Old 10th November 2020, 10:29   #1  |  Link
Helg1980
Cine Encoder (Windows/Linux)
Program description
Cine Encoder is an application, uses the FFmpeg, MKVToolNix and MediaInfo utilities, that allows to convert media files while preserving HDR metadata. Supported hardware encoding NVENC and Intel QSV (for Windows and experimental for Linux). The following encoding modes are implemented: H265, H264, VP9, MPEG-2, XDCAM, XAVC, DNxHR, ProRes. The program can also be used to change the HDR metadata, such as Master Display, maxLum, minLum, and other parameters.
There are packages for the main distributions: Windows 8.1, 10, Debian, Ubuntu 20.04, Fedora 32, CentOS 7.8, Arch Linux, Manjaro Linux.
Download
https://github.com/CineEncoder/cine-encoder/releases
Linux versions:
https://www.pling.com/p/1406740/
Report a bug and suggestions
https://github.com/CineEncoder/cine-encoder/issues
Helg1980 is offline   Reply With Quote
Old 2nd February 2021, 13:44   #2  |  Link
Helg1980
A new version 3.1 has been released:
- implemented Windows support,
- fixed some bugs,
- improved design.
Old 18th March 2021, 07:37   #3  |  Link
Helg1980
A new version 3.2 has been released:
- added new features: metadata editing, audio track selection, subtitle selection, clip cropping, clip sorting,
- added presets,
- fixed some bugs,
- improved design.
Old 26th June 2021, 14:25   #4  |  Link
Helg1980
A new version 3.3 has been released:
- the interface has been redesigned into dock widgets,
- added new features: additional settings for presets.
- added presets for Intel QSV, XDCAM,
- fixed some bugs.
Old 25th August 2021, 16:34   #5  |  Link
Helg1980
A new version 3.4 has been released:
- added log window,
- added a light theme,
- added the ability to minimize the program to the tray,
- apply the preset with a double left click,
- change a preset's names in the preset window,
- added the ability to convert the color primary, color matrix, transfer,
- fixed some bugs.
Old 24th November 2021, 10:08   #6  |  Link
Helg1980
A new version 3.5.2 has been released:
- added the ability to reset window state to default,
- added blocking the launch of multiple instances of the program,
- add presets for Intel QSV VP9, H265,
- added preset for XAVC and H265 12 bit,
- fixed a bug encoding with subtitles.
avc, hevc, vp9
