Old 17th July 2022, 20:32   #19541  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
First audio file in ripbot is always marked as default.
Old 17th July 2022, 20:48   #19542  |  Link
VirulentPip
I just noticed this is now the case ! So happy now. It hasn't always been like this for me.. Track one and two have always both been set as default.
VirulentPip is offline   Reply With Quote
Old 19th July 2022, 20:09   #19543  |  Link
slalom
slalom's Avatar
Yes, but the first track would play by default, maybe you wanted the second track default with the old version
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 20th July 2022, 07:42   #19544  |  Link
TDS
Formally known as .......
TDS's Avatar
I've rarely had issues with default audio tracks, and tbh, I don't understand the problem.
But I rarely encode audio thru RipBot anymore, as it doesn't convert to E-AC3, so I just add it later, after external conversion.
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 21st July 2022, 21:40   #19545  |  Link
slalom
slalom's Avatar
Use the 3-dot button to add it before video encoding
Old 22nd July 2022, 03:02   #19546  |  Link
TDS
TDS's Avatar
Yes you can, BUT RipBot can't do the conversion, so you've got to do it externally, anyway.
Old 22nd July 2022, 15:29   #19547  |  Link
sapphiresky83
Ripbot264 program gone after self-updates
Last night I went to open Ripbot264, instead of the program I received an updating status window. When that was done my shortcut no longer worked and when I ventured into my RipBot264 application folder the main application executable has been removed completely out of the folder, however, all of the other components of RipBot264 including the Encoding Server and Encoding Clients executable programs are still in the folder.
It looks like it just literally removed the main RipBot264 application file.
Upon replacing the main executable from a backup directory, Malwarebytes has grabbed the main executable as well as the Encoding Server executable as malware and specifically "Malware.Heuristic.1003"
Anyone else run into this or know what's up with that?
Last edited by sapphiresky83; 22nd July 2022 at 15:48. Reason: Added more info, screenshot
sapphiresky83 is offline   Reply With Quote
Old 22nd July 2022, 16:20   #19548  |  Link
Atak_Snajpera
https://www.virustotal.com/gui/file-...Y1ODUwMzQyOA==
It means that antiviruses just suck. Especially that Heuristic part. This literally happens every time I do an update. Uninstall that crap and just use build in antivirus in Windows.
Old 22nd July 2022, 19:27   #19549  |  Link
Ryushin
Ryushin's Avatar
Bug in Pauly Dunne Build
Hi Pauly,
I've been using your build and I've been encountering a problem when pulling in a ripped 4K UHD disc. If I use MakeMKV to extract the feature into a mkv file is pulls in fine.
Error:
Renaming Pauly's eac3to and replace it with RipBot's allows it to work fine.
Pulling in ripped Blu-ray discs seems to work fine with Pauly's eac3to.
Ryushin is offline   Reply With Quote
Old 22nd July 2022, 22:18   #19550  |  Link
slalom
slalom's Avatar
I meant after the conversion
Old 23rd July 2022, 02:23   #19551  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Originally Posted by Ryushin View Post
Hi Pauly,
Error:
Hey Ryushin,
I'm rather confused with this comment, it's almost like you're commenting on a error, then you say that if you "rename" something, or overwrite it, it works.
It doesn't work on ripped 4K's but is OK with BluRay's...
I can't comment either way, as I don't "rip" 4K or BluRay disc's, and therefore, I don't have any issues.
But maybe it's a bug with the latest eac3to...
PS:- I just noted this info about eac3to :-
eac3to v3.36
* fixed: UHD Blu-Ray support didn't work with newer releases
* fixed: on some OSs there were crashes
* fixed: libav command line output hooking wasn't working properly
* added special handling for TrueHD seamless branching
* 2nd pass for audio gap fixing is auto-disabled for (UHD) Blu-Rays now
* libDcaDec: updated to 0.2.0
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
Pauly Dunne is offline   Reply With Quote
Old 23rd July 2022, 11:28   #19552  |  Link
Ryushin
Ryushin's Avatar
Originally Posted by Pauly Dunne View Post
Hey Ryushin,
The version in your 20220714 build is v3.36, but maybe there is a change in syntax that does not work with RB.
