Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD burning
Old 11th September 2003, 01:43   #1  |  Link
Kyle_Katarn
Ignition : DVD burning optimizer
Ignition is a FREEware developped by the Katarn Corp.
Ignition optimizes the way that CD / Audio CDs / DVD are burnt by dispatching files on multiple media in order to minimize the space lost on each media. A must have for your archiving processes.
[Screenshot]
[Web Site]
http://www.katarncorp.com/?ignition
KC Softwares
http://www.kcsoftwares.com
Kyle_Katarn is offline   Reply With Quote
Old 11th September 2003, 01:44   #2  |  Link
Kyle_Katarn
Update : 2.2.1.24
>> Improved support for audio content
KC Softwares
Old 13th September 2003, 04:46   #3  |  Link
b0b0b0b
b0b0b0b's Avatar
Hi, is this like a knapsack or bin packing solver?
Ignition features ...
Support 650,700 Mb CDs and DVDs
Automatically create folders for each optimized CD or create a TXT file that contains the optimized list of each CD's content.
Ability to put a bunch of files on every media (autorun, codecs...)
Ability to burn CDs/DVDs (requires CopyToDVD)
Internationalization support.
b0b0b0b is offline   Reply With Quote
Old 13th September 2003, 08:50   #4  |  Link
Kyle_Katarn
bin packing solver + frontend for CD/DVD software
KC Softwares
Old 13th September 2003, 08:51   #5  |  Link
maa
Don't get it...
Does "Internationalization support" make my foriegn DVDs look better
Whats more usefull: E=MC˛ or (CallSS VMGM) Call VMG PGC: 1 [Resume Cell: 1]?
maa is offline   Reply With Quote
Old 13th September 2003, 08:53   #6  |  Link
Kyle_Katarn
No, it means that the software can be translated (Settings->...) in many (list available on the software's web page) languages ;-)
KC Softwares
Old 5th October 2003, 14:18   #7  |  Link
Kyle_Katarn
Update Available : http://www.katarncorp.com/?ignition
KC Softwares
Old 6th October 2003, 14:48   #8  |  Link
Rober2D2
What I normally do is compession and auto split using winrar which is quite slow, so I will give a chance to this tool.
Rober2D2 is offline   Reply With Quote
Old 6th October 2003, 15:50   #9  |  Link
Kyle_Katarn
Thank you
KC Softwares
Old 28th October 2003, 09:52   #10  |  Link
Kyle_Katarn
Have you tested it ? Do you have comments ?
KC Softwares
Old 17th August 2014, 22:17   #11  |  Link
Kyle_Katarn
Ignition - 2.15 (Released 2014-08-17)
- 0002582: [New Feature] New Icon (Kyle_Katarn) - resolved.
- 0002543: [New Feature] Make window sizeable (Kyle_Katarn) - resolved.
- 0002228: [New Feature] Log shall indicate if administrator rights are granted (Kyle_Katarn) - resolved.
- 0002252: [New Feature] Windows 8.1 support in log file (Kyle_Katarn) - resolved.
KC Softwares
Old 7th December 2014, 14:31   #12  |  Link
Kyle_Katarn
Ignition - 2.15.1 (Released 2014-12-07)
- 0002681: [New Feature] "Buy media" button (Kyle_Katarn) - resolved.
- 0002668: [Bug] Misdetection of Windows 8.1 (Kyle_Katarn) - resolved.
KC Softwares
Old 29th March 2015, 18:34   #13  |  Link
Kyle_Katarn
Ignition - 2.16 (Released 2015-03-29)
- 0002813: [Bug] "Load project" window is cluttered (Kyle_Katarn) - resolved.
- 0002741: [Bug] GUI problems with 120 DPI (Kyle_Katarn) - resolved.
- 0002812: [Refactoring] Error message when "optimize" action launched with no files. (Kyle_Katarn) - resolved.
- 0002810: [Refactoring] "A group is bigger than media size" error message should indicate which one (+size) (Kyle_Katarn) - resolved.
