Thread Tools Display Modes
Old 4th March 2019, 19:34   #21  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by Jamaika View Post
The color format doesn't work. After removing the command, I have it.
I can be wrong, but it seems this type of problem is "inevitable" when the current source-code is compiled for Windows with GCC:
https://github.com/intel/SVT-HEVC/is...ment-468867836
filler56789 is offline   Reply With Quote
Old 4th March 2019, 20:10   #22  |  Link
Jamaika
It isn't true that GCC is guilty.
I've compiled svt encoder myself. Strange, for BPG libsvt works, in encoder svt doesn't want to.
Jamaika is offline   Reply With Quote
Old 4th March 2019, 20:26   #23  |  Link
filler56789
SuperVirus
I DIDN'T say it's GCC's fault, I said and meant the current source-code is messy :-/
Old 5th March 2019, 08:01   #24  |  Link
Jamaika
I will not clutter up the topic. I'll wait for the corrections. In general, I have a hard time compiling the App with GCC. GCC enforces static headers in the APP otherwise the information is duplicated with libsvt.
Old 5th March 2019, 08:54   #25  |  Link
dipje
AFAIK the svt encoder only supports a few specific input formats :
https://github.com/intel/SVT-HEVC/bl...t-video-format
Svt encodes to raw hevc streams on my system, so I have to mux it and set framerate there.
The fps parameters on the cli are (I guess ) only to specify framerate of the input for things like calculating bits per second (so it needs to know how many frames in a second ).
I don't know, but do raw elementary hevc streams even have a fps field somewhere ?
dipje is offline   Reply With Quote
Old 5th March 2019, 10:06   #26  |  Link
sneaker_ger
AVC and HEVC have vui_num_units_in_tick and vui_time_scale.
Old 5th March 2019, 14:14   #27  |  Link
Jamaika
Can somebody test how this SVT-HEVC survives famous park_joy_1080p50.y4m ?
My test codec by encoder BPG SVT.
At the moment the only way I could use.
yuv420p->RGB24->yuv420p
SvtHevcEncApp1.exe -i park_joy_1080p50.y4m -w 1920 -h 1080 -vid-info 1 -fpsinvps 1 -rt 0 -lp 0 -ss -1 -dolby-vision-rpu 0 -tune 2 -profile 1 -tier 0 -hme 1 -sao 0 -dlf 1 -brr 1 -bit-depth 8 -fps 50 -asm 0 -encMode 9 -tbr 70000 -compressed-ten-bit-format 0 -max-qp 48 -min-qp 10 -use-default-me-hme 1 -search-w 16 -search-h 7 -n 0 -q 30 -dolby-vision-profile 0 -max-cll 0 -max-fall 0 -use-master-display 0 -inj-frm-rt 60 -temporal-id 1 -sharp 1 -lad 17 -scd 1 -interlaced-video 0 -color-format 1 -base-layer-switch-mode 0 -pred-struct 0 -irefresh-type 2 -intra-period -2 -hierarchical-levels 3 -b park_joy_1080p50_QP30_tune2_hier3_base0_pred0.h265
https://www.sendspace.com/file/yf2ht7
Conclusion:
We don't use option PredStructure greater than zero. Tune 2 it's VMAF.
Old 5th March 2019, 16:17   #28  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Conclusion:
Well I was expecting something around 5Mbps not those insane 30Mbps. At such high bitrate even x264 shines.
Old 5th March 2019, 19:01   #29  |  Link
Jamaika
For grumpy here they are:
https://www.sendspace.com/filegroup/...GMHiESUyp2aEtw
Old 5th March 2019, 19:21   #30  |  Link
Atak_Snajpera
Pathetic quality! x264 destroys this HEVC encoder easily!
https://www.mediafire.com/file/dmbhg...ormal.mkv/file
Old 5th March 2019, 19:42   #31  |  Link
Jamaika
I don't comment on it. I am proud that I could compile myself and show off my waste of time. I will leave the rest to the professionals.
Old 1st June 2019, 08:30   #32  |  Link
Jamaika
- new fixes for codec SVT HEVC 2019.06.01
Despite few amendments. Generally codec is a bit neglected in relation to SV1 AV1. The codec still has visible errors. There are pink spots of pixels.
svt_hevc.exe -i 111.yuv -b auto_svt.h265 -tile_row_cnt 1 -tile_col_cnt 1 -w 1280 -h 720 -n 0 -bit-depth 8 -umv 1 -fpsinvps 1 -level 0 -tier 0 -fps-num 30000 -fps-denom 1001 -temporal-id 0 -asm 0 -rc 0 -tbr 3000000 -qp-file 32 -max-qp 48 -min-qp 10 -search-w 16 -search-h 7 -hme 1 -use-default-me-hme 1 -sao 0 -dlf 1 -tune 2 -interlaced-video 0 -compressed-ten-bit-format 0 -color-format 1 -encMode 0 -vid-info 1 -sharp 0 -irefresh-type 1 -hierarchical-levels 0 -base-layer-switch-mode 0 -intra-period 31 -pred-struct 2 -constrd-intra 1 -profile 1 -hdr 0
https://www.sendspace.com/file/z9xqvl
Old 11th June 2019, 17:19   #33  |  Link
benwaggoner
How did you tune it? There's approaching x265-like configurability in SVT-HEVC. Lots of psychovisual options, lots of quality/speed tradeoffs.
