Old 27th June 2010, 17:23   #1  |  Link
pbelkner
FFSoxPlayer released
FFSoX Player is a Winamp (http://www.winamp.com/) plug-in based on the FFmpeg (http://www.ffmpeg.org/) and SoX (http://sox.sourceforge.net/) libraries. Using FFmepg almost all multimedia files may be played, including but by far not restricted to H.264 and VP8. Audiophile sound processing is provided using high quality 32 bit SoX algorithms and dithering.
FFSoX Player turns Winamp into a video player for almost all known formats.
Home: http://in-ffsox.sourceforge.net/
Download: http://sourceforge.net/projects/in-ffsox/files/
pbelkner is offline   Reply With Quote
Old 25th July 2010, 14:53   #2  |  Link
pbelkner
v0.4 released
What's new?
  • Enabled seeking (depends on whether the corresponding FFmpeg format supports it).
  • Made switching on/off the gain effect's limiter available in configuration dialog.
  • Resolved some issues which caused the plug-in to crash in case of unsupported codecs.
For details go here.
For download go here.
Old 8th August 2010, 14:26   #3  |  Link
pbelkner
v0.4.1 released
What's new?
  • Support for "avcore-0.dll" (new FFmpeg library, has to be copied along the other DLLs if using FFmpeg from third party sites, e.g. http://ffmpeg.arrozcru.org/autobuilds/).
  • Resolved some video synchronization issues.
  • Switch on/off SoX decoders via configuration.
Old 8th August 2010, 16:55   #4  |  Link
leeperry
Kid for Today
hehe, you made some friend on the hydroponic audio forum, I see
BTW, would you have any idea how to make the winamp2 DSP plugins in ffdshow work in 24int instead of 16int by any chance? It's entirely possible apparently, as both Christian Budde and the coder of the foobar wrapper did it
It's around here: http://ffdshow-tryout.svn.sourceforg.../?pathrev=1928
there's a lot of "int16_t", but changing them to "int24_t" gives static..
Old 8th August 2010, 19:14   #5  |  Link
pbelkner
Thanks
BTW, would you have any idea how to make the winamp2 DSP plugins in ffdshow work in 24int instead of 16int by any chance? It's entirely possibly apparently, as both Christian Budde and the coder of the foobar wrapper did it
Unfortunately not out of the box. It took me about half a year only to scratch at the surface of FFmpeg ...
Old 22nd August 2010, 16:37   #6  |  Link
pbelkner
v0.4.2 released
What's new?
  • Fixed seeking OGG (and possibly other formats).
  • Verified that streaming (e.g. via HTTP) is supported. For streaming "SoX decoder" in preferences should be switched off.
Old 22nd August 2010, 19:13   #7  |  Link
pbelkner
Recompiled v0.4.2
There where some issues reported with the binaries compiled on a Vista/64 system. I've just uploaded new binaries compiled on a XP/32 system which should do better.
Sorry for any inconvenience.
Old 28th August 2010, 12:47   #8  |  Link
pbelkner
v0.4.3 released
What's new?
  • Fixed reading metadata from OGG/Vorbis.
  • Fixed Musepack SV7 and SV8 formats crashing at the end of a track.
Old 10th October 2010, 15:06   #9  |  Link
pbelkner
v0.4.4 released
What's new?
  • Changed order of applying the replay gain and resampling effects. Resampling is now the first effect.
  • The stereo (2.0) audio stream is preferred over any other audio stream.
  • Added an "Objectives" section to the documentation describing the objectives why we are developing the the plug-in (currently only with respect to audio processing).
Old 16th December 2010, 17:52   #10  |  Link
pbelkner
v0.4.5 released
What's new?
  • Fixed mapping tags (under certain circumstances "Album Artist" where not properly mapped or could mask "Album").
  • Fixed playing mono.
  • Changed suggestion when to use "multiple integer" mode for up-sampling.
Old 27th December 2010, 22:48   #11  |  Link
Milardo
I installed the FFSoxPlayer from the .exe file. I didn't install asio. I am able to hear sound but can view no video, do you happen to know what the problem might be?
