Old 12th March 2023, 21:49   #1301  |  Link
jones1913
random user
Originally Posted by jones1913 View Post
I just noticed that mediafire flagged my upload as "virus".
So I dropped the zip file to virustotal, and some encoders are detected as virus or trojan or whatnot (by max 4 search engines out of 69).
See here:
https://www.virustotal.com/gui/file/...0499/relations
To compare I have also tested with encoders from Mulders site:
https://sourceforge.net/projects/mul.../Opus%20Tools/
and the results are even more crazy:
https://www.virustotal.com/gui/file/...46d9/relations
I am very confident that Mulders compiles contain no viruses and these are all false flags.
So I guess it is the same with the encoders in my upload. They are mostly from rarewares.org .
I think everyone must decide if they trust downloaded programs.
If someone has suggestions for alternative download sources than rarewares.org ...
BeHappy Audio Transcoder > <Doom9 forum> <Gleitz forum> <GitHub>
MP4.tool GUI for MP4Box & L-SMASH muxer > https://www.mediafire.com/folder/3i6y6cbkyhblm/MP4.tool
jones1913 is offline   Reply With Quote
Old 12th March 2023, 22:24   #1302  |  Link
LigH
LigH's Avatar
I am not surprised that some Antivirus engines report false alarms for assembler optimized SSE builds of encoders, as provided by RareWares.
New German Gleitz board
Old 13th March 2023, 08:32   #1303  |  Link
john33
I am confident that anything from Rarewares will be a false positive. I am afraid that virustotal is in many cases more of a hindrance than a help, their algorithms are not as smart as they would have people believe.
john33 is offline   Reply With Quote
Old 15th March 2023, 02:19   #1304  |  Link
tebasuna51
tebasuna51's Avatar
The Upmix DSP's can't work with Avs+ and SoxFilter.dll, maybe in the future...
Until that the Avs+ users can work with the commented soxfilter usage in d_UpMix.ext:
front = a#.soxfilter("filter 20-20000")
back = a#.soxfilter("filter 100-7000")
lfe = cc.Amplify(0.0)#ConvertToMono(a).soxfilter("lowpass 120","vol -0.5")
The filters are, for me, unnecesaries and the lfe is much better empty.
tebasuna51 is online now   Reply With Quote
Old 15th March 2023, 13:02   #1305  |  Link
tebasuna51
tebasuna51's Avatar
@jones1913
I can't see the new sources in https://github.com/jones1913/BeHappy
BTW I proppose a change:
Line 338 in old Encoder.cs:
int[] defmask = {0, 4, 3, 7, 51, 55, 63, 319, 1599, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
Num  Mask                                                            Mask
cha  old   old maskchannel defaults      new maskchannel defaults     new   Name
 1     4  FC                            FC                              4  mono
 2     3  FL FR                         FL FR                           3  stereo
 3     7  FL FR FC                      FL FR    LFE                   11  2.1
 4    51  FL FR        BL BR  (quadro)  FL FR FC           BC         263  4.0 (first surround)
 5    55  FL FR FC     BL BR            FL FR FC              SL SR  1543  5.0
 6    63  FL FR FC LFE BL BR            FL FR FC LFE          SL SR  1551  5.1
 7   319  FL FR FC LFE BL BR BC         FL FR FC LFE       BC SL SR  1807  6.1
 8  1599  FL FR FC LFE BL BR    SL SR   FL FR FC LFE BL BR    SL SR  1599  7.1
Then must be:
int[] defmask = {0, 4, 3, 11, 263, 1543, 1551, 1807, 1599, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
Now the defaults are the same than ffmpeg, and with the pair SL/SR for surround, instead BL/BR like can see here
Question: decoders like BestAudioSource or FFAudioSource export a runtime variable with the current dwChannelMask.
How can BeHappy read it to assign the correct maskchannel without need put it manually?
Old 16th March 2023, 21:06   #1306  |  Link
jones1913
random user
It's up now.
Good question. I guess this has to be wired up in Avisynthwrapper.dll .
To start small: how would I retrieve this variable in an ordinary script?
Old 16th March 2023, 23:02   #1307  |  Link
tebasuna51
tebasuna51's Avatar
It's up now.
I don't know, I ask also in Avisynth usage thread
There are some news https://forum.doom9.org/showthread.p...68#post1984568
Old 17th March 2023, 10:36   #1308  |  Link
pinterf
@jones1913
Num  Mask                                                            Mask
 1     4  FC                            FC                              4  mono
Then must be:
Had a look into av_get_default_channel_layout which iterates over channel_layout_map[] and returns the first entry with matching channel count, I see it differently.
