Old 20th October 2024, 10:38   #3021  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by Selur View Post
I just called FFT3DFilter with the default parameters.
Someone knows how to extract the noise frequencies from an image and selectively remove them?
I think it would be really useful and fast with postproduction digital noise, if simple enough.
@turment on Telegram
Old 20th October 2024, 23:14   #3022  |  Link
DTL
There were some FFTW-based plugins like DeFreq (?). But it works about good only if you distortion is narrow bandwidth enough (like colour subcarrier). Natural noise is much more complex mixed with useful data and can not be as simply separated. When you run SMDegrain and it blends different frames blocks - it may be equal to special temporal-convolution frequency filter to pass only narrow frequencies and suppress out of band noise. May be same or close idea is implemented in FFT3D plugin via FFT.
Old 21st October 2024, 10:55   #3023  |  Link
tormento
Acid fr0g
tormento's Avatar
That is not natural noise.
That anime was 3D rendered and digital noise added later, to simulate film effect. The bandwidth, as far as my eyes can see, is really limited and mostly visible in darker area, even if light ones are mildly affected too.
Old 21st October 2024, 13:30   #3024  |  Link
DTL
Typical examples for narrow band distortions are Aerial interference with analog broadcast or some analog interference at ADC board/device to convert analog to digital. If random special noise is added - it most probable have too wide (flat) spectrum and can not be easily filtered out with narrow band-stop filters.
Old 24th October 2024, 16:33   #3025  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by kedautinh12 View Post
Choose what you like. For personal, i prefer DPIR +UniScale CartoonRestore-lite + AnimeJanai's result
Would you please address me to where to download them?
Do you know of some model that can keep 1x scale and deblur/antialiasing, to have some anime restoration instead of scaling?
Old 29th October 2024, 12:23   #3026  |  Link
tormento
Acid fr0g
tormento's Avatar
Tried to use Oyster_super.
I have to Crop(128,128,-128,-128) and resize because the image become enlarged and corrupted along the sides and doubles.
Plus, the comment says ## Input: 444 YUV/RGB at any bitdepth (output is float) but it needs to be 32 bits.
Anyone else?
Old 29th October 2024, 23:14   #3027  |  Link
takla
LWLibavVideoSource("INPUT.mkv")
ConvertBits(32).ConvertToPlanarRGB()
AItrashHere()
takla is offline   Reply With Quote
Old 20th November 2024, 12:28   #3028  |  Link
rgr
Has anyone compared Stabilization Tools Pack with Deshaker 3.1?
rgr is offline   Reply With Quote
Old 21st November 2024, 16:05   #3029  |  Link
tormento
Acid fr0g
tormento's Avatar
The call from xClean:
ConvertFormat(cconv, fmt_out="444", kernel_c=chroma, tv_in=!fulls, cplace_in=cplace)
causes
Script error: NNEDI3RESIZE does not have a named argument "src_width"
(D:/Programmi/Media/AviSynth+/plugins64/TransformsPackMain-2.2.1~Dogway.avsi, line 969)
(D:/Programmi/Media/AviSynth+/plugins64/TransformsPackMain-2.2.1~Dogway.avsi, line 971)
(D:/Programmi/Media/AviSynth+/plugins64/TransformsPackMain-2.2.1~Dogway.avsi, line 972)
(D:/Programmi/Media/AviSynth+/plugins64/TransformsPackMain-2.2.1~Dogway.avsi, line 973)
(D:/Programmi/Media/AviSynth+/plugins64/TransformsPackMain-2.2.1~Dogway.avsi, line 1323)
(D:/Programmi/Media/AviSynth+/plugins64/xClean-beta10~mysteryx93.avsi, line 232)
and I can't sort out the bug in the TransformsPackMain-2.2.1.
Any idea?
Old 3rd December 2024, 22:59   #3030  |  Link
tormento
Acid fr0g
tormento's Avatar
It happens that anime are getting more and more "clean" in the general appearance but if you zoom in the dark areas you can see lot of "pixel fluctuations", perhaps coming from a poor AVC compression strategy, even from BDs. Sometimes it appears on light areas too but it's more rare.
Wanting to cleanup those lurking pixels without ruining the overall quality what do you suggest me?
I have tried with high tr and thsad numbers but all I obtain is to ruin the details without cleaning up the dark areas.
Someone tried it before?
Old 4th December 2024, 00:02   #3031  |  Link
poisondeathray
Filter the dark areas with stronger filtering than the brighter areas (or no filtering for the bright)
You can use the LumaMask in the MasksPack
Old 4th December 2024, 00:16   #3032  |  Link
tormento
Acid fr0g
tormento's Avatar
Thank you, nice idea.
And what about “subtle pixel noise” in light areas?
It’s way less noticeable but still there.
The problem is that from film grain noise, digital workflow switches that easily fixable rumor to tiny pixel fluctuations than you can really notice on larger screens.
Old 4th December 2024, 17:33   #3033  |  Link
poisondeathray
Not really my idea - people have been doing this for >30 years, pre-avisynth with denoising images. You can find video mask scripts 20 years ago
Use a "subtle pixel noise filter" for the light areas using the mask
Then it wasn't produced correctly. Digital workflows add grain to blend everything in . e.g. CG added to film
Old 4th December 2024, 17:44   #3034  |  Link
Z2697
Ray-tracing renderers can produce "real" grians by itself.
And most noises in digital era is added without good reason.
Z2697 is offline   Reply With Quote
Old 4th December 2024, 17:55   #3035  |  Link
poisondeathray
Yes, or not - it depends on the settings
Often the "grain" does not end up look like real film grain, but digital noise - not enough iterations and convergence during render
Yes, digital acquisition tends to be clean, especially with good lighting. The grain is added in post. "Dark" scenes are often shot brighter, then adjusted to look "dark" in post
But for film, the CG elements have grain emulation to blend into the film as stated above
Old 4th December 2024, 19:32   #3036  |  Link
tormento
Acid fr0g
tormento's Avatar
Some full CGI animes start to have good enough quality to be almost on par with drawn ones, i.e. Girls band cry.
The problem is that people are so used to grain that they artificially added it with no apparent reason.
Thus, denoising that digital "pixel fluctuation" makes faint details from CGI to disappear.
I uploaded a small clip from that anime, if you are curious to look at what I mean.
avisynth, dogway, filters, hbd, packs
