17th February 2019, 00:06 | #1 | Link |
Intel SVT-HEVC encoder
hi, anyone tested this one? and benchmarked it with speed vs. quality (VMAF 95ish) ?
https://github.com/intel/SVT-HEVC https://www.phoronix.com/scan.php?pa...Speed-Progress Reading this : https://01.org/sites/default/files/d...sual_cloud.pdf SVT-HEVC achieves similar quality levels to those of HM16, while being 70:1 faster, and similar quality levels to those of x265 very slow, while being 176:1 faster. Quite the statement Last edited by TEB; 17th February 2019 at 00:59. |
18th February 2019, 21:18 | #2 | Link |
It doesn't have as deep tuning parameters as x265, but offers subjective quality optimization and deeper reference frame hierarchy. And they even have subjective DMOS scores!
I don't see at what bitrates the comparisons are made, though. If at really high bitrates, it's not that exciting to say "subjective quality is similar to other encoders." Testing should be done in the range so that the very best encode has at least a Just Noticeable Difference from the source. Thus the codecs are demonstrating at bitrates where "perfect" isn't obtainable, and we can see the tradeoffs and blind spots of each. Also, I am reminded that x265 still doesn't include --tskip in veryslow or placebo. Stock "veryslow" still has more juice to squeeze out (although at further cost of speed). I'm guessing this test used pre 3.0 x265, so the performance difference compared to 3.0's veryslow would be even bigger. |
19th February 2019, 16:06 | #3 | Link |
x265 can now also use SVT
http://x265.org/x265-svt-hevc-house/ |
20th February 2019, 08:42 | #4 | Link |
I've done a very short (and wrong ) test with 1.3 compiled into ffmpeg 4.1.
I've re-encoded a 5 second clip Sony 1920x1080 25fps h264 +/- 50mbit slog2 that had a small object moving fast. As a baseline tried starving the codecs a bit. X264 preset slow, two pass 500k bitrate, yielded a VMAF +/- 76. X265 preset medium two pass 500k bitrate, yielded a VMAF +/- 86 (but was slower to encode ) Libsvt_hevc vbr to actually hit around 600k (single pass always ) , yielded a VMAF of +/- 75. Tried again in cqp mode , changing the qp to hit a bitrate of about twice that. Than tried x264 in preset slow with CRF mode, adjusting the CRF value to get a final filesize that is just under the libsvt one. Svt hit VMAF of 80, x264 VMAF of 86. So, this isn't a serious test at all. Just a little start for me. The clip is too short, it's ungraded, VMAF doesn't tell you all there is, etc... But svt seems fast but sacrifices Soo much in the quality that x264 can match it for not that much slower. It's a software only solution that encodes real-time easily on my 8-series i5 ultrabook...but does not offer Soo much value for 1920x1080 for me it seems. Again, wrong test so don't take it for granted . Files with proper contrast and 4k would be a much more interesting case. |
22nd February 2019, 21:35 | #5 | Link | |
For example, one could use --tune psnr in x264, x265, and SVT-HEVC. That would give some insight into how many tools and modes the encoder tries. Although it would look worse than your tests, so it would be more interesting than applicable. It'd be good to try some longer clips to get a sense of the speed delta. I note that per the updated x265 docs for svt, that it has two modes SLOWER than the placebo equivalent. |
23rd February 2019, 22:17 | #6 | Link |
so people are actually getting respectable quality out of SVT-HEVC? And then I don't mean that it must match or best x265, but I at least expected it yield better quality than x264-software encoder running at comparable speeds.
I tried again with a slog2->rec709 lut on there and preparing the file to be 25fps and a bit longer (30 seconds), and _visually_ the SVT file isn't that bad actually. It just has a bunch more smoothing on it it seems. So x265 with --no-sao can show small amounts of blocking, while the SVT encode has the blocking smoothed out but otherwise just as enjoyable to watch and the same amount of detail from what I can tell.. Will do my tests with a proper free source and the good old fashioned way of using realistic bitrates and visually inspecting the file to make up my mind |
25th February 2019, 16:03 | #7 | Link |
Can somebody test how this SVT-HEVC survives famous park_joy_1080p50.y4m ?
25th February 2019, 20:21 | #8 | Link |
It would be great if people would share the command lines they're using with SVT-HEVC. There's a ton of configurability in there (not as much as x265, but that's a high bar). Some ones where changing from default is likely to have a significant impact on output quality and performance include:
I am kind of confused about how rate control/quality works here. It seems like optimal quality would be -encMode 0No idea how practical -encMode 0 is for speed; that may need to be adjusted. But the above should give a perceptually optimized capped VBR style encode at or below the bitrate value. |
27th February 2019, 23:04 | #10 | Link |
@TEB: I just grabbed the ffmpeg from git (github, not official but real enough) and did a checkout on the 4.1 release. I picked the last release from the IntelSVTHevc from github and it gave directions to apply a patch to the ffmpeg tree. This patch is made for 4.1 and applied cleanly on my build and compiled fine (Windows 10 but WSL Ubuntu 18.04 install). So I don't really have a build to be shared but it compiles cleanly on Ubuntu 18.04 so I guess it shouldn't be that hard to build it yourself if you're asking for Linux binaries.
