Old 22nd June 2004, 00:38   #61  |  Link
Kyle_Katarn
VTB v0.9.4.44 [22/06/2004]
+ Online help
@ GUI : sizable (at last)
http://www.kcsoftwares.com/?vtb
Online Help : http://www.kcsoftwares.com/doc/vtb
KC Softwares
Kyle_Katarn is offline   Reply With Quote
Old 15th July 2004, 16:41   #62  |  Link
Kyle_Katarn
VTB v0.9.7.47 [15/07/2004]
+ "Batch" feature. Exports results to CSV / HTML files for multiples video files
# Play and burn where disabled when loading file by drag'n'drop
WWW : http://www.kcsoftwares.com/?vtb
KC Softwares
Old 15th July 2004, 20:39   #63  |  Link
WaryWolf
this is a great tool kyle, thanks for making it available
but i noticed that the bitrate/quality factor characteristics were not available for matroska video files. i'm guessing that because this is because you haven't got the appropriate settings for the overhead. the calculator integrated into the xvid settings provides this information, at least for xvid streams, if you're interested.
WaryWolf is offline   Reply With Quote
Old 15th July 2004, 21:59   #64  |  Link
bond
if you support apples .mov, you could also support .mp4 easily, as the two are pretty similar
Ogg Theora | Ogg Vorbis
Old 15th July 2004, 22:19   #65  |  Link
Kyle_Katarn
I don't have specs for MP4 files.... but as soon as i've got some, i'll implement its support.
I haven't tried to get MKV bitrate for a long time, i'll get back to this problem as soon as i got rid of installed codec detection.
KC Softwares
Old 15th July 2004, 22:26   #66  |  Link
bond
have a look at the docs mentioned in my mp4 faq and mpeg-4 info thread i linked to in my signature
Old 15th July 2004, 22:27   #67  |  Link
Kyle_Katarn
Thank you very much, i'll give it a look asap ;-)
KC Softwares
Old 19th July 2004, 20:08   #68  |  Link
Kyle_Katarn
VTB v0.9.8.48 [19/07/2004]
+ New features : lists installed Audio & Video Codecs
@ GUI Layout (again)
# Display bug with large fonts fixed.
www : http://www.kcsoftwares.com/?vtb
KC Softwares
Old 21st July 2004, 10:09   #69  |  Link
Atamido
Seņor Member
Atamido's Avatar
Atamido is offline   Reply With Quote
Old 21st July 2004, 10:57   #70  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Great stuff... thanks
Old 21st July 2004, 17:54   #71  |  Link
Kyle_Katarn
Thanks !
Kyle
KC Softwares
Old 26th July 2004, 14:03   #72  |  Link
Kyle_Katarn
VTB v1.0.0.58 [26/07/2004]
+ New feature : Indicates if required codec is installed
+ [Settings] Add/Remove Context menu (Open With VideoToolbox)
+ [Batch Exporter] "Reset" button
+ Available as a Zip file (no installer)
@ Export function now saves file name and asks for output directory
@ GUI Layout (again, again... and again !)
@ [Settings] GUI Layout
@ [Install Script] Start Menu Icons can be disabled
@ [Install Script] context menu item can be disabled
@ Language Files
# [Installed Codecs Lister] Audio codecs infos displayed.
# [Installed Codecs Lister] Form can be maximized properly.
# [Batch Exporter] Root (ie : c:\) are no longer considered as invalid output directory
# Message boxes shouldn't use french caption for yes/no buttons anymore.
Web : http://www.kcsoftwares.com/?vtb
KC Softwares
Old 1st September 2004, 13:13   #73  |  Link
Kyle_Katarn
VTB v1.1.0.64 [01/09/2004]
+ Add DV Type-1 AVI Files Containing One DV Data Stream (http://msdn.microsoft.com/library/de...fileformat.asp)
+ New codec database : MiCDB : (http://micdb.free.fr for details). Video Codecs : 438, Audio Codecs : 191
@ Improved Codec management routines
KC Softwares
Old 14th September 2004, 21:09   #74  |  Link
Kyle_Katarn
VTB v1.1.1.65 [14/09/2004]
# Fixed crash when using "Open With VideoToolbox" context menu due to a bug introduced by v1.1.0.64
KC Softwares
Old 25th September 2004, 14:18   #75  |  Link
Kyle_Katarn
VTB v1.2.0.70 [24/09/2004]
@ Internal software integrity check
# Software named changed from VideoToolbox to VideoInspector
KC Softwares
Old 7th October 2004, 20:55   #76  |  Link
Kyle_Katarn
VTB v1.2.1.71 [07/10/2004]
@ Internal software integrity check (again)
@ Zip (no install) distribution is back !
KC Softwares
Old 7th October 2004, 20:58   #77  |  Link
SeeMoreDigital
Thanks Kyle,
Have you thought anymore about adding MP4 container file reading?
Cheers
Old 19th January 2005, 19:42   #78  |  Link
Kyle_Katarn
MP4 will be added very soon.
Regards,
Kyle
Ps : v1.2.2.72 avaialble here : http://www.kcsoftwares.com
KC Softwares
Old 24th January 2005, 11:42   #79  |  Link
Valky
Valky's Avatar
It doesn't show audio at all in DV-1 type file, but it shows it correctly after the file has been converted to Huffy.
Valky is offline   Reply With Quote
Old 24th January 2005, 18:34   #80  |  Link
Kyle_Katarn
Thanks, I'll investigate
KC Softwares
