Old 6th March 2020, 18:55   #1441  |  Link
stax76
stax76's Avatar
You're welcome. Next build includes a check for it.
stax76 is offline
Old 7th March 2020, 09:21   #1442  |  Link
JKyle
App Digger
JKyle's Avatar
HE-AAC audio in mp4 demuxed to an mka format
While remuxing an AAC audio stream via stream copy with a re-encoded HEVC video stream to an mp4 file, I found this weird behavior of StaxRip (2.0.7.4 Beta): it demuxes the HE-AAC audio stream (via MP4Box) to an mka format while demuxing the AAC-LC audio stream to an m4a format (as expected).
This produces a false warning that remuxing the original AAC(HE-AAC) audio stream via stream copy to an mp4 format is not appropriate, which is inappropriate itself.
On the other hand, this warning does not appear in the case of an AAC-LC audio stream, as a matter of course.
Well, is there any reason why an HE-AAC stream is demuxed to an mka format?
Thanks in advance.
JKyle is offline
Old 7th March 2020, 09:54   #1443  |  Link
stax76
stax76's Avatar
2.0.7.5 Beta
- fix: when the cut feature was used and afterwards the preview was
       opened from the code editor then the cut settings got damaged
- fix: when AviSynthShader was used StaxRip did not show
       a warning in case DirectX 9 is not installed
- fix: HE-AAC as demuxed as mka
- new: setting that allows to define how many frames
       are used for auto cropping
- new: some default settings were changed
- new: the buttons in the preview dialog look much better now, also flicker
       was eleminated and the button and trackbar size was increased,
       standard buttons were used, I don't know how it looks on Win 7...
- new: the csv file content in the apps dialog was improved
- new: auto crop feature in crop dialog finally shows progress
- new: the avisynth and vapoursynth code editor has a new
       'Advanced > Advanced Info' feature, it offers the following info:
       avs2pipemod info, avsmeter info, avsmeter benchmark and vspipe info
https://www.dropbox.com/sh/4ctl2y928...dd3yqcAHa?dl=0
https://1drv.ms/u/s!ArwKS_ZUR01g0kH4...3GaKe?e=qbOfGS
stax76 is offline
Old 7th March 2020, 23:46   #1444  |  Link
Spunkmeyer
Hi Stax, I'm still getting the same exitcode crash referencing D:Projekte etc when trying to use Vapoursynth at the end of demuxing.
Using Avisynth as filters is working ok.
Spunkmeyer is offline
Old 8th March 2020, 00:04   #1445  |  Link
stax76
stax76's Avatar
Please post either a link to the error message or post the error message.
stax76 is offline
Old 8th March 2020, 00:34   #1446  |  Link
Spunkmeyer
StaxRip.ErrorAbortException: Index LWLibav failed with exit code: -1073741515 (0xC0000135)
C:\Users\gouck\AppData\Local\Programs\VapourSynth\core\vspipe.exe "D:\****1080p_temp\ ****1080p_new.vpy" NUL -i
at StaxRip.Proc.Start() in D:\Projekte\VB\staxrip\General\Proc.vb:line 342
at StaxRip.MainForm.Indexing() in D:\Projekte\VB\staxrip\Forms\MainForm.vb:line 3193
at StaxRip.VideoScript.Synchronize(Boolean convertToRGB, Boolean comparePath, Boolean flipVertical) in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 237
at StaxRip.VideoScript.GetInfo() in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 444
at StaxRip.VideoScript.GetFrameCount() in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 458
at StaxRip.GlobalClass.IsValidSource(Boolean warn) in D:\Projekte\VB\staxrip\General\GlobalClass.vb:line 701
at StaxRip.MainForm.AviSynthListView_ScriptChanged() in D:\Projekte\VB\staxrip\Forms\MainForm.vb:line 5223
at StaxRip.FiltersListView.OnChanged() in D:\Projekte\VB\staxrip\Controls\FiltersListView.vb:line 271
at StaxRip.FiltersListView._Lambda$__14-0(VideoScript script) in D:\Projekte\VB\staxrip\Controls\FiltersListView.vb:line 30
at StaxRip.VideoScript.RaiseChanged() in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 22
at StaxRip.VideoScript.SetFilter(Int32 index, VideoFilter filter) in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 92
at StaxRip.MainForm.OpenVideoSourceFiles(IEnumerable`1 files, Boolean isEncoding) in D:\Projekte\VB\staxrip\Forms\MainForm.vb:line 2069
Old 8th March 2020, 01:10   #1447  |  Link
stax76
stax76's Avatar
Apparently my diagnostic code failed on multiple levels, 0xC0000135 should be STATUS_DLL_NOT_FOUND, try this:
Main Menu > Apps > Manage > type 'visual' in search field and install some VC++ Redist x64, also please post the generated vpy vapoursynth script, so I can fix the requirement detection as well as the exit code analysis.
edit:
Is there a _staxrip.log file?
stax76 is offline
Old 8th March 2020, 12:36   #1448  |  Link
Mister XY
In version 2.0.7.5 the chapters are not set automatically. You have to search and select the xml file via Container Options -> Options -> Chapters for each film. If you do not do this, the line in Chapters remains empty.
