Old 6th May 2016, 04:41   #1  |  Link
Ansii
ffmpeg +video packets
I am encoding video files using ffmpeg ,H.264 encoding.
Now I have to send this encoded video files as packets to other system
using Udp protocol. ( also use public ip).
I also have to create some network congestion while I send these packets. When there is more congestion have to change the Qp parameter(quantization parameter) as the bandwidthe be less due congestion.
Then resend these packets which uses new QP .
Can anyone give a clue on how to do this.
how to send a encoded video file as packets over the internet.
Ansii is offline   Reply With Quote
Old 6th May 2016, 15:30   #2  |  Link
Ansii
How can I packetize and send the encoded video file to a diffrent system?
[{( If I decode a video into a sequence of frames and send it and recreate it using fffmpeg?
Then what will happen to the encoding.
Is this completely dumb approach? )}]
encode, h.264 encoder, quantisation parameter, video packets ffmpeg
