11th February 2005, 02:52 | #1 | Link |
Error "File is not valid D2V file"
When I Prepare VOB files through Gordian Knot version 34.6 or 33.1 I receive the error "File is not a valid d2v , avi or avs file!". I have downloaded and reinstalled GN several times and I can't get it to open the D2V file. What could be causing this to happen? I had no problems using GN 33.1 then I upgraded my HD and now GN will not work .
Any thoughts would be helpful. Thanks in advance. Gordian Knot 34.6 DGIndex 1.2.0 RC2 |
11th February 2005, 03:01 | #2 | Link |
Probably you have mismatched DGIndex and DGDecode versions.
Do this. Forget GK for now. Just extract the DGMPGDec 1.2.0 RC3 release into a directory. Go to that directory. Run DGIndex right there and process a file to make a D2V right there in that same directory. Then make this AVS script right there: loadplugin(".\dgdecode.dll") mpeg2source(".\your_d2v.d2v") Then load the AVS script into VirtualDub. Does it work? Last edited by Guest; 11th February 2005 at 03:16. |
11th February 2005, 04:06 | #4 | Link |
Well, I left off the .dll on "dgdecode" but I added it in an edit. I assume you have that?
OK, then. Can you post the first 20 lines of the D2V? And can you cut the clip to a reasonable size, make sure that still fails, and then upload it to my server? If you do that you are guaranteed to get a fix. I'll even guarantee it tonight if you get it to me. Here is the ftp: ftp.neuron2.net usr: guest@neuron2.net (enter it just like that) pwd: guest Up to several hundred MB is fine. |
11th February 2005, 05:34 | #5 | Link |
I did change my script to include the .dll and I got the same result. Below are the first 20 some lines of the D2V file:
DGIndexProjectFile06 1 31 F:\FROSTY\VIDEO_TS\VTS_01_1.VOB Stream_Type=1 iDCT_Algorithm=5 (1:MMX 2:SSEMMX 3:FPU 4:REF 5:SSE2MMX) YUVRGB_Scale=1 (0:TVScale 1:PCScale) Luminance_Filter=0,0 (Gamma, Offset) Clipping=0,0,0,0 (ClipLeft, ClipRight, ClipTop, ClipBottom) Aspect_Ratio=4:3 Picture_Size=720x480 Field_Operation=0 (0:None 1:ForcedFILM 2:RawFrames) Frame_Rate=29970 Location=0,0,0,7FF57 7 0 2048 2 1 12 12 12 12 12 12 12 12 12 12 7 0 374784 2 1 12 12 7 0 477184 2 1 12 12 7 0 575488 2 1 12 12 7 0 665600 2 2 12 12 12 12 12 12 12 12 12 12 12 12 7 0 1155072 2 2 12 12 12 12 12 12 12 12 12 12 12 12 7 0 1636352 2 2 12 12 12 12 12 12 12 12 12 12 12 12 7 0 2140160 2 2 12 12 12 12 12 12 12 12 12 12 12 12 7 0 2643968 2 2 12 12 12 12 12 12 12 12 12 12 12 12 7 0 3151872 2 2 12 12 12 12 12 12 12 12 12 12 12 12 7 0 3639296 2 2 12 12 12 12 12 12 12 12 12 12 12 12 |
11th February 2005, 05:47 | #7 | Link |
Well unfortunatly I received that file of DGIndex from Doom9's page and it is not the most current version as stated "DGMPGDec - latest version of the tool formerly known as DVD2AVI".
I will try to locate the correct version of the program and follow your instructions. |
11th February 2005, 06:05 | #8 | Link |
OK. Get it right here:
http://neuron2.net/fixd2v/decodefix.html DGIndex and DGDecode come in matched pairs. So be sure to use the correct version of both DGIndex.exe and DGDecode.dll. Don't mix and match from different distribution zip files. Please post back if you have any further problems. Thank you for your feedback. I see an opportunity to improve the documentation. |
11th February 2005, 06:39 | #9 | Link |
Alright, I have installed the correct version, 1.2.0 RC3 and I have run the script as above and I still have the same results both in GK and per your instructions above. When I run VirtualDubMod with the script it just closes.
