#20143 | Link | |
Posts: n/a
Don't worry about how much bigger it is than the original !! This is the one I used... https://github.com/jpsdr/x264/releas..._tmod_r3107.7z |
#20144 | Link | |
There are 3 folders, which one? edit used winthread's folder, we'll see edit 2 first grey frame gone, second gray frame is there
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B Last edited by slalom; 14th May 2023 at 17:28. |
#20146 | Link |
Emm no
x264 for x264 and x265 for x265 I don't mix them found a x264_x64.exe file on my backup from 3/19 will try that
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
#20147 | Link | |
Posts: n/a
![]() Since when is x264 for x264 and x265 for x265, you can do what you like with either !! You couldn't even be bothered "testing" with x265, if only to see if the grey frames were still visible. And it looks like you completely ignored Atak's suggestion. |
#20149 | Link |
Posts: n/a
Audio re-encoding when using Segments...
@ Atak,
I realise why the audio needs to be re-encoded after a "Segment's" edit, but unfortunately, if the clip has a TrueHD, FLAC, (or other) audio track(s), then there is no way to retain that, it's either OPUS, AAC or AC3. Without the "Segment's" edit, you simply use "X.X Copy Stream" to retain those types of audio. Is there some way, somehow that these can be re-encoded, or retained ?? |
#20150 | Link |
ok, as the work hours function doesnt work and using distributed encoding in 2-pass keeps undersizing, is there a way to manually input a schedule into windows schedular that will wake the PC then run ripbot and start encoding?
#20151 | Link |
Wanted to report a bug in the latest version.
On the stream selection screen when I choose which audio tracks I want to use from the bluray playlist I want to convert I noticed the radio buttons for the audio three tracks (the ones that let you choose to demux, wave, flac or core) are interconnected. So if you pick 3 different audio streams you can only select the option on one of them and can't choose a different one for each audio track as the selection always moves to the last one you picked even if it's on a different audio track. |
#20152 | Link | |
Posts: n/a
#20153 | Link | |
Movies SMDegrain fails on, source FGT: Bad Boys 2 (2003) Fantastic Four (2015) Logan (2017) |
#20154 | Link | |
Posts: n/a
![]() Yeah, not too sure what's going on there, I haven't had that issue (but then I probably haven't got those video's) All I can suggest is run it thru MKVToolNix, strip out everything but the video track, and see what RB does with it. I quite often I only run video thru RB, and mux everything back, afterwards. If that works, try it with the audio & sub's (if wanted), and try again. Good luck. |
#20155 | Link | |
#20156 | Link | |
#20157 | Link | |
Posts: n/a
I haven't had any issues, tho. Last edited by TDS; 20th May 2023 at 02:49. |
#20158 | Link |
No. I usually have a couple months between uses of Ripbot and the last time I used it was probably around January/February. I was always able to select the options for each audio track independently. With the latest build you can only select an option for one audio track and the options for the other audio tracks get deselected.
#20159 | Link |
I've had some issues like that using smdegrain where it bombs out before starting the encode with the missing info.txt error. I usually always just do an auto-crop on everything. Don't have the exact cause but it seems to be something with the aspect ratio after the auto-crop takes place. Sometimes if the auto-crop brings up an odd ball aspect ratio, say like 2.395:1 instead of a normal 2.4:1 it happens. not all the time, but occasionally. Most of the time I can fix it with resizing to the closes standard aspect ratio which really doesn't effect the end result.
Or if it is something really not close to a standard after the autocrop that gives me an aspect ratio that when divided gives me a partial pixel height with a decimal point. If i custom resize it and round up or down on the height to a full number, I have had that work then as well. I have only had maybe a couple that just would not run with smdegrain, so i just ran them through mdegrain and called it a day. |
#20160 | Link | |
Posts: n/a
Can you check what version you currently have ?? And I am assuming that you have autoupdate enabled... Do you have access to the previous version, so you get this function back ?? I'd say that this is possibly something Atak will have to address. |
| Tags |
| 264, 265, appletv, avchd, bluray, gui, iphone, ipod, ps3, psp, ripbot264, x264 2-pass, x264 gui, x264_64, x265, xbox360 |
| Display Modes | |
