Old 20th May 2010, 15:37   #41  |  Link
STaRGaZeR
4:2:0 hater
The VP8 decoder from the WEBM site. You can find a DirectShow filter set there. Only the decoder is needed.
Thanks, I missed the DS filters.
It's only me or everything encoded with this encoder looks like crap?
Specs, GTX970 - PLS 1440p@96Hz
Originally Posted by Manao View Post
That way, you have xxxx[p|i]yyy, where xxxx is the vertical resolution, yyy is the temporal resolution, and 'i' says the image has been irremediably destroyed.
STaRGaZeR is offline   Reply With Quote
Old 20th May 2010, 15:37   #42  |  Link
NerdWithNoLife
NerdWithNoLife's Avatar
These patent wars are dissapointing. The people on this forum most certainly can design a codec that outperforms even the hype of the commercial products. Apple, Sorenson, Adobe, etc. win in marketing and legal muscle. x264 wins in actually having a great product.
f=33
NerdWithNoLife is offline   Reply With Quote
Old 20th May 2010, 15:58   #43  |  Link
clsid
Originally Posted by Turnpike View Post
The official decoder+latest Haali splitter+MPC work fine on XP.But it seems that I couldn't get the decoder registered on 64bit Win7?
You must explicitly run the command prompt as administrator when using regsvr32 on Vista/7.
MPC-HC 2.3.0
Old 20th May 2010, 16:09   #44  |  Link
weaver4
I see the comments on how it compares to X264 but I was wondering on how it compares to XviD. I am not really an expert in video but to me XviD@Q=3 is approx equal the quality of X264@Q=22 (single pass of course); but the XviD video filesize is appox 25-35% larger.
So if VP8 video quality equals X264@Q=22 for 10-20% larger filesize I could live with that.
I guess all the decoder boxes out there (Popcornhour, WD TV Live, Seagate Theater, etc) will never play VP8; right?
weaver4 is offline   Reply With Quote
Old 20th May 2010, 16:25   #45  |  Link
Boolsheet
Originally Posted by Keiyakusha View Post
is there somewhere compiled ivfenc?
There's a "libvpx 0.9.0 visual studio build" here with Windows binaries.
Example encoding parameters are on their website.
I think VP8 is not all too bad on medium and high bitrates. The crew_4cif test sample on low bitrates shows some problems after the flashes, quality drops really down, but that should be fixable with some encoder improvements I hope.
My nightmares are horrifying, they're all interlaced!
Boolsheet is offline   Reply With Quote
Old 20th May 2010, 17:14   #46  |  Link
Turnpike
Done,thx!But it seems that MPC can't call VP8 decoder in Win7?WMP is ok though.
Turnpike is offline   Reply With Quote
Old 20th May 2010, 17:26   #47  |  Link
stax76
stax76's Avatar
@Emp3r0r
A thread title starting with 'WebM' might be better.
Old 20th May 2010, 17:29   #48  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Ohh thanks! Somehow I overlooked it...
Works for me on Win7 32bit
Old 20th May 2010, 17:47   #49  |  Link
Turnpike
The VP8 decoder doesn't work with MPC-hc x64 version on Win7,but both MPC-hc x86 version and WMP are ok.
Old 20th May 2010, 18:06   #50  |  Link
clsid
The filter is 32-bit so it will obviously not work in MPC x64. It will also not work in Media Center on Vista/7 x64.
MPC-HC 2.3.0
Old 20th May 2010, 21:19   #51  |  Link
weaver4
Originally Posted by stax76 View Post
@Emp3r0r
Adding WebM to StaxRip would even be better.
Old 20th May 2010, 23:52   #52  |  Link
ricardo.santos
ricardo.santos's Avatar
Here's a windows ffmpeg build with vp8
http://micksam7.com/blog/index.php/?p=743
or you can try the flixwebm free converter altough ive been unable to change audio settings it always produces vorbis at 192k
http://www.wildform.com/products/flix/
Have fun
ricardo.santos is offline   Reply With Quote
Old 21st May 2010, 00:52   #53  |  Link
stax76
stax76's Avatar
I just need to add a new encoder, a few tweaks, some updated applications and some new profiles but still it will take time.
Before adding WebM support I have to finish revising the complete UI adding high DPI support.
Old 21st May 2010, 06:43   #54  |  Link
Midzuki
Unavailable
Midzuki's Avatar
My initial (non-)impressions about VP8 :
at the moment, NOT supported outside of the WebM «sub-container» Until Google, or someone else, releases a real CLI encoder/muxer, a stable DirectShow decoder, and (seriously!) a VfW .DLL, I will keep having very-little curiosity about it.
P.S.: I did give a try to "ivfenc.exe". What the heck, it's infinitely slower than the VC-1 DMO encoder.
Completely unusable for "obsolete" rigs like mine.
Midzuki is offline   Reply With Quote
Old 21st May 2010, 09:11   #55  |  Link
Schrade
Schrade's Avatar
Originally Posted by Dark Shikari View Post
Heh,
Steve Jobs links to your blog post in a response to an E-mail someone sent to him.
http://www.theregister.co.uk/2010/05/20/jobs_on_vp8/
Schrade is offline   Reply With Quote
Old 21st May 2010, 10:39   #56  |  Link
MfA
Make no mistake though ... he linked it because it gives his earlier patent arguments a sheen of respectability from an independent source.
Shame that that part of it was entirely build on assumptions (not a patent number to be spotted).
MfA is offline   Reply With Quote
Old 21st May 2010, 11:50   #57  |  Link
Lotesdelere
Here is a sample file from Opera:
http://lachy.id.au/lib/media/elephan...0p-Stereo.webm
Unfortunately the audio does not decode properly with CoreVorbis or ffdshow.
Same here whatever audio decoder is used, I think the problem comes from the "official" DirectShow filters.
However this build of VLC can play it fine.
Lotesdelere is offline   Reply With Quote
Old 21st May 2010, 11:50   #58  |  Link
CruNcher
CruNcher's Avatar
Yeah that Jason plays his PR game is a pitty
It is about Time
Old 21st May 2010, 11:58   #59  |  Link
Lotesdelere
Ah finally something that works, thanks for this link.
I couldn't get the DirectShow encoder to work (crashed with assertion failed) and the command line tools are creating raw streams only that nothing can mux.
What a pity, what a bad start for a new standard (?).
Old 21st May 2010, 12:09   #60  |  Link
CruNcher
CruNcher's Avatar
Sorry but this Kid stuff doesn't really is the nature of Doom9 (MOD ?)
especially not in the importance of the situation we are facing, something like this doesn't really helps
It is about Time
vp8, webm