KC Softwares
Old 9th May 2015, 14:37   #14  |  Link
Kyle_Katarn
Ignition - 2.17 (Released 2015-05-09)
- 0002830: [Refactoring] More robust audio file analyse (Kyle_Katarn) - resolved.
- 0002828: [Bug] Remove Flac support until duration is properly detected (Kyle_Katarn) - resolved.
- 0002829: [Bug] Memory leak in drag'n'drop procedure (Kyle_Katarn) - resolved.
KC Softwares
Old 5th July 2015, 09:22   #15  |  Link
Kyle_Katarn
Ignition - 2.18 (Released 2015-07-05)
- 0002841: [Bug] If I language is changed the custom size gets reset to zero. (Kyle_Katarn) - resolved.
- 0002840: [Bug] Help is not working - Nothing happens if select help from the menu or pressing F1. (Kyle_Katarn) - resolved.
- 0002725: [Refactoring] Change CTRL+A shortcut from "About..." to "Select All" (Kyle_Katarn) - resolved.
KC Softwares
Old 6th December 2015, 21:42   #16  |  Link
Kyle_Katarn
Ignition - 2.19 (Released 2015-12-06)
- 0002937: [Refactoring] Update of "invalid licence" message (due to revocation machanism) (Kyle_Katarn) - resolved.
- 0003230: [New Feature] ALSR (Address space layout randomization) (Kyle_Katarn) - resolved.
- 0003306: [Refactoring] Upgrade of internal JEDI Libraries (Kyle_Katarn) - resolved.
- 0003270: [Bug] Windows 10 support in log file (Kyle_Katarn) - resolved.
KC Softwares
Old 7th February 2016, 15:15   #17  |  Link
Kyle_Katarn
Ignition - 2.20 (Released 2016-02-07)
- 0003502: [Bug] Wrong language file used (Kyle_Katarn) - resolved.
- 0003490: [Bug] Log of language + change (Kyle_Katarn) - resolved.
KC Softwares
Old 14th November 2017, 22:03   #18  |  Link
Kyle_Katarn
Ignition - 2.23 (Released 2017-11-14)
0004533: [Refactoring] Update of internal ICS library from 8.34 to 8.50 (Kyle_Katarn)
0004416: [New Feature] Menu item for "Bug report" and "Change Log" (Kyle_Katarn)
0004532: [Bug] Read settings from wrong reg key (Kyle_Katarn)
0004332: [Refactoring] Updated Dutch translation (Kyle_Katarn)
KC Softwares
Old 2nd January 2019, 14:33   #19  |  Link
Kyle_Katarn
Ignition - 2.25 (Released 2019-01-02)
https://www.kcsoftwares.com/?ignition
0005136: [Bug] Crash when closing Portable version ran from a read only folder (eg : NAS,...) (Kyle_Katarn)
0005237: [Refactoring] Logging version of active OpenSSL to prepare use of SSL (Kyle_Katarn)
0005043: [Refactoring] OpenSSL 1.1.0h > 1.1.0i (Kyle_Katarn)
0005236: [Bug] CopyToDvd not found (Kyle_Katarn)
0005235: [New Feature] Add BluRay 25 & 50 sizes into media menu (Kyle_Katarn)
0005180: [Refactoring] Updated Hungarian translation (Kyle_Katarn)
0005082: [Refactoring] Improved log management as per 0005071 (Kyle_Katarn)
0004933: [Bug] Language setting is not saved in Portable version (Kyle_Katarn)
0004927: [Refactoring] Spanish (Argentina) translation update (Kyle_Katarn)
KC Softwares
Old 8th May 2019, 11:25   #20  |  Link
Kyle_Katarn
Ignition - 2.26 (Released 2019-05-08)
0005286: [Bug] Missing UninstallDisplayIcon in registry for installed version (Kyle_Katarn)
0000917: [Bug] Uninstall icon is incorrect, displays as recycling bin. (Kyle_Katarn)
0005425: [Refactoring] bcrypt.dll is missing error on Windows XP (Kyle_Katarn)
0005316: [Bug] Update ICS library to 8.59 and OpenSSL to 1.1.1b (Kyle_Katarn)
KC Softwares