Below is the information from the D2V file: DGIndexProjectFile08 1 30 C:\Movies\DGIndex\VTS_01_1.VOB Stream_Type=1 iDCT_Algorithm=5 (1:MMX 2:SSEMMX 3:FPU 4:REF 5:SSE2MMX) YUVRGB_Scale=0 (0:TVScale 1:PCScale) Luminance_Filter=0,0 (Gamma, Offset) Clipping=0,0,0,0 (ClipLeft, ClipRight, ClipTop, ClipBottom) Aspect_Ratio=4:3 Picture_Size=720x480 Field_Operation=0 (0:None 1:ForcedFILM 2:RawFrames) Frame_Rate=29970 Location=0,0,0,7FF57 c00 1 0 2048 2 1 b2 92 b2 a2 b2 a2 b2 a2 b2 a2 c00 1 0 376832 2 1 b2 92 c00 1 0 481280 2 1 b2 92 c00 1 0 579584 2 1 b2 92 |
11th February 2005, 06:46 | #10 | Link |
Please put a source clip on my ftp site so I can figure this out for you. Use VOBSplit to cut off the front and give that to me. Make sure it still fails before uploading it.
Also, use Windows search to see if you have more than one DGDecode.dll on your PC. If you do, delete all but the RC3 one in the directory that I asked you to make. It's especially important to stop Avisynth from autoloading any other versions. Last edited by Guest; 11th February 2005 at 06:52. |
11th February 2005, 07:48 | #11 | Link |
Neuron2
I searched my HD and found the version of DGDecode.dll in the Avisynth directory was not current to the RC3 version of your prog. I corrected this and now I am not having any problems in GK, though the script still isn't functioning correctly. I will look into that tomorrow when I am more awake. If I am still experiencing the same issue I will fillow up with your. Thanks for your help. |
11th February 2005, 14:52 | #13 | Link |
The same thing...
I have the same problem. Starting from installing GordianKnot.RipPack.0.33.1.Setup.exe and now with GordianKnot.RipPack.0.34.6.beta.Update.exe
I check dll in Avisinth folder also - it's Ok but the problem persists. The only solution for me is the use of DVD2AVI instead of DGIndex. |
11th February 2005, 15:11 | #15 | Link |
One more thing!
I'll check it but first I must say one more thing: DGIndex RC2 and RC3 doesn't respond to F3 key command!
So in fact there is a contradiction with GK instructions on the first tab of GK. It may be really confusing for some people! |
11th February 2005, 15:29 | #17 | Link | ||
Dismembered
I just thought I'd inform Squirrel Nut Zipper, and now I'm buzzing off again , since as neuron 2 mentioned rightly, this is off topic entirely.
Allen's Axiom: When all else fails, read the instructions. |
11th February 2005, 15:45 | #18 | Link |
Hmm...
What can I say... Actually it was in 1.1.x version.
Anyway, why don't you implement this? Don't you think it will be convenient? Is it so difficult thing to do? Concerning the main topic I made the script as you say; it opens in VirtualDubMod flawlessly. So it seems there is a problem with some dll's coming with GK. Cannot DGIndex or GK be confused by the presence of MPEG2Dec.dll or mpeg2dec3.dll in GK folder? I think we need to move this topic to GK forum. |
11th February 2005, 15:57 | #19 | Link | ||
Re: Hmm...
11th February 2005, 18:13 | #20 | Link | |
Re: Error "File is not valid D2V file"
Can you return something to the effect of "d2v is newer than DGDecode" or "Mismatched d2v and DGDecode versions) Leave the "File is not a valid d2v" message for truely unreadable d2v files. |