Milardo is offline   Reply With Quote
Old 15th May 2011, 16:16   #12  |  Link
pbelkner
Version 0.4.6.4 released
FFmpeg has "bumped" their DLLs:
  • avutil-50.dll => avutil-51.dll
  • avcodec-52.dll => avcodec-53.dll
  • avformat-52.dll => avformat-53.dll
  • avcore-0.dll dropped
Version 0.4.6.4 released:
What's new?
  • Compatible to the latest (bumped) FFmpeg versions.
For upgrading to full FFmpeg (needed for playback of e.g. MP3, H264 and many other codecs and formats) get the FFmpeg DLLs from the latest shared builds
Originally Posted by Milardo View Post
Do you have upgraded to full FFmpeg?
Old 21st May 2011, 06:12   #13  |  Link
Milardo
I will try the new update and full ffmpeg and I will let you know.
Old 21st May 2011, 07:19   #14  |  Link
Milardo
I'm testing FFSoX player and have some questions. First, is it necessary to install asio? What benefits are there if you install that? I've downloaded the in_ffsox-0.4.6.4-ffmpeg.exe file, do I need to update the ffmpeg dlls? It seems that the installation includes latest versions. Also, how do I get FFSoX player to play any files like DVR-MS, flv, vob, and others? I specified in the file types of FFSoX player for example FLV and winamp wouldn't even play the file at all. I'm really interested in getting this plugin to work with winamp. Also, how do I switch between audio streams if I have a dual stream file like mkv? Thanks in advance for your help.
Old 21st May 2011, 13:19   #15  |  Link
pbelkner
Thank you for giving it a try.
No.
The plugin's focus is on rendering audio as perfect as possible. In using ASIO it is for sure that the audio signal reaches the DAC (sound card) unaltered, i.e. it is exact the same bit pattern as produced by the plugin. If you are using the Winamp's default Direct Sound output the audio signal will most likely be altered by Windows, e.g. re-sampled. This should be avoided, if possible.
You should prefer ASIO if you're going to listen to the audio via your home stereo.
You should of course upgrade. The included version is configured to contain only a very restricted set of codecs and formats.
FFmpeg is improved on a day by day basis. Even if the plugin doesn't change it is a good idea to upgrade FFmpeg from time to time in order to profit from FFmpeg improvments.
Cf. previous question. You shuold upgrade in order to make sure that the codecs/formats are supported by your FFmpeg DLLs. Just specifying file types is not sufficient.
The plugin does this for you. It chooses the first video stream and the first (stereo/2.0) audio stream.
Old 1st October 2011, 16:14   #16  |  Link
pbelkner
Version 0.4.6.5 released
What's new?
  • Enables 32 bit float format for decoding e.g. MP3, AC3 and other lossy audio codecs.
  • Enables (and requires) usage of FFmpeg's "swscale-2.dll", i.e. compatible to the latest FFmpeg versions. For upgrading to full FFmpeg (needed for playback of e.g. MP3, H264 and many other codecs and formats) get the FFmpeg DLLs from the latest shared builds at Zeranoe: http://ffmpeg.zeranoe.com/builds/win32/shared/.
Old 1st October 2011, 16:53   #17  |  Link
kerimcem
winamp seek bar not work
kerimcem is offline   Reply With Quote
Old 2nd October 2011, 06:31   #18  |  Link
pbelkner
Thanks for the feedback.
It depends on the container format, e.g. MKV works. I have to admit that I've not fully understood how seeking works in FFmpeg and SoX. Any help is appreciated.
Old 2nd October 2011, 10:42   #19  |  Link
naoan
I used this in conjunction with xmplay and actually liking how it sounds, better than foobar2000 imho.
Edit :
I just tried the new 0.4.6.5 (with latest ffmpeg) and it seems to be hotter/more sibilance than 0.4.6.4. Not a good thing imo, I'm rolling back to previous version...
naoan is offline   Reply With Quote
Old 2nd October 2011, 15:01   #20  |  Link
kerimcem
If seek bar work on FLAC files, i will use.Sound quality is definitely awesome..thanks.
