)
forward = MAnalyse(superfilt, isb = false, blksize=16,overlap=4,search=3,dct=0)
forward_re = MRecalculate(super, forward, blksize=8, overlap=2, thSAD=100)
backward_re = MRecalculate(super, backward, blksize=8, overlap=2, thSAD=100)
#This is alternative way to double the number of frames.
#double = SmoothFPS2 (source,threads)
double = source.MFlowFps(super, backward_re, forward_re, num=VidNum*2, den=VidDen, blend=false)
double = showdot ? double.subtitle("***") : double
test=ShowMetrics(source)
#Generate a white or black frame, depending on frame difference
BWMask=GenerateMask(source)
#Generate the 2x framerate mask needed to choose the motion-estimated frames
themask = interleave(BlackFrame,trim(BWMask,1,0))
#Merge double framerate from original with motion-esimated frames, but only where there are jumps
#(i.e., original frames are used except at jump points)
# *** NOTE *** mt_merge does NOT produce a clean merge, and the dups are slightly altered from the originals -- unable to fix
interleave(source,source).mt_merge(double,themask,luma=true,U=3,V=3)
#Decimate half of all frames
RequestLinear
tdecimate(display=false,debug=false,mode=1,Cycle=DupCycle*2,CycleR=DupCycle,vfrdec=1,sdlim=0)
#Alternate decimation -- should work, but doesn't
#tdecimate(display=false,debug=false,mode=2,rate=59.94006,maxndl=19,m2PA=true)
#Alternate ways to end the script. Must assign variable to tdecimate output instead of using implied "last."
#prefetch(threads)
#return test
#Stacked view, for debugging
#return stackvertical(source,decimated)
#End Main Program
#Begin Functions
#This function displays the YDiff value that will be used for detecting big jumps
#Each YDiff must eliminate Ydiff~=0 (i.e., a duplicate) from moving average
#This is why there are three lines for each YDiff. Each block uses the next or preceeding
#frame, if the current YDiff is near zero, indicating a dup.
#Note: This function works just fine
function ShowMetrics (clip c)
  fixed=source.ScriptClip("Subtitle(String(
    \ (( (YDifferenceFromPrevious(selectevery(source, 1, 2)) < 0.3 ?
    \       YDifferenceFromPrevious(selectevery(source, 1, 3))  :
    \       YDifferenceFromPrevious(selectevery(source, 1, 2)) )
    \    (YDifferenceFromPrevious(selectevery(source, 1, 1)) < 0.3 ?
    \     YDifferenceFromPrevious(selectevery(source, 1, 2))  :
    \     YDifferenceFromPrevious(selectevery(source, 1, 1))  )
    \    (YDifferenceFromPrevious(selectevery(source, 1, -1)) < 0.3 ?
    \     YDifferenceFromPrevious(selectevery(source, 1, -2))  :
    \     YDifferenceFromPrevious(selectevery(source, 1, -1))  )
    \    (YDifferenceFromPrevious(selectevery(source, 1, -2)) < 0.3 ?
    \     YDifferenceFromPrevious(selectevery(source, 1, -3))  :
    \     YDifferenceFromPrevious(selectevery(source, 1, -2))  )
    \     )/4) /
    \    (YDifferenceFromPrevious(source) + 0.01)
  return fixed
#This function returns a white clip whenever a big jump is detected; otherwise a black clip is returned
#Each YDiff must eliminate Ydiff=0 (duplicate) from moving average.
#Since the first two frames of the clip have no preceding frame, don't return a mask
#for those two frames (which means there will be no fix for the first two frames)
#This function works just fine (i.e., really great detection)
function GenerateMask (clip c)
  MyMask=c.ScriptClip("""
    \     )/4) /
    \    (YDifferenceFromPrevious(source) + 0.01) <= JumpThresh
    \  && current_frame > 2
    \ ? WhiteFrame : BlackFrame """)
  return MyMask
#This function is hard-wired for 60 fps. Not worth the time to generalize it, since SVP
#didn't seem to provide a huge benefit over MVTools2, although it should be faster.
function SmoothFPS2(clip source, threads) {
  super_params="{pel:2,gpu:1}"
  analyse_params="""{
        block:{w:16,h:16},
	main:{search:{coarse:{distance:0}}},
	refine:[{thsad:200}]
  smoothfps_params="{rate:{num:120,den:60,abs:false},scene:{mode:0,limits:{scene:8500}},algo:21,cubic:1}"
  super =   SVSuper(source,super_params)
  vectors = SVAnalyse(super, analyse_params)
  SVSmoothFps(source,super,  vectors,  smoothfps_params,  url="www.svp-team.com",  mt=threads)
Old 27th October 2021, 23:55   #2  |  Link
poisondeathray
It looks like "video" white is used, ie., Y=235; not Y=255
Same for "black" . Y=16, not Y=255
You can use expr("255", "128", "128") to make it full white in 8bit YUV or coloryuv(preset="TV->PC") , not sure which is faster, probably expr .