@Benwaggoner: Played around a bit with piping yuv420p from ffmpeg into the SvcHevcEncApp utility (specifying number of frames, fps, width and height) and that produced way different results than my earlier ffmpeg tests. I don't know if I just gave wrong parameters in ffmpeg, or the ffmpeg-svthevc wrapper is not passing all parameters correctly but these results were WAAAY more usable on the quality side of things, but also took longer to encode. I can slow SvcHevc right down to 0.5fps on my laptop or up to 88 fps... and it produces results which are more in line with what I expect with those speeds :P. So I'm testing again, my previous results were apparently only on the 'very fast' settings. This makes the encoder way more usable and a 'real encoder' for common use. (it seems it's been made with the idea to run 'always realtime, adjusting itself as it goes to stay realtime' on recent Xeon cores). |
28th February 2019, 08:49 | #12 | Link | ||
{ EB_H265_ENC_CONFIGURATION* svtHevcParam = (EB_H265_ENC_CONFIGURATION*)param->svtHevcParam; //Preset & Tune default svtHevcParam->encMode = 9; // if (!strcmp(preset, "faster")) svtHevcParam->encMode = 9; svtHevcParam->tune = 0; // if (!strcmp(tune, "grain")) svtHevcParam->tune = 0; else if (!strcmp(tune, "animation")) svtHevcParam->tune = 0; ??? // Rate Control default svtHevcParam->frameRate = 60; svtHevcParam->frameRateNumerator = 0; svtHevcParam->frameRateDenominator = 0; svtHevcParam->encoderBitDepth = 8; svtHevcParam->compressedTenBitFormat = 0; svtHevcParam->rateControlMode = 0; svtHevcParam->sceneChangeDetection = 1; svtHevcParam->lookAheadDistance = (uint32_t)~0; svtHevcParam->framesToBeEncoded = 0; svtHevcParam->targetBitRate = 7000000; svtHevcParam->maxQpAllowed = 48; svtHevcParam->minQpAllowed = 10; svtHevcParam->bitRateReduction = 1; /*vmaf is under development, currently x265 won't support vmaf*/ Quote:
if (encoder->m_param->bEnableSvtHevc) { EB_H265_ENC_CONFIGURATION* svtParam = (EB_H265_ENC_CONFIGURATION*)encoder->m_svtAppData->svtHevcParams; if (pic_in) Last edited by Jamaika; 28th February 2019 at 09:15. |
28th February 2019, 12:47 | #13 | Link | |
SuperVirus
r:\make6t4\gccs64\830\bin\../lib/gcc/x86_64-w64-mingw32/8.3.0/../../../../x86_64-w64-mingw32/bin/ranlib.exe: unable to rename '../../../lib/libASM_AVX2.a'; reason: File exists make[2]: *** [Source/Lib/ASM_AVX2/CMakeFiles/ASM_AVX2.dir/build.make:230: lib/libASM_AVX2.a] Error 1 make[2]: *** Deleting file 'lib/libASM_AVX2.a' make[1]: *** [CMakeFiles/Makefile2:403: Source/Lib/ASM_AVX2/CMakeFiles/ASM_AVX2.dir/all] Error 2 make: *** [Makefile:130: all] Error 2 |
28th February 2019, 16:42 | #14 | Link |
Wolfberry has 1.3.0 compiled and in his public share folder
https://drive.google.com/drive/folde...mHKYLzO3elemlC |
28th February 2019, 18:16 | #15 | Link |
I compiled x265_svt with my own way:
i.e. I delete AVX and leave only SSE2. What conclusions: doesn't tolerate colormatrix 2020, high-tier and lacks parameters. Don't add LIBVMAF. Why is main10? How I added 8bit. y4m [info]: 1920x1080 fps 29/1 i420p8 sar 1:1 unknown frame count raw [info]: output file: x265_hightier_crf28_tunegrain.h265 x265 [info]: HEVC encoder version 3.0_Au+8 x265 [info]: build info [Windows][GCC 9.0.1][64 bit][noasm] 8bit SVT [version]: SVT-HEVC Encoder Lib v1.3.0 SVT [build] : GCC 9.0.1 64 bit LIB Build date: Feb 28 2019 16:55:02 ------------------------------------------- SVT [Warning]: Color format EB_YUV400 not supported, set to EB_YUV420 Number of logical cores available: 4 Number of PPCS 107 ------------------------------------------- SVT [config]: Main10 Profile Tier (auto) Level (auto) SVT [config]: EncoderMode / LatencyMode / Tune : 4 / 0 / 0 SVT [config]: EncoderBitDepth / CompressedTenBitFormat / EncoderColorFormat : 8 / 0 / 1 SVT [config]: SourceWidth / SourceHeight : 1920 / 1080 SVT [config]: Fps_Numerator / Fps_Denominator / Gop Size / IntraRefreshType : 29 / 1 / 61 / 2 SVT [config]: HierarchicalLevels / BaseLayerSwitchMode / PredStructure : 3 / 0 / 2 SVT [config]: BRC Mode / QP / LookaheadDistance / SceneChange : CQP / 32 / 17 / 1 SVT [config]: BitRateReduction / ImproveSharpness : 1 / 1 ------------------------------------------- My file only for 8bit. Enjoy. https://www.sendspace.com/file/ki9z14 Last edited by Jamaika; 28th February 2019 at 18:25. |