Mister XY is offline
Old 8th March 2020, 13:37   #1449  |  Link
Patman
Patman's Avatar
On github is an issue opened for this case. Look there, I uploaded a fix in the comments.
Tools for StaxRip | x264 - x265
Patman is offline
Old 8th March 2020, 16:34   #1450  |  Link
Taurus
Taurus's Avatar
Thank you, working as expected
Taurus is offline
Old 8th March 2020, 17:39   #1451  |  Link
stax76
stax76's Avatar
I hope it's getting more stable because I really want to get that 2.0.8.0 stable release out, please help to test.
- fix: format compatibility was improved with an automated test
- fix: in the preview dialog the start position for mpc
       and mpv was incorrect when cut ranges were active
- fix: chapter file not being picked up
- fix: in the filter setup profiles dialog a exception could
       happen and loading a filter setup from the menu could fail
- fix: the filter parameter menu in the code editor was adding
       parameters even if they were already existing with different casing
- fix: cutting could cause an error where staxrip generates
       a chapter file without containing a ChapterAtom
- new: the logic to create and edit cut sections in the preview
       dialog is now smarter and more flexible
- new: the assistant tells in case of a script error that the
       full error can be shown by clicking the preview button
- new: MiniDeen avs filter added
- new: Advanced Info in the code editor was moved to the top level menu
       and AviSynth Info() can be shown directly from the Advanced Info
       without adding Info() to the script, staxrip generates the script
       with perfect font size and shows it with mpv (paused, no osc, no osd)
stax76 is offline
Old 8th March 2020, 18:33   #1452  |  Link
NikosD
For your next version ALL rigaya's HW transcoders have new versions:
NVenc v4.68
QSVenc v3.33
VCEenc v5.04
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
NikosD is offline
Old 8th March 2020, 19:44   #1453  |  Link
stax76
stax76's Avatar
@NikosD
I've updated it locally.
stax76 is offline
Old 8th March 2020, 20:18   #1454  |  Link
Spunkmeyer
I'm not even getting a chance to run a script when choosing VS as filters, it just bombs after demuxing as above.
Old 8th March 2020, 20:22   #1455  |  Link
JKyle
App Digger
JKyle's Avatar
And Subtitle Edit was updated to 3.5.14 yesterday:
https://github.com/SubtitleEdit/subt...ses/tag/3.5.14
BTW, I noticed a sub-folder name change in the StaxRip\Apps\Plugins folder: BothDual
Well, just for you guys who just overwrite the whole folders/files.
JKyle is offline
Old 8th March 2020, 20:47   #1456  |  Link
Patman
Patman's Avatar
NVenc v4.68
QSVenc v3.33
VCEenc v5.04
With the update of these three apps, a new option was added for each: --input-option
Another option has been added for QSVEnc: --vpp-colorspace
Patman is offline
Old 8th March 2020, 20:55   #1457  |  Link
stax76
stax76's Avatar
@Spunkmeyer
Look for a file that ends with _staxrip.log
@JKyle
I've updated it.
stax76 is offline
Old 8th March 2020, 20:58   #1458  |  Link
FreaQ
Starfish
FreaQ's Avatar
I tried 2.0.7.6 and it's not usable.
I open a new video file with source "automatic". Demuxing is working, but then the program fails and I get the error message, that AviSynth+ was not found even so I installed 3.5 prior.
------------------------- Error opening source -------------------------
AviSynth+ installation cannot be found
LoadPlugin("D:\_Programme\_Portable\StaxRip-x64-2.0.7.6-beta\Apps\Plugins\both\ffms2\ffms2.dll")
FFVideoSource("D:\Video\Der Film_temp\Der Film.mkv", colorspace = "YV12", \
              cachefile = "D:\Video\Der Film_temp\Kim Possible - Der Film.ffindex")
But what is even more painful is, that my version of 2.0.6.0 is also not working anymore.
I use both versions as portable installations with the settings folder in each portable folder. I reverted AviSynth+ to the previous version but 2.0.6.0 keeps on failing.
FFVideoSource: The index does not match the source file
(D:\Video\Billy the Kid_temp\Billy the Kid_source.avs, line 3)
LoadPlugin("D:\_Programme\_Portable\StaxRip-x64-2.0.6.0-stable\Apps\Plugins\both\ffms2\ffms2.dll")
FFVideoSource("D:\Video\Billy the Kid_temp\Billy the Kid.mkv", colorspace = "YV12", \
              cachefile = "D:\Video\Billy the Kid_temp\Billy the Kid.ffindex")
Edit: 1.7.0.6 still works flawlessly.
FreaQ is offline
Old 8th March 2020, 21:12   #1459  |  Link
stax76
stax76's Avatar
I've already added it locally, don't anybody worry that a switch will be missed, it's not gonna happen.
https://github.com/staxrip/staxrip/b...eneral/Test.vb
https://github.com/staxrip/staxrip/b...QSVEnc.vb#L116
stax76 is offline
Old 8th March 2020, 21:21   #1460  |  Link
stax76
stax76's Avatar
@FreaQ
Post one screenshot of the AviSynth page in the apps dialog and one screenshot of your Windows Uninstall dialog showing your AviSynth+ 3.5 x64 installation.
stax76 is offline
aac, hdr, hevc, nvenc, staxrip, x264, x265