Old 28th October 2021, 02:31   #3  |  Link
johnmeyer
Thanks for that. I started to try out your suggestion by adding a levels statement (e.g., levels(255,1,255,255,255)) when all of a sudden the script wouldn't work. After ten wasted minutes I decided to re-boot (Win XP 32-bit). The script started working again (with the problems reported above, of course).
This means I am chasing memory leak problems as well.
I like AVISynth and I appreciate open source, but it sure can be fragile at times.
Oh yes, the levels(255,1,255,255,255) and levels(0,1,0,0,0) statements did not fix the problem.
global BlackFrame = BlankClip( source, Color=$000000 ).levels(0,1,0,0,0)
global WhiteFrame = BlankClip( source, Color=$FFFFFF ).levels(255,1,255,255,255)
TDecimate, with display=true still had non-zero metrics for the dups created by the
statement. If I change that to just interleave(source,source), without the mt_merge, TDecimate shows 0.00 for the dups, as it should.
If I end up having to create my own decimation workflow outside of AVISynth, exporting metrics and then importing a decimation override file, it will be much more important to have these metrics be zero.
Old 28th October 2021, 02:36   #4  |  Link
videoh
Useful n00b
Is there a link to a description of Didée's idea?
Old 28th October 2021, 02:38   #5  |  Link
poisondeathray
For the mask part, if you wanted to use levels, it would be this for 8bit YUV
BlackFrame = BlankClip( source, Color=$000000 ).levels(16,1,235,0,255,false)
WhiteFrame = BlankClip( source, Color=$FFFFFF ).levels(16,1,235,16,235,false)
Old 28th October 2021, 02:53   #6  |  Link
johnmeyer
Yes.
https://forum.doom9.org/showthread.p...24#post1409324
I completely changed the detection logic not only because his wasn't very good, but also because there was no way to display the detection metrics. If you can't display them, you can't tune the script.
Old 28th October 2021, 02:58   #7  |  Link
videoh
Useful n00b
Thank you.
Old 28th October 2021, 03:00   #8  |  Link
johnmeyer
I've shut down for the day, but I'll try that tomorrow. I obviously took your advice the wrong way around. (255 instead of 235, etc.)
Old 28th October 2021, 10:18   #9  |  Link
Yes.
I was playing with this (above Didee link mod) a few weeks back (I think I left it in working order, but not sure),
# DeDecimateNtsc24BackTo30.avsi
Function DeDecimateNtsc24BackTo30(clip c,Bool "ShowDot") {
    DeDecimateNtsc24BackTo30.avsi : Mod to Script function by StainlessS. Original script by Didee @ https://forum.doom9.org/showthread.php?p=1409324#post1409324
    required, AVS v2.60/+, Pinterf mt_masktools, Pinterf mvtools2, Pinterf tivtc.
    Source should be NTSC_FILM(23.976p) that has been decimated from original PROGRESSIVE_NTSC_STANDARD(29.97p).
    c    myName="DeDecimateNtsc24BackTo30: "
    ShowDot = Default(ShowDot,False)        # shows a "dot" on the interpolated frames of the result
    o  = assumefps(1.0)        # Avoid frame doubling rounding issues, due to weird NTSC framerates.
    ox = o.width() oy=o.height()
    Assert(!c.IsRGB && c.IsPlanar,myname+"Planar YUV only")
    try { bpc=c.BitsPerComponent } catch(msg) { bpc=8 }
    Assert(8 <= bpc <= 16,myname+"8 to 16 bit only")
    super  = (showdot ? o.subtitle(".") : o).MSuper(pel=2,hpad=16,vpad=16)
    bvec   = MAnalyse(super, overlap=4, isb = true,  search=4, dct=5)
    fvec   = MAnalyse(super, overlap=4, isb = false, search=4, dct=5)
    double = o.MFlowFps(super, bvec, fvec, num=2, den=1, blend=false)                                         # Result will be 2.0 FPS, and FrameCount=(c.FrameCount*2)-1. Dont Blend at SceneChange.