Yea, I read my post it it didn't make much sense. If I use MakeMVK to extract the video into a mkv file from the source disc then I can import that fine into RB. But if RB (eac3to) has to demux the video from a source disc then it gives me that error.
I'll look at the eac3to thread and see what I can find out.
Old 24th July 2022, 01:57   #19553  |  Link
TDS
TDS's Avatar
Yea, I read my post it it didn't make much sense. If I use MakeMKV to extract the video into a mkv file from the source disc then I can import that fine into RB. But if RB (eac3to) has to demux the video from a source disc then it gives me that error.
As it has been a L-O-N-G time since I ripped a BluRay disc, or even a DVD, wouldn't it be preferable to rip with a 3rd party app to "defeat" any encryption, etc, anyway ??
BTW, the odd time I used MakeMKV, I didn't like it
However, you DID mention that you found a work around, so just go with that, I'd suggest.
Old 29th July 2022, 12:48   #19554  |  Link
Ryushin
Ryushin's Avatar
I rip the disc to my NAS using MakeMKV or AnyDVD to remove the encryption. Then I RB to import it and it demuxes it into it's components. I switched to using RB's eac3to and it is extracting discs fine. I have thousands of discs.
MakeMKV has become invaluable to me to extract episodes out of disc TV series and then I label them and batch import them into RB. MakeMVK also makes files with Dolby Vision in them and then I can use a third party tool to extract just the Dolby Vision out and then mux it back into my encoded versions.
Old 3rd August 2022, 12:41   #19555  |  Link
phred1
Convert HEVC to SDR?
I've got some files encoded in HEVC that i'd like to convert to SDR. How on earth do I setup RipBot to do this? I've google myself blue but cannot find the answer. Please help!
When trying to convert the files to x264 I get this purple tint. Tonemapp button for AviSynth is not clickable in GUI.
MediaInfo data:
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : V_MPEGH/ISO/HEVC
Duration : 33 min 35 s
Bit rate : 24.3 Mb/s
Width : 3 840 pixels
Height : 2 026 pixels
Display aspect ratio : 1.895
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.131
Stream size : 5.71 GiB (97%)
Language : English
Default : Yes
Forced : No
phred1 is offline   Reply With Quote
Old 3rd August 2022, 12:54   #19556  |  Link
Ryushin
Ryushin's Avatar
MediaInfo data:
Video
Format : HEVC
Color space : YUV
Bit depth : 10 bits
Language : English
Default : Yes
Forced : No
According to that file it is Dolby Vision only and there is no HDR10 in it so you won't be able to convert it to SDR using RipBot's Tonemap feature in the avisynth options.
Using MediaInfo, my HDR look like this for a pure HDR10 file:
HDR format : SMPTE ST 2086, HDR10 compatible
And my Dolby Vision with HDR look like this:
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Old 3rd August 2022, 13:53   #19557  |  Link
Atak_Snajpera
MediaInfo data:
Video
Format : HEVC
Color space : YUV
Bit depth : 10 bits
Language : English
Default : Yes
Forced : No
Could you upload some sample to Mediafire or similar service? 100 MiB/200 MiB should be enough.
Old 3rd August 2022, 14:49   #19558  |  Link
TDS
TDS's Avatar
MediaInfo data:
Video
Format : HEVC
Color space : YUV
Bit depth : 10 bits
Language : English
Default : Yes
Forced : No
Would this be of any use at all :-
https://forum.doom9.org/showthread.php?t=183479
Also (just thinking out loud), what if you "convert" it to HDR10 first, then try going to SDR...but why do you want to ??
Old 3rd August 2022, 15:26   #19559  |  Link
phred1
Thanx for the explanation! I'll give up on these files since it will require too much CLI for my taste :-/
Old 9th August 2022, 11:58   #19560  |  Link
cypher007
ive got a potential issue with the work hours function.
im running it on a Z490 board with i5 10400f and server 2022.
yesterday when i tried it it went to sleep at the right time then woke up about 30 secs later then shutdown again, it looped like this until i held the power button. now the soft raid 1 is resyncing due to the power cycles. anyway just wondering why it did this? do i need to change anything in the bios? is it because im using a server OS?
cypher007 is offline   Reply With Quote
