Old 15th May 2024, 17:19   #20681  |  Link
rlev11
Originally Posted by FTLOY View Post
As far as I can tell, there's no issues with client.
The only strange thing that has been happening (and I think I've mentioned this recently), is a chunk can be happily progressing, and then "out of the blue", it re-starts, no errors msg's, just starts from 0%.
Only times I have experienced something like that was back when I did not make sure the encoding server window was on the desktop on every machine (not minimized in the tray), or occasionally when doing the rare 480p with some heavy degraining, I'll get encoding server stalled messages on some of the servers.
rlev11 is offline   Reply With Quote
Old 16th May 2024, 10:59   #20682  |  Link
cypher007
actually i had a think about it and ive had it where even on a standard encode (not DE) its not stopped but accelerated the FPS and created junk when ive changed networks. really odd issue, i just make sure i dont unplug my lan when encoding.
cypher007 is offline   Reply With Quote
Old 25th May 2024, 10:59   #20683  |  Link
FTLOY
Friend of a friend..
FTLOY's Avatar
I was having a bit of a play with the latest Handbrake 1.8.0 today, and it appears to be able to convert most audio to TrueHD, now, not just pass thru, albeit, ONLY to 5.1, even if the original is 7.1.
RipBot264 v1.27.3 (08-06-2024)
FTLOY is offline   Reply With Quote
Old 25th May 2024, 17:40   #20684  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Meanwhile most of TrueHD streams in movies are 7.1 so ... useless for me.
Old 30th May 2024, 06:02   #20685  |  Link
FTLOY
FTLOY's Avatar
@ Atak,
I've been trying to remember the app you created to test bit's comparing to FFMS2 & L-smash, but I am drawing a blank.
I'd like to run some more tests now there's yet another improved FFMS2 build, and then there's a "new kid on the block", BestSource (BS)
Old 30th May 2024, 08:07   #20686  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Seektester ?
https://forum.doom9.org/showthread.php?t=176878
Old 30th May 2024, 08:32   #20687  |  Link
FTLOY
FTLOY's Avatar
Originally Posted by Emulgator View Post
You just never know where you are going to pop up
that's the one.
Old 30th May 2024, 09:59   #20688  |  Link
Emulgator
Emulgator's Avatar
Just one Seektester quickie for fun:
1920x1080x25i AVC+MVC in .MTS from a Panasonic 3D-Cam HDC-Z10000
LWLibavVideosource 1194 by Asd-g fine
Bestsource 4.0 by Myrsloik fine
FFMS2 5.0 by Myrsloik fine
FFMS2 2390 by StvG faulty (frameskips/repeats)
Old 30th May 2024, 10:18   #20689  |  Link
FTLOY
FTLOY's Avatar
Well, that's great that you've done that
Saves me doing it...
Maybe Atak will take note...it would be nice if he added FFMS2 5.0 & Bestsource to RipBot...just to give users a choice.
Cheers.
Old 30th May 2024, 11:22   #20690  |  Link
Atak_Snajpera
Cheers.
If ain't broken , don't fix it. That's my rule. If decoded frame is not corrupted then what is the point of using FFMS2 or BestSource?
Old 30th May 2024, 11:37   #20691  |  Link
FTLOY
FTLOY's Avatar
Who said it was broken, it's about choice...
FFMS2 used to be a user's choice option..
It's just that over the years, you have been asked for certain extra features & functions that can only improve RipBot, but because YOU don't have a use for it, it doesn't happen, unfortunately.
It's good that someone like Pauly Dunne went to the trouble of adding the use of SMDegrain to RB, and it's proven to the many that use the PD builds, that it's superior & faster than the options in "vanilla" RB.
Just sayin'...
Old 30th May 2024, 12:05   #20692  |  Link
Atak_Snajpera
What does FFMS2 or BestSource improve over LWLibavVideosource? In the end all those filters rely on ffmpeg code under hood.
LWLibavVideosource has proven to be very reliable over all those years so if ain't broken , don't change it.
frame accurate = CHECK
No corrupted frames = CHECK
That's all I need.
Old 30th May 2024, 12:15   #20693  |  Link
FTLOY
FTLOY's Avatar
That's all I need.
Again, it's about user choice !!!
I have no idea if FFMS2 or BS improve anything, and L-Smash isn't broken, but I have read that it might be being overshadowed by BestSource (same dev does both, I believe).
I thought that "filter's" were Avisynth based, and FFMPEG processed / encoded everything.
But this sums it up perfectly:-
That's all I need.
Old 30th May 2024, 12:17   #20694  |  Link
Atak_Snajpera
FFMPEG code also decodes stuff using builtin decoders.
https://ffmpeg.org/ffmpeg-codecs.html#Decoders
The same code is used in SourceFilters() as well.
NO MATTER WHAT YOU CHOOSE YOU ALWAYS CHOOSE FFMPEG CODE UNDER THE HOOD. End of story.
Old 30th May 2024, 12:44   #20695  |  Link
Atak_Snajpera
That's all I need.
Fun fact: I started this project in 2007 because I wanted something simple for encoding my videos to my PSP. So It's been always tailored for my needs.
Distributed Encoding Mode was also not created because somebody requested it. I made it for myself because I had an extra PC at home.
Old 30th May 2024, 14:19   #20696  |  Link
FTLOY
FTLOY's Avatar
So if you created this for your own needs, why did you release it to the public ???
Knowing that you would probably never do anything to it, that YOU didn't want !!!
But despite your stubbornness, I do have to applaud you for figuring out how to successfully introduce the awesome Distributed Encoding function, that IS the most outstanding feature of ANY encoding app.
None of them have attempted such a feature, the only one that comes even close is StaxRip with its parallel chunk encoding, which even tho it speeds up the encoding process, it ONLY works on 1 PC
Old 30th May 2024, 16:27   #20697  |  Link
Emulgator
Emulgator's Avatar
I do agree with that, for years no failures here with LWLibavVideosource under different use cases.
The safe indexing gold standard is already implemented by Atak, adding any poorer choice
(for instance ffms2, what he tested back then and discarded for good measure) would ask for trouble...
Old 30th May 2024, 18:33   #20698  |  Link
FTLOY
FTLOY's Avatar
Maybe back then, FFMS2 was faulty, but the latest build, and BS appear to be "fine" (in your words).
Old 30th May 2024, 20:01   #20699  |  Link
cypher007
anyone getting a microsoft virus scan come up when updating to 1.27.3?
Old 30th May 2024, 20:42   #20700  |  Link
rlev11
Yep, picks up Trojan:Win32/Phonzy.B!ml on ribbot264.exe and Trojan.Win32/Wacatac.B!ml on encodingclient and encodingserver exe's
Malwarebytes did not pick them up, only microsoft AV realtime protection
Downloaded the latest Microsoft Safety Scanner and ran that against it and it came back clean as well