    shftn = BitLShift(1, bpc-8)
    cs256 = BitLShift(256,shftn)
    cs255 = cs256-1
    cs128 = BitLShift(128,shftn)
    cs32  = BitLShift(32,shftn)
    d2n_yexpr="x " + String(cs128) + " - abs " + String(cs32) + " / 1 2.0 / ^ " + String(cs128) + " *"        # [8-Bit]:- rpn="x 128 - abs 32 / 1 2.0 / ^ 128 *" : Infix="( (abs(x-128)/32) ^ (1/2.0) ) * 128"
    diff2next = mt_makediff(o,o.selectevery(1,1)).mt_lut(d2n_yexpr,U=-(cs128),V=-(cs128))
    diff2next = mt_lutf(diff2next,diff2next,yexpr="x",mode="average").pointresize(32,32)
    diff2next = interleave(diff2next.selectevery(4,0).tsg(2),diff2next.selectevery(4,1).tsg(2),
        \  diff2next.selectevery(4,2).tsg(2),diff2next.selectevery(4,3).tsg(2))
    maximum = diff2next.mt_logic(diff2next.selectevery(1,-3),"max")
        \  .mt_logic(diff2next.selectevery(1,-2),"max")
        \  .mt_logic(diff2next.selectevery(1,-1),"max")
        \  .mt_logic(diff2next.selectevery(1, 1),"max")
        \  .mt_logic(diff2next.selectevery(1, 2),"max")
        \  .mt_logic(diff2next.selectevery(1, 3),"max")
    ismax_yexpr = "x y < 0 " + String(cs255) + " ?"                                                           # [8-Bit]:- rpn = "x y < 0 255 ?" : Infix = "(x < y) ? 0 : 255"
    ismax = mt_lutxy(diff2next,maximum,ismax_yexpr,U=-(cs128),V=-(cs128)).pointresize(ox,oy)
    themask = interleave(o.mt_lut("0"),ismax)
    interleave(o,o).mt_merge(double,themask,luma=true,U=3,V=3)                                                # Process U and V
    tdecimate(mode=1,cycleR=3,cycle=8)        # Decimate 3 out of 8 = 18 out of 48 (leaving 24 from 48)
    assumefps(30000,1001)        # Back to NTSC_Video
    return last
# tsg by Didee @ https://forum.doom9.org/showthread.php?p=1409324#post1409324
#  ssS: Looks like some kind of limited Gausian Temporal Soften.
#       TemporalSoften (clip, int radius, int luma_threshold, int chroma_threshold, int "scenechange", int "mode")
#       Radius=1=Adjacent_frames, Luma_threshold=255=no limit, chroma_threshold=0=dont process, scenechange=255=ignore, mode=2=ISSE
function tsg(clip c, int t) { c
t<5?last:last.temporalsoften(1,255,0,255,2).merge(last,0.25)
t<4?last:last.temporalsoften(1,255,0,255,2).merge(last,0.25)
t<3?last:last.temporalsoften(1,255,0,255,2).merge(last,0.25)
t<2?last:last.temporalsoften(1,255,0,255,2).merge(last,0.25)
t<1?last:last.temporalsoften(1,255,0,255,2).merge(last,0.25) }
EDITED: [there were two instances where I had not changed csLev128 to cs128]
EDIT: 8 -> 16 bit depth.
Old 28th October 2021, 16:19   #10  |  Link
VoodooFX
Banana User
VoodooFX's Avatar
I had problems too with TDecimate. To avoid drops I do real-fps *3 video, and TDecimate just sometimes drops non-duplicate frame when duplicate is just next one.
VoodooFX is offline   Reply With Quote
Old 28th October 2021, 18:20   #11  |  Link
There is also this Doggie-Doo mod of Didee / JohnM script[FillMissing]:- https://github.com/Dogway/Avisynth-S...llMissing.avsi
As well as JKyle mod [with wrong black/white frame colors]:- https://forum.doom9.org/showthread.p...24#post1947624
EDIT: Doggy uses Color_YUV=$000000, and Color_YUV=$FFFFFF which are also a bit wrong,
should be (for 8 bit ONLY)
Black = BlankClip( source, Color_yuv=$008080 )
White = BlankClip( source, Color_yuv=$FF8080)
[color_YUV AVS+ only]
Maybe use (where masktools 2 used already)
Black=source.mt_lut("0")
White=black.mt_Invert() # OK for HBD, eg 16 bit Y becomes $FFFF, not $FF00 (FULL WHITE required for Mt_merge mask).
