Old 20th March 2024, 23:34   #20501  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Make sure that new system is 100% stale. CPU and ram.
Old 20th March 2024, 23:54   #20502  |  Link
slalom
slalom's Avatar
Originally Posted by Ryushin View Post
I crop everything except subtitled movies, which I generate ASS subtitle files and push them into the black bars. Otherwise, I always crop.
So you crop it to view it on a 16/9 TV. Isn't that pointless?
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 21st March 2024, 10:52   #20503  |  Link
FTLOY
Friend of a friend..
FTLOY's Avatar
I know this is a simple typo, but it turned out to be so coincidently contradictory... everyone what's a new system to be "fresh", not stale.
I even made a "grammero" (typo) in my reply....what's should have been want's
FTLOY is offline   Reply With Quote
Old 21st March 2024, 10:58   #20504  |  Link
FTLOY
FTLOY's Avatar
I don't always agree or understand some of your posts, but this one I whole heartedly agree.
However, nobody seems to do things the same, each to their own.
Old 21st March 2024, 12:29   #20505  |  Link
Ryushin
Ryushin's Avatar
Maybe just for a TV yea, but not for a computer, mobile devices, or some projectors. Why even encode the black bars. Seems like a waste of space in viewing the file.
There was a problem with cropping and Dolby Vision, but that has been solved.
Ryushin is offline   Reply With Quote
Old 21st March 2024, 15:07   #20506  |  Link
Atak_Snajpera
LOL! ofcourse I meant stable.
Old 21st March 2024, 15:28   #20507  |  Link
00-00
Thanks for the reply. Is there a specific test/software you recommend? I'm currently running tests using OCCT. I'll also check with memtest86 as well.
The system is running at stock btw, no overclocks.
00-00 is offline   Reply With Quote
Old 21st March 2024, 16:24   #20508  |  Link
Atak_Snajpera
Prime95 and memtest86 executed from usbstick
Old 21st March 2024, 16:46   #20509  |  Link
00-00
Great, will do!
Old 21st March 2024, 18:10   #20510  |  Link
slalom
slalom's Avatar
Obviously, black bars are not encoded or take space in the file
Old 22nd March 2024, 00:52   #20511  |  Link
FTLOY
FTLOY's Avatar
Great, will do
AIDA64 has some good "stress" test's.
Old 22nd March 2024, 15:21   #20512  |  Link
00-00
Thanks, will check that out!
Old 23rd March 2024, 12:00   #20513  |  Link
Ryushin
Ryushin's Avatar
Of course. I only meant that the black bars consume screen real estate. We have more and more ultra widescreen monitors now as well.
Old 25th March 2024, 10:09   #20514  |  Link
FTLOY
FTLOY's Avatar
I can't believe it, we have yet another auto update, ppl
v1.27.2
Added: Enhanced filtering for AUDIO and SUBTITLES streams
UPDATE:- Took me a little while to find the new audio feature, but it's ONLY available when using the Batch feature...
Old 26th March 2024, 14:13   #20515  |  Link
Ryushin
Ryushin's Avatar
Thanks for the Update
Thank you so much Atak! This will be a massive time saver for me. Much appreciated.
Old 26th March 2024, 22:14   #20516  |  Link
dipais
I will add the same filtering for audio streams next time. No eta though.
Hi Atak,
Would you please update the x265 encoder to support --auto-aq parameters as currently used by the latest version of StaxRip ?.
Cheers,
D
dipais is offline   Reply With Quote
Old 27th March 2024, 09:36   #20517  |  Link
FTLOY
FTLOY's Avatar
Originally Posted by dipais View Post
Hi Atak,
Cheers,
D
First post demands....not a good start
You can do this yourself !!
What you need to do is grab that same build of x265, from here:-
https://github.com/Patman86/x265-Mod-by-Patman/releases
(I used this one:- x265-3.5+156+14-df2e4c31e-.Mod-by-Patman.-x64-x86-64-v3-gcc13.2.0.7z)
Unpack it, and copy it to the x265 folder in RipBot264, and rename it accordingly.
Then go to the "Profiles" folder, choose hevc, open the profile .txt you want to modify, add --auto-aq, and save it to a different name .txt
But a word of warning, with the tests I did today, whilst waiting for Doom9 to come back online,
this x265 build does NOT play very well with RipBot.
It doesn't work in "normal" encoding mode, and when using Distributed Encoding, it works,
BUT the displayed progress (in the Encoding Server window) & info is displayed very differently to standard x265 builds.
You HAVE to have at least one Encoding Server window open, otherwise it appears to be doing nothing !!!!
As the Encoding Client window constantly shows "Initializing encoding process...", and only updates after a chunk has been completed.
Also, the read out in the bottom left corner also doesn't not display any useful info, until a chunk is completed.
Other than all that Patmans's build's are good to go (but I don't use them).
I have a strange sensation that Atak won't modify his app, to suit a "special" build of x265.
Old 27th March 2024, 14:35   #20518  |  Link
Wishbringer
Silent Reader
Wishbringer's Avatar
@FTLOY
Do Patman mods of x265 now work with RB264 DE?
Last I tested them, they didn't show progress in distributed encoding because of changes of progress bar.
Wishbringer is offline   Reply With Quote
Old 27th March 2024, 14:44   #20519  |  Link
FTLOY
FTLOY's Avatar
Originally Posted by Wishbringer View Post
@FTLOY
I thought I had explained what it does....
They work, but very differently.
So while the Encoding Server is busily encoding (showing the progress down the page), the Encoding Client shows "Initializing encoding progress", and it stays like that until that chunk is completed, then onto the next chunk, and the "Pass1" progress line gets updated as the chunks are processed.
More info:- I have just been testing jpsdr's latest x265 which also has an "auto-aq" mode, however, it seems a little more "tunable" than patman's, but it still ONLY works in DE mode. which isn't a bad thing !!
Old 27th March 2024, 15:50   #20520  |  Link
archiel
RB stuck in wait chain
Has anyone come across this situation or have a possible solution?
I am running RB and RB PD on Windows 11. After the last set of MS updates I could see ripbot264.exe in task manager, but the GUI was not loading. After running memory checks sfc /scannow, etc. without any success I looked at the process in Task Manager and could see it was in a wait-chain, waiting on a microsoft.sharepoint.exe process. Killing the process immediately allowed the GUI to load, but if there is a way to prevent this happening it would be so much better.
The microsoft.sharepoint.exe process would appear to be linked to my one-drive account, but killing it does not seem to have any adverse effect on synchronisation.
archiel is offline   Reply With Quote
