Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 28th December 2019, 16:41   #61  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffxvid 1.6.2
* Add support for the noise video filter. Can be beneficial on (very) clean sources by applying some noise to avoid things like color/light banding in the encode
Old 23rd February 2020, 15:59   #62  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.6.3
* Use MPlayer for crop detection instead of FFmpeg which seems to have issues with 4k/UHD content
Old 5th March 2020, 22:09   #63  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.6.4
* Go back to FFmpeg for crop detection
Old 9th March 2020, 21:13   #64  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.6.5
* Bugfix: missing if conditional in the crop code
Old 23rd March 2020, 07:11   #65  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.6.6
* Add -max_muxing_queue_size switch to workaround possible issues when muxing Atmos/DTS-X audio
Old 16th June 2020, 20:09   #66  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.6.8
* Support TrueHD audio in the MP4 container
Old 21st June 2020, 16:11   #67  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.6.9
* Fixed a bug that prevents using TrueHD mono audio in the MP4 container
Old 27th December 2020, 19:34   #68  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.7.0
* Fixed a long standing bug where audio mapping values were incorrect for audio metadata resulting in incomplete or wrong values
Old 28th December 2020, 02:51   #69  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.7.1
* Fix a bug in the $vidtrack variable
Old 22nd January 2021, 09:01   #70  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.7.2
* Remove "a" from the -ac audio option
* Fix possible negative index in the audio option
Old 2nd February 2021, 15:07   #71  |  Link
microchip8
microchip8's Avatar
ChangeLlog for ffxvid 1.7.3
* Replace the yadif deinterlacer with bwdif. It's faster and provides higher quality
Old 23rd January 2023, 11:38   #72  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.7.4
* Support more deinterlacing filters
Old 1st February 2023, 09:27   #73  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
I've never used this app, but I'll say thank you for folks who do! I appreciate your efforts
Old 1st February 2023, 10:41   #74  |  Link
microchip8
microchip8's Avatar
Thanks. It's just a Bash shell script I write mainly for myself as I spend many hours working in the terminal on Linux so I need something CLI/terminal-based for encoding too...
Old 17th August 2023, 04:48   #75  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.7.5
* Fix crop detection for HDR content
* Set Lanczos as default scaler option
Old 7th January 2024, 20:24   #76  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.7.6
* Improved compatibility with the BSDs
* Set the setpts + atempo option as default for FPS conversion
* Set side/wide audio channels as default
* Support the newly added channels for TrueHD audio
* Bugfix in the video_noise_func() function
* Improved FPS detection code
Old 4th February 2024, 17:49   #77  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.7.7
* Don't exit but warn about MP4Box/Mplayer missing from the user's system
Old 28th February 2024, 23:16   #78  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.8.0
* Initial support for zimg (z lib) scalers
Old 28th October 2024, 17:17   #79  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.8.1
* Updated the audio copy code to detect Dolby Atmos and use the correct name metadata
* Renamed a few variables
Old 30th October 2024, 21:57   #80  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffxvid 1.8.2
* Reduced duplication in the final audio params code variable
* Use kHz instead of Hz for audio sample rate metadata
* Slightly increased default value of the noise filter
* Updated the AUTHORS file (email address)
