Old 22nd June 2010, 09:36   #1  |  Link
buzzqw
HDConvertToX author
AutoWebM -> gui for IVFenc and MakeWebM
Hi All
here AutoWebM a simple gui for IVFenc (Nic' version) and MakeWebM
Instruction:
* Install the MakeWebM directshow filters: http://code.google.com/p/webm/downlo...8.zip&can=2&q=
and launch install_webmdshow.exe
* Make sure you have installed avisynth and a working set of directshow decoders
this is the first alpha release
http://www.64k.it/andres/data/autowebm/AutoWebM01.zip
and always download the update! http://www.64k.it/andres/data/autowebm/AutoWebM.exe
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 22nd June 2010, 14:11   #2  |  Link
poisondeathray
Thanks!
Old 23rd June 2010, 07:59   #3  |  Link
buzzqw
HDConvertToX author
update
added support quality encoding
added possibility to specify decoder when using ifvenc
fixed resizer
BHH
Old 23rd June 2010, 11:42   #4  |  Link
Selur
Selur's Avatar
@buzzq: why are the directshow filters needed? iirc ivfenc doesn't need them.
Old 23rd June 2010, 12:02   #5  |  Link
ricardo.santos
ricardo.santos's Avatar
To play the output webm file, just in case someone downloads the program and canīt play the webm file after.
ricardo.santos is offline   Reply With Quote
Old 23rd June 2010, 12:04   #6  |  Link
Selur
Selur's Avatar
would have been a good idea to mention that,..
Old 23rd June 2010, 12:13   #7  |  Link
ricardo.santos
I don't know if that's the reason...just guessing
Good job with the GUI Buzzqw. keep up the good work.
Thank you
Old 23rd June 2010, 13:15   #8  |  Link
buzzqw
HDConvertToX author
well.. autoWebM gui support BOTH ivfenc and makewebm
and makewebm is a directshow based encoder
BHH
Old 23rd June 2010, 21:16   #9  |  Link
wiak
might want to add webm as container, why? webm isnt webm without .webm, aka its mandatory for it to work in chrome, firefox and opera!
WebM is basicly Matroska restricted to VP8 and Vorbis?
aka when you chose IVFenc, you cant remux to webm
Woah! Ninja?! http://nwgat.ninja/ (AV1 Overview)
"Not available in your region" has now been redefined as "Go Pirate, you filthy scum" Nwgat
wiak is offline   Reply With Quote
Old 24th June 2010, 03:02   #10  |  Link
B.F.
B.F.'s Avatar
Are the WebM vorbus encoder really need for encoding?
B.F. is offline   Reply With Quote
Old 24th June 2010, 07:19   #11  |  Link
buzzqw
HDConvertToX author
that's why if you select MakeWebM as encoder you can only select webm as container.
the "bad" is makewebm has lot less options then ivfenc
yes, otherwise your webm file are without audio
BHH
Old 15th July 2010, 20:40   #12  |  Link
plonk420
amd & h.264 fanboy
plonk420's Avatar
thank you SO much for this!
plonk420 is offline   Reply With Quote
autowebm, easy, webm