Old 28th October 2021, 18:39   #12  |  Link
poisondeathray
This is the fastest, least overhead method to generate a black or white YUV "blankclip" with the "source" characteristics - compared to expr, levels, coloryuv, mt_lut
Old 28th October 2021, 18:45   #13  |  Link
May be for 8-bit only, but did you see this,
And its only really done the once, not at every frame so speed hardly matters at all.
Old 28th October 2021, 18:52   #14  |  Link
Dogway
If your mask is $FFFFFF you can set luma=false which might be faster
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
Old 28th October 2021, 19:08   #15  |  Link
Cheers Doggggy, did not know what that one was for.
EDIT: Luma=false = default.
mt_merge
bool luma = false
luma is a special mode, where only the the first plane (luma or red plane) of the mask is used to process all three channels.
Note: when luma=true, it forces chroma processing (chroma="process" or u=3, v=3).
Old 28th October 2021, 19:23   #16  |  Link
Dog,
this defo dont look right to me,
    BWMask = ScriptClip("
            YDif1 = YDifferenceFromPrevious(src8,2)
            YDif1 = YDif1 < 0.2 ? YDifferenceFromPrevious(src8,3)  : YDif1
            YDif2 = YDifferenceFromPrevious(src8,1)
            YDif2 = YDif2 < 0.2 ? YDifferenceFromPrevious(src8,2)  : YDif2
            YDif3 = YDifferenceFromPrevious(src8,-1)
            YDif3 = YDif3 < 0.2 ? YDifferenceFromPrevious(src8,-2) : YDif3
            YDif4 = YDifferenceFromPrevious(src8,-2)
            YDif4 = YDif4 < 0.2 ? YDifferenceFromPrevious(src8,-3) : YDif4
            YDiff = ((YDif1 + YDif2 + YDif3 + YDif4) / 4.0 ) / (YDifferenceFromPrevious(src8,) + 0.01) <= JumpThresh ? \
        source.White : \
        source.Black   \
            ",args="src8,JumpThresh,Black,White")
I'm gonna steal some of that, but with some changes.
what is source.White and Source.Black, Source not visible inside scriptclip, and source.White dont make a lot of sense (to me).
What is assign to YDiff supposed to do, and why do you just return Last, ie src8 of input.
Old 28th October 2021, 19:37   #17  |  Link
Dogway
I noticed it. Fixed already!!
Old 28th October 2021, 19:45   #18  |  Link
Good dog, now that is worth stealing.
Old 28th October 2021, 20:36   #19  |  Link
zorr
You need Pinterf's version of MVTools, v2.2.7 or later.
**v2.2.7 (20170421)
- fix: mt_edge 10,12,14 bits: clamp mask value from 65535 to 1023 (10 bits), 4095 (12 bits) and 16383 (14 bits)
- fix: mt_merge 10-16 bits + non mod-16 width + luma=true + 4:2:2 colorspace, correct right side pixels
- fix: mt_merge 8 bit clips: keep original pixels from clip1/2 when mask is exactly 0 or 255
zorr is offline   Reply With Quote
Old 28th October 2021, 20:59   #20  |  Link
poisondeathray
For different bit depths blackclip(souce).expr should be faster than source.mt_lut; both will "flexible" in terms of bitdepth and correct on inverting
expr("0", "x", "x") for copy u,v and expr("0", "range_half", "range_half") for half uv at source bitdepth
source=("random 1080p source")
black = source.mt_lut("0").killaudio()
#black = blankclip(source).expr("0",  "range_half",  "range_half"").killaudio()
#black = blankclip(source).expr("0",  "x",  "x").killaudio()
#black = blankclip(source).mt_lut("0").killaudio()
black
8bit source benchmarks , fps, cpu%, no prefetch
(I believe expr is optimized with avx2 instructions, but it didn't make much of a difference on these benchmarks with SetMaxCPU("sse4.1") for this operation )
ffmpeg -i mt_lut.avs -f null NUL
285fps, 60%
ffmpeg -i blankclip_expr_uv_range_half.avs -f null NUL
1060fps, 25%
ffmpeg -i blankclip_expr_uv_copy.avs -f null NUL
1010fps, 25%
ffmpeg -i blankclip_mt_lut.avs -f null NUL
490fps, 22%
Eitherway, you're right it should have limited impact speedwise on John's specific script (it's not going to be the part that is the "bottleneck")
Do you need to copy the chroma channels for the mask ? Really you only need "Y" plane 100% white or 100% black. It might be slightly faster to do it in Y or Gray for the mask part, instead of YUV (discard instead of dragging the chroma channels along)
drops, duplicates, tdecimate