2nd March 2019, 23:51 | #16 | Link | |
SuperVirus
3rd March 2019, 21:00 | #18 | Link | |
How specific are these to a particular Xeon version? I would think they would get tuned and targeted pretty specifically. I wonder how much benefit profiler-guided optimization would provide. |
4th March 2019, 10:02 | #19 | Link | |
SvtHevcEncApp.exe -i 111.yuv -w 1920 -h 1080 -tune 0 -profile 1 -bit-depth 8 -fps 30000/1001 -asm 0 -encMode 9 -tbr 70000 -compressed-ten-bit-format 0 -b 112.h265 How to add framerate 29.972? How to add color subsample yuv420? encoderColorFormat = EB_YUV420 |
4th March 2019, 17:23 | #20 | Link |
Where is color format in SvtHevcEncApp.exe?
TOKEN DESCRIPTION INPUT TYPE -nch NumberOfChannels Single input -i InputFile Single input -b StreamFile Single input -errlog ErrorFile Single input -o ReconFile Single input -qp-file QpFile Single input -interlaced-video InterlacedVideo Single input -separate-fields SeperateFields Single input -w SourceWidth Single input -h SourceHeight Single input -n FrameToBeEncoded Single input -nb BufferedInput Single input -base-layer-switch-mode BaseLayerSwitchMode Single input -encMode EncoderMode Single input -intra-period IntraPeriod Single input -irefresh-type IntraRefreshType Single input -fps FrameRate Single input -fps-num FrameRateNumerator Single input -fps-denom FrameRateDenominator Single input -bit-depth EncoderBitDepth Single input -compressed-ten-bit-format CompressedTenBitFormat Single input -hierarchical-levels HierarchicalLevels Single input -pred-struct PredStructure Single input -scd SceneChangeDetection Single input -q QP Single input -use-q-file UseQpFile Single input -rc RateControlMode Single input -lad LookAheadDistance Single input -tbr TargetBitRate Single input -max-qp MaxQpAllowed Single input -min-qp MinQpAllowed Single input -dlf LoopFilterDisable Single input -sao SAO Single input -use-default-me-hme UseDefaultMeHme Single input -hme HME Single input -search-w SearchAreaWidth Single input -search-h SearchAreaHeight Single input -constrd-intra ConstrainedIntra Single input -tune Tune Single input -lp LogicalProcessors Single input -ss TargetSocket Single input -rt SwitchThreadsToRtPriority Single input -brr BitRateReduction Single input -sharp ImproveSharpness Single input -vid-info VideoUsabilityInfo Single input -hdr HighDynamicRangeInput Single input -ua-delm AccessUnitDelimiter Single input -pbuff BufferingPeriod Single input -tpic PictureTiming Single input -reg-user-data RegisteredUserData Single input -unreg-user-data UnregisteredUserData Single input -recovery-point RecoveryPoint Single input -max-cll MaxCLL Single input -max-fall MaxFALL Single input -use-master-display UseMasterDisplay Single input -master-display MasterDisplay Single input -dolby-vision-profile DolbyVisionProfile Single input -dolby-vision-rpu DolbyVisionRpuFile Single input -nalu-file NaluFile Single input -temporal-id TemporalId Single input -fpsinvps FPSInVPS Single input -inj Injector Single input -inj-frm-rt InjectorFrameRate Single input -speed-ctrl SpeedControlFlag Single input -profile Profile Single input -tier Tier Single input -level Level Single input -latency-mode LatencyMode Single input -asm AsmType Single input Code:
Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L3.1@Main Codec ID : hvc1 Codec ID/Info : High Efficiency Video Coding Duration : 2 s 880 ms Bit rate : 1 909 kb/s Maximum bit rate : 2 543 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Bits/(Pixel*Frame) : 0.083 Stream size : 671 KiB (100%) Title : h265@GPAC0.7.2-DEV-rev991-gac74c900-master Encoded date : UTC 2019-03-04 16:16:40 Tagged date : UTC 2019-03-04 16:16:40 Codec configuration box : hvcC |
