Old 3rd September 2021, 07:22   #1  |  Link
tonemapped
Video Fanatic
tonemapped's Avatar
Chroma subsampling : 4:2:0 (Type 1 / Type 0)
I've been experimenting with DVDFab for Blu-ray to x265 (I'm happy with a CLI but find tools with GUIs fun to play around with, like Staxrip - never Handbrake as it's horrible) conversion and found - annoyingly, after converting about a dozen films - an oddity with the output.
For some reason, the blacks are washed out and I believe it's down to the chroma subsampling it's using.
Partial mediainfo output (I know it's 8-bit which I wouldn't normally choose for HEVC).
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4@Main
Codec ID : V_MPEGH/ISO/HEVC
Color space : YUV
Bit depth : 8 bits
Color range : Full
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
I believe the part marked in bold is the cause of the problem. I've never encountered an issue with 4:2:0 Type 1/0 so not entirely sure what's going on. Is this something that can be fixed without encoding the Blu-rays again (e.g. a flag in mkvmerge)? As I don't seem to have this issue with x264, is it related to that in some form?
Here's a simple demonstration of the issue - the grey area should be black.
Direct link to png: https://i.ibb.co/CHfwnwZ/dvdfab-outp...roma-issue.png
Any thoughts on the matter are much appreciated.
PC: R9 5900X | 32GB 3600 MT/s RAM | 2*1TB NVMe | RTX 3080 | water-cooled
NAS: SM 48-bay 240TB+ storage | Xeon 1220 | 32GB DDR4 ECC
HTPC: Pentium J5005 | 16GB RAM | 256GB SSD | 15W
tonemapped is offline   Reply With Quote
Old 3rd September 2021, 19:18   #2  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I think color range should be limited instead of full. If it's encoded with the wrong settings, it needs to be redone to correct it.
Old 3rd September 2021, 19:35   #3  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
For 4K UHD I recommend that you always encode in 10-bit, not 8-bit...
But as with any re-encoding it all depends on your characteristics of your source content.
Old 4th September 2021, 00:07   #4  |  Link
tonemapped
Video Fanatic
tonemapped's Avatar
Yep, how silly - totally missed that. Cheers for pointing it out.
Old 16th September 2021, 09:50   #5  |  Link
Balling
This is a latest experiment from myself and Jan in ffmpeg: we pass through chroma location. So if you have a jpeg image that (all jpeg does) uses center location it will pass through center to chroma loc in hevc VUI in SPS. Alas it looks like it effs up on R'G'B' JPEGs.
Balling is offline   Reply With Quote
Old 17th September 2021, 19:00   #6  |  Link
benwaggoner
Well, R'G'B' doesn't have chroma positions, so it should be a straightforward fix.
And excellent progress! This will be a very welcome feature.
Ben Waggoner
My Compression Book
Old 19th September 2021, 10:21   #7  |  Link
Balling
First of call R'G'B' can be subsampled in JPEG, yeah. In many, many different ways. https://trac.ffmpeg.org/ticket/8930#comment:4 Second of all it just always assumes center since that is the only way for jpeg, it is globally tagged, even for not subsampled R'G'B', which is wrong of course.
chroma subsampling, x265
