Old 31st May 2006, 21:21   #301  |  Link
Dayvon
I'm Dayvon, an MP4 addict
Dayvon's Avatar
@ Dimzon
Sorry for dropping off the face of the earth man. I had every intention of helping out in some way, and then LIFE happened . Needless to say, BeHappy is rocking! You've been doing awesome work. Me and everyone else using it gives you thanks!
My Gear
Dayvon is offline   Reply With Quote
Old 1st June 2006, 18:39   #302  |  Link
fight2win
What's in a name dude !
fight2win's Avatar
for ac3 to aac conversion, how to increase volume of output file in behappy?
fight2win is offline   Reply With Quote
Old 1st June 2006, 20:35   #303  |  Link
tebasuna51
tebasuna51's Avatar
Use NicAc3Source with DRC and after Normalize at desired level.
Old 2nd June 2006, 12:49   #304  |  Link
fight2win
fight2win's Avatar
my behappy only says source as nicac3, not as nicac3drc, where to get it?
Old 2nd June 2006, 13:02   #305  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
choose nicac3 source AND click on [...] button against source selection
dimzon is offline   Reply With Quote
Old 10th June 2006, 17:55   #306  |  Link
fight2win
fight2win's Avatar
i have 3 little queries about ac3/dts to aac encoding:
1.if my source is 2-ch 192kbps ac3, which out of drc source,normalize to 100 percent and dpl2 downmix options should i use?
2.in what order should normalize and dpl2 downmix options should come, i mean, which should come first and which after that?
3. for muxing in mp4 container, should i use .aac conatainer output encoding or .m4a container output encoding?
thanks in advance, by the way, behappy rocks!
Old 10th June 2006, 20:18   #307  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
1. for stereo encoding's don't use dominix
2. first dominix and then normalize (but i think is the same when is inverted)
3. mp4 is better choice, because sometimes must to singnal HE-AAC when muxing, and muxers can't detect propertly HE-AAC files.
shon3i is offline   Reply With Quote
Old 10th June 2006, 20:39   #308  |  Link
fight2win
fight2win's Avatar
thanks!
Old 10th June 2006, 21:05   #309  |  Link
fight2win
fight2win's Avatar
even when encoding ac3 6 channel or dts to 2-channel aac, should i use downmix to dpl2 ?
Old 10th June 2006, 23:20   #310  |  Link
tebasuna51
tebasuna51's Avatar
Is not the same. First downmix and after normalize.
When normalize over 6 channels the max peak of all channels is used to calculate the common gain applied to all channels.
After downmix, (to avoid clipping problems, the coeficients in downmix matrix must sum only 1.0) the resultant 2 channels never are normalized.
Only if all 6 input channels have a equal max peak at same time is the same.
Yes, why not?
Old 16th June 2006, 06:17   #311  |  Link
vlada
Hello,
I have one very basic question: Why the NicAudio.dll isn't loaded? The script created by BeHappy doesen't work. It reports there is no command called NicAC3Source. I think there sould be something like LoadPlugin("NicAudio.dll"). Of course I have this file in my AviSynth plugin's directory. Why isn't BeHappy working for me?
Sorry for this very basic question, but I couldn't find the answer anywhere.
vlada is offline   Reply With Quote
Old 16th June 2006, 10:18   #312  |  Link
dimzon
dimzon's Avatar
Sometimes some software can modify HKEY_LOCAL_MACHINE\SOFTWARE\AviSynth registry key, check it to know wich ACTUAL dir is AviSynth plugin dir
Old 16th June 2006, 11:41   #313  |  Link
MacAddict
XviD User
Maybe this should be default in the GUI then?
DFI NF4 SLI Expert | Opteron 165 CCBBE 0616 XPMW (9x325HTT=2.9Ghz) | 2x1GB G.Skill HZ (3-4-4-8-12-16-2T) | LG 62L DVD/CD | Geforce 7300GT | All SATA | Antec 650 Trio PSU | XP SP2
MacAddict is offline   Reply With Quote
Old 17th June 2006, 02:32   #314  |  Link
tebasuna51
tebasuna51's Avatar
Yes, for habitual jobs Normalize() is the last DSP to be used.
I don't remember if is the default but, if you use Move Down, the next time you use BeHappy your order is preserved.
Old 17th June 2006, 19:18   #315  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Again i haved some free time to make new fresh package with last versions
ChapterGen - manipulate with chapters in various i/o formats, with CLI support
Official website or Doom9 thread
Old 19th June 2006, 20:36   #316  |  Link
vlada
dimzon> So if I have a plugin in AviSynth plugin's folder, there should be no need to load the plugin in script? I didn't know that.
Anyway I installed the package from shon3i and BeHappy started working. I have no idea what was wrong.
Old 20th June 2006, 16:57   #317  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Maybe you don't haved nicaudio.dll in avisynth plugins folder, or avisynth use other path for plugins(stored in registry, look dimzon's post above) and my setup use this path and find right plugins folder on system
Old 20th June 2006, 19:23   #318  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Fresh package is out.
Now support BassAudio which means more input file types supported directly (wav/ogg/aiff/mp3/mp2/wma/flac/wv/ape/mpc/spx/aac/m4a/mp4/ac3)
but have some minor bugs and restrictions like
- aac decode don't work for 5.1 multichannel. Better to use DirectShowSource
- stereo ac3 (2.0) don't work. NicAC3 is better
And i found that ape (Monkey's Audio) don't work propertly
Old 22nd June 2006, 23:45   #319  |  Link
Yanaran
Just wanted to say thanks for this great tool, finally I get full volume ac3 for my DVDs without jumping through hoops.
Yanaran is offline   Reply With Quote
Old 26th June 2006, 15:29   #320  |  Link
dimzon
dimzon's Avatar
http://gotdotnet.com/
Now BeHappy is Featured Workspace
Originally Posted by bla-bla-bla@microsoft.com
Hello,
Your project rocks! We're going to feature it on the GotDotNet homepage. Congrats and keep up the great work.
Julie
Microsoft GotDotNet Team
behappy