Based on this:
https://ffmpeg.org/doxygen/trunk/cha...8c_source.html
and
https://ffmpeg.org/doxygen/trunk/cha...8h_source.html
The default five and six-channel setting is 5.0 BACK and 5.1 BACK, so they shouldn't be changed.
Changing the 3 and 4-channel defaults to 2.1 and 4.0 is O.K.
pinterf is offline   Reply With Quote
Old 17th March 2023, 14:49   #1309  |  Link
tebasuna51
tebasuna51's Avatar
and
And 6.1 (7 channels) must be changed also.
Well, and ffmpeg must change 5.0 BACK and 5.1 BACK defaults.
In old times SL/SR (Side) was at 90 and BL/BR at 135 (Back like cuadro) and the AC3/DTS sources 5.1 with Surround channels (Ls/Rs) at 120 was decoded to BL/BR (120 near 135 than 90)
But now the preference seems assign 110 to Side (SL/SR) and Surround (Ls/Rs)
And ffmpeg is coherent with that:
DTS 5.0 decoded like 5.0(side)
DTS 5.1 decoded like 5.1(side)
AC3 5.0 decoded like 5.0(side)
AC3 5.1 decoded like 5.1(side)
What source must be decoded to BL/BR pair?
Old 17th March 2023, 15:30   #1310  |  Link
pinterf
Then they at ffmpeg project know it well, just keep the above mentioned old defaults for compatibility reasons?
Old 17th March 2023, 19:54   #1311  |  Link
tebasuna51
tebasuna51's Avatar
I don't think so, but no problem for me (I am one of the last defender of decode Ls/Rs to BL/BR, but with eac3to I changed my mind and recommend the pair SL/SR).
BTW the BeHappy defaults was created by me, and I recommend actualize them because all sources 5.0/5.1 are decoded to SL/SR, and encoders accept better the SL/SR pair to create 5.0/5.1 files.
All AVR's 5.1 play SL/SR or BL/BR with the Ls/Rs speakers without problems.
Old 18th March 2023, 14:31   #1312  |  Link
jones1913
random user
@jones1913
Num  Mask                                                            Mask
 1     4  FC                            FC                              4  mono
Then must be:
Its done.
Compiled bins can be found on github in "bin" folder: https://github.com/jones1913/BeHappy/tree/master/bin
Old 19th March 2023, 19:12   #1313  |  Link
jones1913
random user
Soxfilter seems to work now with latest avs+ test version, should we still use your fix?
And 2 more questions:
- Audiolimiter.dll (for Down Mix) is 32bit only, so we must disable it in 64bit BeHappy build or is there an alternative?
- Do we still need BassAudioSource and NicAudioSource? Have they any use case that is not covered from our ffmpeg based filters?
Old 20th March 2023, 09:45   #1314  |  Link
tebasuna51
tebasuna51's Avatar
It is a test version, we can wait until we know how use it to include the maskchannel. BTW can be a user decision because:
- front = a#.soxfilter("filter 20-20000")
Who need that filter? For what a limit here? The encoders have filters to limit the banwidth based in bitrate requested.
- back = a#.soxfilter("filter 100-7000")
To save bitrate? Maybe this can have some sense.
- lfe = cc.Amplify(0.0)#ConvertToMono(a).soxfilter("lowpass 120","vol -0.5")
Never. Please don't mistake the LowFrequencyEfects channel with the subwoffer in an AVR.
The AVR, and also simple audio equipment 2.1, extract the low frequencies from ALL channels and send them to the subwoofer.
Create a unexistent LFE only can produce problems with differences in phase or cut frequencies betwen that filter and the AVR's filters configured more accurate with the speakers attached to them.
Please leave the lfe empty, or use a 5.0, when upmix 2.0 to 5.1
There are an alternative using the compand sox filter.
See the ffmpeg downmix, and in MeGui 64 thread
I will test it.
NicAudioSource is not necesary anymore after the other decoders support the drc=0.
BassAudioSource have some special decoders, for instance .mid, not supported in standard audio decoders. Maybe it is not used frequently but it is a option.
Old 5th December 2023, 13:43   #1315  |  Link
tebasuna51
tebasuna51's Avatar
WARNING: the sintax in last L-SMASH-Works-r1156.0.0.0 have a important change:
the recommended parameter for LWLibavAudioSource/LSMASHAudioSource(..., drc_scale=0,...) not work now, must be:
(..., ff_options = "drc_scale=0", ...)
Then if you use that new version (32 or 64 bits) you must change the s_L-SmashAudio.ext with the attached one.
There are also a upgraded SoxFilter 2.1 with some changes over the previous 1.0. If you use it I recommend upgrade also d_UpMix.ext and d_DownMix.ext with the attached, now work for 32 and 64 bits and not need AudioLimiter.dll:
File Type: 7z s_L-SmashAudio.7z (1,000 Bytes, 32 views)
behappy