Ben Waggoner
My Compression Book
Old 24th July 2019, 07:25   #34  |  Link
GrandAdmiralThrawn
GrandAdmiralThrawn's Avatar
Assembly code paths
I compiled x265_svt with my own way:
i.e. I delete AVX and leave only SSE2.
Could you elaborate on how you did that? I tried the same thing, but all I managed to do was to disable assembly optimizations altogether, making --asm 0 the default and running it on non-AVX, non-NUMA machines after a bit of patching. But that appears to be pure C code now.
Even the NONAVX2 codepath (--asm 1) seems to depend on AVX in some way. Or maybe it depends on YMM/ZMM registers or the OS XSAVE instruction being present, I don't know. Can't speak C or x86 assembly properly.
Edit: Or maybe it's Visual Studio 2017 at fault here?
What I would like to do is to create a build that runs with SSE2 or SSSE3 or SSE4.2 selectively, so I can do non-NUMA specific builds for older CPUs, while retaining as many optimizations as possible.
Thank you!
Proud owner of a 3dfx Voodoo5 6000 AGP HiNT Rev.A-3700 prototype
No RISC, no fun!
GrandAdmiralThrawn is offline   Reply With Quote
Old 24th July 2019, 21:00   #35  |  Link
Jamaika
I have changed some implementations a bit. I had to turn off the SIMD (SSE3, SSE41, AVX, AVX2, AVX512)
I could not use assembler in GCC. So some of the functions do not work, i.e. SAO.
It should be added that x265_svt is only 8bit 420yuv.
I also changed the functions of svt in param.cpp
Added opensource for GNU and codec video with file .bat
https://www.sendspace.com/filegroup/...fwx7MXSw%2B6nA
How do you think that you will do better? You have other ideas. Share your knowledge.
Old 29th July 2019, 17:39   #36  |  Link
Shevach
Video compressionist
How to configure SVT-HEVC to generate closed GOPs with SPS/PPS?
i tried the following command line to generate closed GOP (= 30 frames):
./SvtHevcEncApp -i container_384x320.yuv -w 384 -h 320 -encMode 6 -intra-period 29 -fps 30 -rc 1 -tbr 500000 -umv 0 -irefresh-type 2 -lad 2 -pred-struct 2 -hierarchical-levels 0 -ua-delm 1 -b test.h265
However, upon inspection of the generated stream i found that all IDRs (excepting the very first one) are not accompanied with SPS/PPS and hence can't serve as a random access point.
Shevach is offline   Reply With Quote
Old 29th July 2019, 18:06   #37  |  Link
Jamaika
Use the function:
-irefresh-type 2 -hierarchical-levels 0 -base-layer-switch-mode 0 -intra-period 29 -pred-struct 2
// GOP Structure
    /* The intra period defines the interval of frames after which you insert an
     * Intra refresh. It is strongly recommended to set the value to multiple of
     * 8 minus 1 the closest to 1 second (e.g. 55, 47, 31, 23 should be used for
     * 60, 50, 30, (24 or 25) respectively.
     * -1 = no intra update.
     * -2 = auto.
     * Deault is -2. */
    int32_t                 intraPeriodLength;
    /* Random access.
     * 1 = CRA, open GOP.
     * 2 = IDR, closed GOP.
     * Default is 1. */
    uint32_t                intraRefreshType;
    /* Flag to code VPS / SPS / PPS.
     * Default is 1. */
    uint8_t                 codeVpsSpsPps;
Old 30th July 2019, 03:12   #38  |  Link
Shevach
@Jamaika
i actually use same command line 'excepting -base-layer-switch-mode 0'. This does not work.
i dived into the source code and found in the main loop (the procedure PacketizationKernel ) the following condition:
if(pictureControlSetPtr->pictureNumber == 0 && sequenceControlSetPtr->staticConfig.codeVpsSpsPps == 1)
According to the above condition VPS/SPS/PPS are generated for the very first frame only.
i replaced the condition with 'if(outputStreamPtr->sliceType==EB_IDR_PICTURE)' and the modified SVT encoder does inserts VPS/SPS/PPS before each IDR. Thus, each IDR is a random access point.
Old 30th July 2019, 04:40   #39  |  Link
Jamaika
Originally Posted by Shevach View Post
@Jamaika
This is true, but they have improved something for frames B with SAO frames. Still bad work compressed-ten-bit-format and hierarchical-levels.
In general the problem frames B and SPS/VPS were reported. The answer was we don't have time for HEVC.
It adds holiday corrections, added new features, but old problems remain.
PS To check the new codecs HEVC, analyzer is useful. Unfortunately the programs are paid.
Old 30th July 2019, 17:18   #40  |  Link
Shevach
i observe a problem in encoding time. Despite i compiled SVT-HEVC with all SSEx and AVX2, for encMode=8 (fast preset) on CIF yuv sequence the encoding speed is around 12fps. The same setting of x265 provides ~50fps.
As per B-frames, there are a wide class of low-latency applications (e.g. cloud gaming) where B-frames are irrelevant and not used.
My main concern is low encoding time of SVT-HEVC comaring to that of x265.
Thread Tools
