Thread Tools Display Modes
Old 28th January 2025, 04:32   #861  |  Link
vertigo220
Unfortunately, I don't have the bandwidth for that. Due to my crappy ISP, I have limited data and don't have it to spare for this. As valiant an effort as chapterEditor is, I think I'm just going to give up on trying to do multi-edition MKVs, as it's proven to be too difficult and error-prone. Thanks, anyway.
vertigo220 is offline   Reply With Quote
Old 28th January 2025, 14:01   #862  |  Link
hubblec4
Matroska find' ich toll
Yes, it is also a problem to send such large data over the network. I understand you well, as my internet connection is not the best either.
The problem with the multi-edition MKVs is always merging the data from the M2TS files into a single file, as unfortunately MTX does not use a very good internal process.
A completely 100% perfect method would be to mux all the M2TS files separately into MKV files and then access the files using ordered chapters and generate the virtual timeline. But then you have a lot of MKV files, and whether you want that is up to you.
Have you also activated the option "Use time stamp files" in the latest cE version? This helps MTX to put the audio frames in the right place.
hubblec4 is offline   Reply With Quote
Old 13th March 2025, 03:56   #863  |  Link
phant8m
Is there a way to open a, previously created, Multi-Edition MKV and use the BD2MKV Chapter check feature that was introduced in rev1.44?
When using BD2MKV to create a multi-edition MKV, I found the chapter check feature convenient to check the transitions and adjust as necessary. However, I didn't discover the feature until after already creating some Multi-Edition MKV files. I'm hoping there's a way to go back and check them using this feature.
hubblec4, many thanks for this tool!
phant8m is offline   Reply With Quote
Old 13th March 2025, 13:54   #864  |  Link
hubblec4
Hi phant8m
and welcome to Doom9 forum.
The Chapter Check feature is only available for the currently created multi-edition MKV file.
Unfortunately, editing it afterwards is not possible.
On the other hand, I highly recommend using the new feature (timestamp files) for creating multi-edition files.
Only with timestamp files for the audio will you get a 100% clean multi-edition MKV file.
Old 14th March 2025, 07:00   #865  |  Link
phant8m
Thanks for confirming. Regarding the timestamp feature, I think I'm using it.
I'm using rev1.45 of cE with DGDemux. "Timestamp Files" is checked on the MKV tab of the Disc2MKV preferences. I can confirm timestamp files for the audio tracks do get created. Hopefully this all means it's working.
All the multi-edition MKVs I've created are from the same TV series. For these, I've noticed that the transition from angle 2 back to angle 1, was 1 frame late causing audio/visual "glitches" on playback (from showing 1 frame of the next scene in angle 2 before it switches back to angle 1). This was easy enough to fix using the chapter check feature though.
Old 14th March 2025, 11:59   #866  |  Link
hubblec4
OK, good to know that the chapter check feature helps.
Above the Timestamp files setting, there's an option for the "Magic" Timestamp Scale value.
This option should also be enabled, as it creates better timestamps for audio and video, which can lead to smoother transition control.
Old 27th November 2025, 17:10   #867  |  Link
tormento
Acid fr0g
tormento's Avatar
Do you plan to add High DPI support?
@turment on Telegram
Old 15th February 2026, 20:49   #868  |  Link
vertigo220
Sorry for the long delay. Since I unfortunately had to give up on this, I forgot to respond before. I don't remember if I tried this, and it might be worth trying again with it, but even if it works, it doesn't seem it's the best option anymore. I originally planned to use cE to create a multi-edition MKV that could later be encoded (with, e.g., Handbrake) down to a smaller, still multi-edition, file, but now that I'm looking into doing this, it doesn't seem possible. I'd always assumed it was due to the qfile which is meant to use for encoding, but when I just tried it, it didn't work, and searching this thread and the web I've been unable to find anything regarding doing this.
So unless I'm missing something, and it is possible to do this, it makes more sense to have a separate encode for each cut/edition with multiple files, as that would not only be smaller than one non-encoded file, even with the duplicated content, but it's better for compatibility. So is there a way to encode a multi-edition file in e.g. 264/265 with the seamless branching to allow for a much smaller single file, or is that truly not possible?
bluray backup, chapter editor, dvd2mkv, matroska menu, metadata, multi-edition-mkv, xml tag
Thread Tools
